> CX-7 > Issues & Troubleshooting
 Old 08-18-2015, 05:03 PM   #1
DrewFlu33's Avatar
Posts: 16   (View Stats)
DrewFlu33 will become famous soon enoughDrewFlu33 will become famous soon enough
Default A/C Compressor Drain Location?
I've got water all on my passenger side floorboard, and water sloshing around under my console. I'm sure that the drain for the A/C compressor is clogged, but can't find the damn thing! Anybody know where it is?
DrewFlu33 is offline   Reply With Quote
 Old 08-18-2015, 08:35 PM   #2
lildisco's Avatar
Posts: 332   (View Stats)
lildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond repute
On the cx9 its behind the heat shield right around where the exhaust turns to heads towards the back of the car. Roughly where your feet would be inside the car.
I'd imagine that the cx7 is roughly in the same spot
Cooper Red Mica 2008 CX7 AWD GT w/Nav
K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors
Originally Posted by TopGear Magazine
This is a good car, a fine family SUV that will serve you well, if unremarkably. It's on sale from 18 May, and its arrival signals the phasing out of the larger CX-7, like the 2 supermini, one of Mazda's underrated, underappreciated cars. Let's hope the CX-5 avoids the same fate. It deserves to.
Tuned with
lildisco is offline   Reply With Quote
 Old 08-19-2015, 05:55 AM   #3
silentdoer's Avatar
Posts: 64   (View Stats)
silentdoer will become famous soon enough
Groaned at 4 Times in 1 Post
It's definitely caused by a clogged A/C drain.
silentdoer is offline   Reply With Quote
 Old 08-19-2015, 05:16 PM   #4
DrewFlu33's Avatar
Thanks for the replies. I was able to find a lot of pictures and info about where it's located on the CX-9, but never the CX-7. Luckily I happened upon the mythical compressor drain. It turns out it's a completely different location than the CX-9. It also turns out you don't have to get the car up in the air to unclog it, which is good to know for the future.
I took a picture in case anyone else ever has the issue. It's located on the firewall on the passenger side and does not look like a drain tube at all. I honestly thought it looked like a metal piece of some kind before touching it. The shape resembles the end of a sway bar that extends past where it bolts to the frame--like crimped metal or something. Rest assured, it's rubber. This photo is taken standing right at the passenger wheel well looking down behind the motor towards the firewall. Apologies for the refrigerant line obstructing the view, but notice the water pouring out!
There was over a gallon of water that came out. I shoved a stiff wire in it first and got it to flow, then for good measure stuck the end of a shop vac hose on it. It sealed nicely against the firewall and I think pulled some additional gunk out of the drain line. Now to find a shop that has cabin air filters in stock....
 Old 10-04-2017, 08:50 AM   #5
45rpm's Avatar
Posts: 1   (View Stats)
45rpm is an unknown quantity at this point
Thanks Drew. I am having the same problem you are. How long of a wire did you use? Thanks...
45rpm is offline   Reply With Quote
 Old 10-30-2019, 07:31 PM   #6
HenryMen's Avatar
Posts: 2   (View Stats)
HenryMen is an unknown quantity at this point
Default смотреть сериал бандитский петербург в хорошем качестве
Всем привет! прикольный у вас сайт!
Нашел хорошую базу кино: Новые фильмы онлайн
Тут: Лучшие военные фильмы бесплатно лучшие советские военные фильмы смотреть онлайн список 2018
Здесь: смотреть фильмы онлайн в хорошем 2019 боевики лучшие боевики онлайн рейтинг 2019
Здесь: ?? ????? / In the Flesh (????? 1-2) (2013-2014) ???????? ?????? ????????? Во плоти / In the Flesh (Сезон 1-2) (2013-2014) смотреть онлайн бесплатно
Здесь: ???? ??????? ??????? ??????? ???? ? ???????? ???????? "????" ???????? ?????? ?????????
кино онлайн 2019 бесплатно в хорошем боевик http://kinofanonline.net/boevik/ рейтинг 2018
HenryMen is offline   Reply With Quote
Battery drain G26 2010 MS3 - Troubleshoot/Diagnostics 14 08-14-2012 04:21 AM
Drain easily our OCC Atomic41 Mazdaspeed3/6 General Discussion 36 06-29-2012 02:18 PM
How often do you drain your OCC? Oswald MazdaSpeed 3 - Engine, Transmission & Driveline 2 12-31-2010 11:54 PM
Page generated in 0.27296 seconds with 24 queries
