Miata MX-5
> Miata - General Questions
Like Tree10Likes
 Old 12-19-2014, 11:37 AM   #81
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
I guess ill put this here
The Following 3 Users Say Thank You to UnknownSuperhero For This Useful Post:
aaronc7 (12-19-2014), Easter Bunny (12-22-2014), Neverlift (12-19-2014)
 Old 12-20-2014, 12:09 AM   #82
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
come@me bro
 Old 12-20-2014, 09:29 AM   #83
2zz mr-s
dooderek's Avatar
Groans: 239
The Following User Says Thank You to dooderek For This Useful Post:
Neverlift (12-20-2014)
 Old 12-28-2014, 10:38 PM   #84
2zz mr-s
dooderek's Avatar
Groans: 239
Finally after a week of docking around, the tuning is complete. Our recent issue was for some odd reason, we were seeing huge amounts of knock in only one cell. The auto tuning software which actually does closed loop WOT ignition tuning kept picking up knock and retarding the ignition. We eventually ended up with a ignition curve going from 26 degrees to 4 degrees and back to 24. There was a very noticeable dip in power when going through that "trouble" cell.
So after doing a few things (checking plugs, etc.) we decided to swap to another PowerFC, luckily we had two on hand. Lo and behold the issue was gone.
Will post pics and vids soon. sure all you guys are "dying" to see them, lol.
Koke382 likes this.
Koke382 (01-08-2015)
 Old 12-29-2014, 03:57 PM   #85
2zz mr-s
dooderek's Avatar
Groans: 239
Installed a Prosport 60mm LSU 4.9 wideband gauge,
Bought the Lo-Tek 60mm A pillar gauge pod, so off went the oem one!
Removing the oem a pillar was finicky, I removed the 2 bolts on the side of the dash (facing the drivers door) to leverage a bit of wiggle room with the dash. The a pillar essentially clips in, a bit of yank and it came out. Problem area was the area around the top latch for the top. I surmise you could remove it for better leverage but it is not necessary.
Next I found a nice spot where I could route the gauge wires up into the A pillar,
I decided the best spot to tap for power was the fuse box located on the side of the dash facing the drivers door. The prosport gauge actually requires a 12v constant and a 12v switch, this is due to the peak and warn function. If you only hooked it up to the switch then the gauge would lose its set peak and warn memory every time you turned the car off. To ensure a steady flow of electricity I hooked in a relay from the 12v switch to the battery.
For the 12v constant I tapped into the OBD2 fuse.
For the 12v switch I used the CIG fuse (ACC) although a IGN switch would work too.
Routed the wires under the driver side door sill, just pull up gently around the edges and it comes out! (held in by plastic clips)
I used this grommet to route the wires to the engine bay.
Controller box for the wideband (Not all widebands use an external controller, some like the AEM UEGO is built into the gauge)
Finished product
Koke382 likes this.
 Old 12-30-2014, 12:58 AM   #86
2zz mr-s
dooderek's Avatar
Groans: 239
induction noise!
Koke382 (01-19-2015)
 Old 01-08-2015, 10:01 AM   #87
2zz mr-s
dooderek's Avatar
Groans: 239
installed some chassis bracing,
Crazy how much body flex the breast plate reduces. Next to the Front Strut Bar, this is the most noticeable bracing improvement.
Koke382 likes this.
The Following 2 Users Say Thank You to dooderek For This Useful Post:
Easter Bunny (01-09-2015), Koke382 (01-08-2015)
 Old 01-08-2015, 10:08 AM   #88
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Looks like this is going to be a really potent car. When is the first track day?
Past Mazdas & Speeds
 Old 01-08-2015, 11:33 PM   #89
2zz mr-s
dooderek's Avatar
Groans: 239
Tony, teach me how to make such a crystal clear GIF
 Old 01-09-2015, 07:52 AM   #90
Neverlift's Avatar
Groans: 1,143
Of all the things I could teach and you choose GIFs?
This will cost you
UnknownSuperhero (01-09-2015)
 Old 01-09-2015, 10:19 AM   #91
It's a nice little car Derek - looks and sounds great. Tuned out the understeer you were mentioning earlier?
 Old 01-09-2015, 06:10 PM   #92
2zz mr-s
dooderek's Avatar
Groans: 239
Hey Alex!
It's been a long time, we need to catch up one of these days.
Interesting enough, I did fix the understeering. Played around with the tire pressure till I got it where I wanted. I dropped about three psi in the front.
 Old 01-19-2015, 08:40 AM   #93
2zz mr-s
dooderek's Avatar
Groans: 239
Weather was great this weekend, so I decided to drop the top down and take a quick vid.
 Old 01-28-2015, 02:09 PM   #94
2zz mr-s
dooderek's Avatar
Groans: 239
weathers nice, finally taking some pictures with the top down,
Also swapped in the 1zz knock sensor to get more accurate readings. I expect to be hitting 29 - 30 degrees of timing engine allowing.
 Old 01-28-2015, 07:24 PM   #95
Neverlift's Avatar
Groans: 1,143
Hardtop, Wheels, AEM EMS.
 Old 11-14-2015, 09:52 PM   #96
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
bump.
SofaKingAwesome likes this.
94 M
MS6
IS350
Page generated in 0.37866 seconds with 25 queries
