Miata MX-5
> Miata - General Questions
Like Tree61Likes
 Old 07-23-2014, 06:38 PM   #41
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Yeah, that should be a good time for you. Do you have a press? I recommend putting them in the freezer overnight the day before doing them.
Past Mazdas & Speeds
Chief_Wiggum (07-24-2014)
 Old 07-24-2014, 03:49 PM   #42
Ziggo's Avatar
Posts: 3,843   (View Stats)
I don't have a press, but the 3 jaw puller I got from harbor freight has done a pretty good job of pressing them out. The biggest issues is they tend to get hung up on one side, then go crooked. When I straighten it out it releases the tension on the 3 jaw puller which then likes to fall off.
More junk arrived today. A very necessary rear view mirror to replace the ricey thing that was on there before, not only because it was ricey, but because it was blocking my line of sight. New radiator cap, just cause I don't trust the old one and it was $5 and new steering rack boots.
Ask Me About My:
Code Monkey (07-24-2014)
 Old 07-24-2014, 04:07 PM   #43
The mirror that came with it would be awesome for track use. Unless you are too tall.
Can't believe no one else commented on the splatter painted valve cover.
 Old 07-24-2014, 04:13 PM   #44
Ziggo's Avatar
I am way too tall, and it was not secured well enough or of high enough quality for me to trust it around my head.
The valve cover is.... Special. I like to think of the splatter as rainbow jizz from a unicorn.
Downmented likes this.
Ask Me About My:
The Following 7 Users Say Thank You to Ziggo For This Useful Post:
Downmented (08-27-2014), Easter Bunny (07-24-2014), Pointless (07-29-2014), Pu Manchu (07-26-2014), pzr2874 (07-26-2014), Tomas (11-30-2014), UnknownSuperhero (07-24-2014)
 Old 07-26-2014, 02:22 AM   #45
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
oh, he got plenty of comments on shout, believe me.
and it's a shame the vc won't fit the inevitable 1.8l swap, cause it suits him
The Following User Says Thank You to Pu Manchu For This Useful Post:
Ziggo (07-26-2014)
 Old 07-26-2014, 07:58 AM   #46
Honestly after this picure was posted I want to splatter paint my whole car.
pzr2874 (07-26-2014), Tomas (11-30-2014), Ziggo (07-26-2014)
 Old 07-26-2014, 11:36 AM   #47
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
holy mother of god!
1) that's a ton of work.
2) no way to drink a soda while driving the car afterward unless its in a sippy cup.
3) BTW I did love the VC paint job.
Gangs all here, but goddamn does it look like alot of work. Time to start using an impact on the puller to push bushings out, I didn't realize how many were on the rear.
Also on the to do is to install a zerk on every one of these except the end links and the diff mounts. Then repaint black with rattle can.
pzr2874 likes this.
Ziggo (07-26-2014)
 Old 07-26-2014, 11:53 AM   #48
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Why would you install a zerk on all of them?.... those should outlast your life.... err.... the life of the car.
 Old 07-26-2014, 01:34 PM   #49
Neverlift's Avatar
Groans: 1,143
Without a zerk, it's basically half assing the job. If you damage a part that has the bushing installed, and then need to replace that part, you wont be getting that bushing back out, and you will need find a means of just replacing that bushing. Grease is going to keep them clean, keep water out, and will also keep them from binding. Binding is going to be a bigger problem than squeaking.
pzr2874 (07-26-2014), Ziggo (07-26-2014)
 Old 07-26-2014, 01:38 PM   #50
pzr2874's Avatar
Groans: 146
good point, I was thinking of longevity.
 Old 07-26-2014, 03:47 PM   #51
Ziggo's Avatar
Binding is the reason as I hear it. You want as little resistance in the bushings as you can get to keep the suspension action pure, you want the spring/shock to control the suspension, not hysteresis in the bushing. Regular greasing helps that.
Really I am just copying what (many) others have done before when setting up a track miata
Ask Me About My:
 Old 07-26-2014, 03:53 PM   #52
Ziggo's Avatar
holy mother of god!
Good thing I have a massive collection of sippy cups!
Ask Me About My:
Dano (07-27-2014), Neverlift (07-26-2014)
 Old 07-29-2014, 05:10 PM   #53
Ziggo's Avatar
Just so I don't go too long without doing anything.... Rearview mirror installed.
Also zerk fittings and snazzy caps have arrived.
Ask Me About My:
Code Monkey (07-29-2014)
 Old 07-29-2014, 05:18 PM   #54
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Just spotted this little gem
Miata
Pickles Tune in progress
 Old 07-29-2014, 06:10 PM   #55
Chief_Wiggum's Avatar
Posts: 419   (View Stats)
I was worried for a minute, based on the picture I thought you installed blue led lights in the interior.
The Following 2 Users Say Thank You to Chief_Wiggum For This Useful Post:
Cheapspeed (07-29-2014), Ziggo (07-29-2014)
 Old 07-29-2014, 06:48 PM   #56
Neverlift's Avatar
Groans: 1,143
That steering wheel is hilarious with that lighting.
How many dead hookers would it take to get it from you?
Chief_Wiggum (07-30-2014), Ziggo (07-30-2014)
 Old 07-29-2014, 08:19 PM   #57
Ziggo's Avatar
Potato camera FTL. I swear no leds were used in the making of this picture, aside from the led "flash" from the phone.
Ask Me About My:
 Old 07-30-2014, 08:06 AM   #58
Is that matching glow in the dark paint around the vents as well?
The Following 3 Users Say Thank You to Chief_Wiggum For This Useful Post:
Easter Bunny (07-30-2014), Neverlift (07-30-2014), Pu Manchu (07-30-2014)
 Old 07-30-2014, 08:10 AM   #59
jbmazda6's Avatar
Posts: 1,230   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
Have you taken a blacklight over the interior yet? I bet this guy got a lot of gay man jizz all over it while zipping around town.
In all seriousness this looks like an awesome build in the making.
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline   Reply With Quote
The Following 3 Users Say Thank You to jbmazda6 For This Useful Post:
Easter Bunny (07-30-2014), Neverlift (07-30-2014), Ziggo (07-30-2014)
 Old 07-30-2014, 08:23 AM   #60
Originally Posted by jbmazda6 View Post
Have you taken a blacklight over the interior yet? I bet this guy got a lot of gay man jizz all over it while zipping around town..
It's funny because it's true...
The Following User Says Thank You to Chief_Wiggum For This Useful Post:
Ziggo (07-30-2014)
 Old 07-30-2014, 09:32 AM   #61
Ziggo's Avatar
Thank goodness I don't have a black light. Ignorance is bliss
It doesn't seem to glow with the lights off, but it does match.
Ask Me About My:
Last edited by Ziggo; 07-30-2014 at 09:32 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-15-2014, 08:58 AM   #62
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Ziggo spotted with new paint job
The Following 7 Users Say Thank You to aaronc7 For This Useful Post:
beachshoer (08-15-2014), Chief_Wiggum (08-15-2014), Code Monkey (08-15-2014), Dano (08-15-2014), Downmented (08-27-2014), Easter Bunny (08-15-2014), UnknownSuperhero (08-15-2014)
 Old 08-15-2014, 01:23 PM   #63
Neverlift's Avatar
Groans: 1,143
Funny the bumper doesn't read, Out of Closet, Wife Doesn't Know
 Old 08-26-2014, 06:29 PM   #64
Pu Manchu's Avatar
Groans: 546
bump
94 M
MS6
IS350
Ziggo (08-27-2014)
 Old 08-27-2014, 08:56 AM   #65
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Yummy. Hows the car feel now that you have all the new bushings installed?
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
Ziggo (08-27-2014)
 Old 08-27-2014, 05:26 PM   #66
Ziggo's Avatar
Don't shame me! It's been too hot to be in the garage working recently. Been working lots of overtime though, will help me purchase those xida clubsports I have been ogling
Ask Me About My:
Easter Bunny (09-01-2014), Neverlift (08-28-2014), SpencerC (08-27-2014)
 Old 08-27-2014, 06:05 PM   #67
SpencerC's Avatar
Posts: 2,159   (View Stats)
I'm curious on the bushings too, I should do it to my Miata.
Ziggo (08-27-2014)
 Old 08-30-2014, 09:31 AM   #68
Ziggo's Avatar
Alright, I spent a couple hours in the garage this morning before it got too warm. Chose not to work suspension stuff because I may be able to buy those xida coilovers I have been wanting in the next couple months, so no point to getting too far ahead on the rest of it.
I completed removing the AC system from the car, I had not removed the condenser before. The Evaporator is still in, I will figure that out later. I also took a rag and cleaned up the worst of the grime from the bay, most of which was leaked power steering fluid. Looks like the AC system (minus the evaporator) and power steering system total to 41.5lbs. Not too shabby, but I figure quite a few drivers will weigh 40lbs less than me too, so meh..
Installed the new radiator overflow tank, and the washer fluid pump. I seem to have misplaced the cap for the washer fluid tank though. It will turn up eventually I figure.
Flushed the coolant system twice, it was like mud was coming out the first time, the second it was still cloudy, so I will probably do it one more time. However having the car on that long revealed that the alternator was not charging the battery. So that is my next item to troubleshoot. While the car was warming up I also installed the new boots on the steering rack. Will need to buy some hose to loop the lines to complete it and have it ready to reinstall.
Ask Me About My:
aaronc7 (08-30-2014), Chief_Wiggum (08-30-2014), Easter Bunny (09-01-2014), Mauro_Penguin (08-30-2014), Pu Manchu (08-30-2014), pzr2874 (08-31-2014), smoogs12 (09-01-2014)
 Old 09-01-2014, 12:45 PM   #69
Ziggo's Avatar
I pulled the drivers seat an did a foamectomy on the seat bottom, and pulled the center piece of foam from the seat back. Bolstering is much better now, and I am a a good few inches below the roll bar. Looks like I should be able to make do with just a deep dish steering wheel and a proper rollbar
Ask Me About My:
 Old 09-01-2014, 04:58 PM   #70
Ziggo's Avatar
Well shit. Foamectomy less successful than I initially assumed. Looks like I am going to have to race seat it and drop the floor pan to pass tech. I need another 4" down to pass. I do sit low enough with no seat in the car so I suppose there is still hope.
Ask Me About My:
 Old 09-01-2014, 05:18 PM   #71
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
Race seat and a hard top
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
 Old 09-01-2014, 08:00 PM   #72
I did a foamectomy too and overall disappointed. It helps a little bit but not too much, especially if you want to track the car. Bolting the seats to the floor is the best solution, here is a nice write up by a local track junkie.
 Old 09-01-2014, 08:14 PM   #73
Neverlift's Avatar
Groans: 1,143
That rollbar isn't passing tech anyway chief.
Code Monkey (09-01-2014)
 Old 09-01-2014, 08:46 PM   #74
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Ok I'll bite, WTF is HLA?
Yes, I know it must be something obvious, but I have been drinking good beer since 4pm...
Tomas (11-30-2014)
 Old 09-01-2014, 08:48 PM   #75
aaronc7's Avatar
Groans: 370
Hydraulic lash adjuster. Type of lifter used on NA Miatas.
Tomas (11-30-2014)
 Old 09-01-2014, 08:50 PM   #76
Pu Manchu's Avatar
Groans: 546
since ziggo has tapped out, i assume you're talkin about the hydraulic lash adjusters from very early in this thread
94 M
MS6
IS350
cld12pk2go (09-02-2014)
 Old 09-01-2014, 08:51 PM   #77
Yea looking back on the pics it looks like a painted style bar lol. I'd get a real roll bar before you measure anything.
 Old 09-01-2014, 09:46 PM   #78
Ziggo's Avatar
Well the intention is to take it to MER and have them fab me up a roll bar, plus possibly door bars, but I want a hard/soft top to be able to clear it so I can't raise the bar height much, if any.
Ask Me About My:
 Old 09-01-2014, 11:50 PM   #79
pzr2874's Avatar
Groans: 146
So you're talking about going pro SCCA Chris? Could always give it a season to iron the shit out on the track b4
 Old 09-02-2014, 10:18 AM   #80
SpencerC's Avatar
Helmets man. Take up too much space. Lol. The foamectomy I did on mine didn't help as much as I would have liked either. It was better, but not great.
Ziggo's Miata of the Day Ziggo Miata - Track Cars and Racing 112 07-12-2014 04:12 PM
Ziggo's Boost Tuning Thread Ziggo MazdaSpeed 3/6 - ECU Computer Tuning 192 07-06-2011 01:08 PM
Page generated in 0.57810 seconds with 35 queries
