Miata MX-5
> Miata - General Questions
 Old 08-01-2015, 07:16 PM   #1
Atticaz's Avatar
Posts: 621   (View Stats)
Default P1260 CODE on 2007 MX-5
I am pretty sure a trip to the stealership is the only way to go. But still. Dealing with this shit right now. Wife drove her car yesterday and parked it in the garage. The car was pulled into the garage and sat there over night. The only thing that has happened between then a now is I replaced a power window switch. I found out the window switch was missing one of the connectors, so I reinstalled the original. After that, car would not start. I took the battery, which is new to be tested. It's fine. Used my DashCommand app to reveal the P1260 code. "Theft Detected. Vehicle Immobilized."
Anyone had this happen and what did you do to fix it?
2007 MAZDASPEED3 - SOLD
 Old 08-03-2015, 07:16 PM   #2
Atticaz's Avatar
Ended up getting the car towed to the dealership. Ended up being a blown IC fuse. I did a fuse check. Guess I missed one somehow. The dealership waived the $328 diagnostic tests and fuse replacement. Only had to pay $95 for towing. The most expensive fuse swap ever. Lol FML
 Old 08-04-2015, 10:25 AM   #3
At least the problem in the end was easy.
-Derrick
 Old 08-04-2015, 10:52 AM   #4
Atticaz's Avatar
-Derrick
Very true. Just wish I spent a bit more time checking the fuses. I coulda put that $95 towards more CS parts. That's all I was thinking. Lol.
The Following User Says Thank You to Atticaz For This Useful Post:
CorkSport (08-04-2015)
TPMS code U0127 and ABS code B1318 Z32_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 05-12-2015 06:34 AM
Code P2402 CX-7 2007 turbo egrarzoom CX-7 > Issues & Troubleshooting 5 02-25-2015 09:05 AM
P0401 code just got my mazdaspeed 3 and this code popped up Steezyms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-23-2014 02:20 PM
2007 MS3 Head Unit and HVAC Paint Code billyrohm MazdaSpeed 3/6 - Car Audio & Electronics 2 04-18-2008 05:05 PM
Page generated in 0.24659 seconds with 21 queries
