![]() Join Date: Jul 2013
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I have an 08 CX7, the other day while cruising at about 75mph, I lost what felt like the turbo? I went to pass a car and stepped on it and it was like the car had an anchor. No power. The engine started making and intermittent "howling" sound within minutes. Now it " howls" from about 1800rpm to around 2200rpm all of the time, but still no power. I can ( probably shouldn't) drive it and get up to highway speed , but it has hardly no acceleration. It's a VERY slow climb to speed. I've had some say it's the belt tensioner making the noise, but it doesn't explain the drop in power. I'm looking for ideas. I'm stumped. I'm a motor head ... but I'm an old school motor head. Not a tuner....yet THANKS for any help! |
![]() Join Date: Apr 2011 Location: Boynton Beach FL/Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,007
Groaned at 64 Times in 49 Posts
| Not Ranked : 0 score Sounds like a boost leak. Check either your intake, or tubes leading to the intercooler.
__________________ Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq. #HAR Hidden Agendas Racing |
(Thread Starter) | Not Ranked : 0 score Checked out both intercooler tubes, both OK. I used a buddies code reader and I got a P0101 for the MAF or VAF and then got a P0401 for the EGR valve. I guess I'll keep checking lines and clean the EGR. ANY other ideas would be great.
__________________ 2008 CX7 Sport, BONE STOCK...for now. |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score does it howl only while on the gas? does it how constantly with wheel speed? either you missed a boost leak (wastegate, boost control solenoid).. or something like the pto took a dump.
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following User Says Thank You to m4tic For This Useful Post: | Payne Racing 67 (07-25-2013) |
| Not Ranked : 0 score Did you check your intake? Where it connects to the turbo? That will affect MAF, and because it throws everything off, could cause the egr code as well Sent from your moms phone
![]() Join Date: Oct 2016
| Not Ranked : 0 score I am having exactly the same issue. Dealer is asking to replace catalytic converter ..they are saying $2K for the replacement. |
| Loss of power at WOT | Speeden6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 49 | 04-09-2012 09:48 PM |
| WTF power loss and mpg loss | ztnedman1 | Gen2 MS3 General Discussion | 10 | 11-07-2011 07:26 PM |
| Loss power | kao_lor | Mazdaspeed3/6 General Discussion | 13 | 04-15-2011 01:43 PM |
| New to me MS3 08.5 Power Loss | rtabagaboy | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 31 | 10-17-2009 01:22 PM |
| Loss of Power | mleblond | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 09-03-2009 07:16 AM |
