Miata MX-5
> Miata - General Questions
 Old 05-29-2016, 09:36 AM   #1
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
Default Msm wont start, help!
Need some help with a miata!
Just had the engine rebuilt, block is back in the car. The car sat for about 7 or so months, so we drained all the fuel and refilled it, we are getting fuel and spark in the cylinders and it is turning over but not firing. Verified timing, no vacuum leaks.. Everything on the car is stock but the pistons, rods, valves, and turbo. Car is an 04 mazdaspeed miata.
@Code Monkey; if you know someone that could help please tag them
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
The Following User Says Thank You to derek13p For This Useful Post:
Code Monkey (05-29-2016)
 Old 05-29-2016, 09:47 AM   #2
@Neverlift;
 Old 05-29-2016, 10:23 AM   #3
Mmahan3510's Avatar
Posts: 93   (View Stats)
Mmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of light
Groaned at 19 Times in 6 Posts
Compression?
Sent from my VIVO XL using Tapatalk
2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT
Mmahan3510 is offline   Reply With Quote
 Old 05-29-2016, 10:59 AM   #4
derek13p's Avatar
Groans: 38
The rings are new and have never been heat cycled so the compression is 60 at the moment.
Was told that putting a few drops of trans fluid in each cylinder would raise it up a little more but once it heat cycles and sets in it'll raise up
06 MS6 & 06 MS6
Daily driven
 Old 05-29-2016, 01:13 PM   #5
Mmahan3510's Avatar
Crank sensor signal? Just thinking of the simple things first
 Old 05-29-2016, 08:11 PM   #6
derek13p's Avatar
Groans: 38
how do you check to see if its getting signal?
06 MS6 & 06 MS6
Daily driven
 Old 05-29-2016, 08:34 PM   #7
Mmahan3510's Avatar
Get a buddy and have them turn the car over, while you have a multimeter checking for resistance at the sensor. If it is zero or infinite you have a bad sensor.
Or a scanner
Last edited by Mmahan3510; 05-29-2016 at 08:34 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Mmahan3510 For This Useful Post:
derek13p (05-29-2016)
Help - car wont start WillyH Gen2 MS3 General Discussion 17 12-10-2012 04:16 PM
Cobb AP Wont work car wont start boosted_speed6 Mazdaspeed3/6 General Discussion 30 05-09-2011 11:11 PM
08 MS3 Wont Start jross993 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-04-2011 04:20 PM
Car wont start! SharkDiver MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 10-14-2009 07:02 PM
Page generated in 0.27775 seconds with 22 queries
