> [ETS] Extreme Turbo Systems
 Old 12-26-2017, 10:07 AM   #1
diztunde's Avatar
Posts: 2   (View Stats)
diztunde has a little shameless behaviour in the past
Default Overheating and heater issues
My 2008 Mazda 6 heater won't work and the car temp is going through the roof. Someone help please.
Sent from my SM-G950U using Tapatalk
diztunde is offline   Reply With Quote
The Following User Says NO Thank You to diztunde For This Un-useful Post:
sharksinspace (12-27-2017)
 Old 12-26-2017, 10:30 AM   #2
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Has to be a troll ^^^
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
monkey.bones.007 (12-26-2017)
 Old 12-26-2017, 06:53 PM   #3
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Get some matches and gas and make it even hotter!
crapatalk it sucks for free
 Old 12-26-2017, 07:15 PM   #4
diztunde's Avatar
There's something called life, please get one.
 Old 12-26-2017, 07:17 PM   #5
Naw, it's much more fun to troll you and your stupid question.
 Old 12-26-2017, 08:51 PM   #6
drive_sideways's Avatar
Posts: 120   (View Stats)
drive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nice
Your thermostat is stuck shut, you will need a new one, also make sure your car has coolant in it.
Btw a simple google search would have answered your question much quicker.
drive_sideways is offline   Reply With Quote
 Old 12-27-2017, 03:26 AM   #7
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Most probably no coolant.
With the thermostat stuck shut there's plenty of cabin heating because the heater is using the same coolant at the engine. Actually turning the cabin heat all the way up is one way of cooling the engine when the thermostat is stuck shut. Of course, assuming that the heat control works in the center console... because it may be that as well.
On the other hand @diztunde, did you phoken notice where you did phoken post? Wotta phock your (over)heating problem has to do with aftermarket performance parts supplied by ETS?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Last edited by mituc; 12-27-2017 at 03:34 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-27-2017, 07:40 AM   #8
He's also posting about a regular 6 and not a speed. More than likely his water pump is shot, hence no circulating of coolant. He posted on the wrong section, posted about a wrong car, and was generally a twat who won't be back. This is why we can't have nice things.
 Old 12-27-2017, 08:42 AM   #9
Djohns's Avatar
Posts: 3,944   (View Stats)
OP can suck a bag of dicks.
2010 black mica speed3
Soon:built motor
monkey.bones.007 (12-27-2017)
How I solved me power steering overheating issues MATT DAMOND MazdaSpeed 6 - Engine, Transmission & Driveline 20 04-09-2015 05:57 PM
Weird AC/Heater issues tadzooks Gen2 MS3 General Discussion 3 01-24-2014 10:36 PM
HTP 3.5 heater hose wtf tokoam MazdaSpeed 3/6 - Big Turbo Builds 19 01-08-2014 06:58 PM
Gas smell with heater on Deldran Mazdaspeed3/6 General Discussion 40 04-25-2013 03:22 PM
Overheating Issues zlatan MazdaSpeed 3 - Engine, Transmission & Driveline 13 02-19-2012 01:14 AM
Page generated in 0.28954 seconds with 25 queries
