![]() Join Date: Apr 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Can anyone recommend a good auto body shop in SoCal (preferably Orange County) that does good paint work at a reasonable price? I have an '05 MSM that needs an entire paint job. I've received quotes from $2k to $8k. |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Not in the OC, but my good friend Andrew owns a body shop in Van Nuys. Tell him Tony sent you. And those MSM paint jobs are several stage metallics... that shit is not cheap or easy to lay down, so those quotes seem reasonable. https://www.facebook.com/ACHMotoring/ He also hosts track events if you want to bring the MSM out and get some quality seat time. https://www.motorsportreg.com/events...raceway-294739 https://www.facebook.com/achmtrackdayz/
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
(Thread Starter) | Not Ranked : 0 score Thank you! I'll give him a call |
| The Following User Says Thank You to hnoman For This Useful Post: | Neverlift (04-19-2017) |
| Tuning Shops in NorCal or SoCal ??? | 11cruzito11 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 06-16-2009 07:59 PM |
