![]() | | #41 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following User Says Thank You to Neverlift For This Useful Post: | Easter Bunny (10-18-2014) |
![]() | | #42 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
(Thread Starter) | Not Ranked : 0 score manifold bolted up
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #43 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score happy midship monday
| The Following User Says Thank You to dooderek For This Useful Post: | Koke382 (10-27-2014) |
![]() | | #44 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score Custom exhaust fitted
![]() | | #45 | ![]() |
![]() Join Date: Jun 2012 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score Please tell me the car has a 6sp or you got a 6sp with the 2zz
__________________ 2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob Dyno'ed at 277whp/290lb-ft on 91 piss |
![]() | | #46 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Nope. Nope. & Nope. Who in their right mind would waste money on a C series 6 speed trans when the Turbo E153 & Solara E351 bolt right in?
![]() | | #47 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score Stock muffler = 28.2 lbs Stock Downpipe = 13.4 lbs Stock header = haven't weighed yet but total stock exhaust system should be a little over 50 lbs ![]()
![]() | | #48 | ![]() |
Groans: 239
| The Following User Says Thank You to dooderek For This Useful Post: | WetzMS3 (11-12-2014) |
![]() | | #49 | ![]() |
| Not Ranked : 0 score Are the gears in the E153 short enough for the 2ZZ? Of course it doesn't matter if you are going FI.
![]() | | #50 | ![]() |
Groans: 239
You are correct the c56 transmission has longer gears which makes staying in lift "difficult" but no impossible. most notably 1-2, 2-5 no issues Although in the meantime i did source a nice 00-01 Celica ecu where the lift engages at 6k and redlines at 8350
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" | |
![]() | | #51 | ![]() |
I know more than I would like about these engines lol.
__________________ 2009 CWP MS3 | JBR short shift plate, JBR shifter bushings, CP-e stage 2 RMM, JBR RSB, JBR Wide-Path, CS downpipe, UR catted test pipe, Cobb cat-back, Forge BPV V1, Swift Spec R springs, Bilstein B8, Whiteline KCA428 ALK, Whiteline Bumpsteer Correction, Corksport injector seals, Weds Sports SA55M 18x8 +48, Bridgestone S-04 245/40/18, BLOX Limited 490g shiftknob Dyno'ed at 277whp/290lb-ft on 91 piss | |
![]() | | #52 | ![]() |
Groans: 239
Yeah the ecu by the year did change from 8350/6000 to 8250/6200 RL/LIFT in the later years. IIRC 8700 wouldn't be possible on the stock valve train :X
![]() | | #53 | ![]() |
Also if you notice Lift not engaging, you would have to change out the lift bolts.
| The Following User Says Thank You to EvoFire For This Useful Post: | Neverlift (11-04-2014) |
![]() | | #54 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score here we go, 2zz's in! LSD getting ready to be put in and so it begins out with the old Really got my monies worth out of the clutch lol in with the new She's in! Getting late, hard parking in the garage until tomorrow
![]() | | #55 | ![]() |
Groans: 1,143
| Not Ranked : 0 score So, hardtop? Brakes? Wheels?
![]() | | #56 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score the stock brakes are gewwwd. Nobody bothers upgrading them except for pads. lol nigga i aint made of money, can't be blowing whole wads of cash at the car haha
![]() | | #57 | ![]() |
Groans: 1,143
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() | |
| The Following User Says Thank You to Neverlift For This Useful Post: | Koke382 (11-09-2014) |
![]() | | #58 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score Start blowing wads for cash.
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() | | #59 | ![]() |
![]() Join Date: Aug 2011 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,535
Groans: 60
| Not Ranked : 0 score Looks better than the impulse for sure.
__________________ 2011 MS3. Cobb AP V3, GTX3071, CPE LTR mani, Tial 44mm EWG, 3 bar MAP sensor and PnP harness, JBR WP intake, HTP battery tray with a 51 Optima Yellow battery, ITV22s, GFB BOV, Autotech internals, CPE injector seals and studs, VTCS delete, COBB FMIC, UR DP and TP, CNT CBE, JBR TIGs and Coolant bypass, JBR EGR delete, JBR RMM, PMM, and TMM, JBR OCC, PERM Plate, JBR RSB, JBR Rear Camber arms, 17X8 RPF1, TWM full replacement shifter with a PERM buttplug shift knob. Waiting to install:Built block, NJspeed PNP IM, Prosport boost and water temp gauges, coilovers and shit. |
| The Following 3 Users Say Thank You to BPASPEED For This Useful Post: |
![]() | | #60 | ![]() |
Groans: 239
![]() | | #61 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Looks like the GookPro Hero 4+ does pretty decent in low light, but sucks at no light. How big a difference is handling and turn in with the LSD? How is lift?
![]() | | #62 | ![]() |
Groans: 239
The difference with a lsd is amazing. Even making u turns is fun hahaha. Finally I don't plow around low speed corners with one wheel. I can now rotate the car with power. Lift is great. The 2zz actually feels about the same as the 1zz until lift kicks in. The only drawback is too be in the powerband I have to be at 6k. I can see now the drawback with the 5 speed. Staying in lift between 1 - 2 is hard. Landing out of lift means out of the power and, which makes the car "slow" (relatively) until you get back to lift. The pro of the 5 speed is you stay in power longer, but it's all moot once forced induction happens . I'll be doing a powerfc this month too.
![]() | | #63 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Boo PowerFC.
![]() | | #64 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score daytime shot, npt bad for a gookpro lol
![]() | | #65 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score falling out of lift 1-2 power shifting 2-3 some more intake noise
![]() | | #66 | ![]() |
Groans: 239
![]() | | #67 | ![]() |
Groans: 239
![]() | | #68 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score just hooning around understeers pretty terribly in the rain. clutch dump
| The Following User Says Thank You to dooderek For This Useful Post: | Koke382 (11-23-2014) |
![]() | | #69 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Yeah, I've found all MR cars push really bad in the rain. It just takes incredible commitment to the throttle, like more input than you would expect, and it must remain constant, without fear.
| The Following User Says Thank You to Neverlift For This Useful Post: | Koke382 (11-23-2014) |
![]() | | #70 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score dat feel when you go around your corner and your limited slip locks and the car grips like its on rails
| The Following User Says Thank You to dooderek For This Useful Post: | BPASPEED (11-29-2014) |
![]() | | #71 | ![]() |
![]() Join Date: Jan 2014 Location: Fort Worth, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score I've gotta say I was not a fan of MR2s until I started following this thread, but I really love your car. Props to you this thing is badass. |
![]() | | #72 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score ohh roooo
![]() | | #73 | ![]() |
Groans: 1,143
| Not Ranked : 0 score My clutch slave shit the bed already. I have the same feels.
| The Following User Says Thank You to Neverlift For This Useful Post: | Koke382 (12-03-2014) |
![]() | | #74 | ![]() |
Groans: 239
| The Following User Says Thank You to dooderek For This Useful Post: | Koke382 (12-10-2014) |
![]() | | #75 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score Will be installing a Hard dog roll bar, 255 fuel pump, moroso baffled oil pan, powerfc, 3" ID intake, and the 660cc injectors will be installed while replacing the gas tank
![]() | | #76 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Skip the pan, get an accumulator.
![]() | | #77 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score new baffled oil pan
![]() | | #78 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score Hard dog roll bar in, messing around with some foam, Painting the battery box for the deka etx12 (rust protection, not because ricer)
| The Following User Says Thank You to dooderek For This Useful Post: | Koke382 (01-08-2015) |
![]() | | #79 | ![]() |
Groans: 239
(Thread Starter) | Not Ranked : 0 score new whale peenor intake 3.25" OD, 3" ID. about the max the pfd can handle accurately
![]() | | #80 | ![]() |
Groans: 370
| Not Ranked : 0 score Damn, is that coupler JDM? |
| The Following 3 Users Say Thank You to aaronc7 For This Useful Post: |
