Miata MX-5
> Miata - General Questions
 Old 04-13-2016, 01:04 PM   #1
Sungamma's Avatar
Posts: 3   (View Stats)
Sungamma will become famous soon enough
Default 04 MSM Speedo Issues
Hi all. Having an intermittent issue with the speedo on my '04 MSM. Usually starts out fine, then the speedo needle stops and starts a few times, then quits altogether, usually after 15-30 minutes. Next day, after sitting all night, it usually starts right up again and runs the same pattern. Can anyone help? Thanks in advance!!
Sungamma is offline   Reply With Quote
 Old 04-13-2016, 01:44 PM   #2
thrisnospork's Avatar
Posts: 254   (View Stats)
*Puts on flame suit*
I used to drive a 1st gen dodge neon a while back and they were notorious for having a similar issue. The solder points for the speedo would crack and you had to pull it, disassemble and reflow all the points. It may be worth pulling the gauge cluster out and checking for that.
thrisnospork is offline   Reply With Quote
 Old 04-18-2016, 04:50 PM   #3
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
^ lol, the MSM wasn't built in America, so I highly doubt some redneck did the soldering causing it to fail so quickly.
This is how you can repair the sensor that is failing. May want to buy a new one just in case you screw the pooch. NB Speedometer Generator Repair - ClubRoadster.net
Past Mazdas & Speeds
Sungamma (04-18-2016)
 Old 04-18-2016, 06:35 PM   #4
Sungamma's Avatar
Thanks a bunch. Sounds like it's EXACTLY what's going on with mine. Question for me is, do I attempt repairing the old one or just replace with a new unit. Will have to ponder that but one way or another, it will be fixed. Thanks!!
The Following User Says Thank You to Sungamma For This Useful Post:
Neverlift (04-19-2016)
Different Speedo!? CluelessTony Mazdaspeed3/6 General Discussion 23 10-08-2014 04:40 PM
ms6 speedo 180 ms3 speedo 160 johnnyspeed6 MazdaSpeed 3/6 - Dyno Sheets/Discussions 19 02-25-2009 03:51 PM
Page generated in 0.25047 seconds with 22 queries
