> CX-7 > Issues & Troubleshooting
 Old 07-23-2018, 11:59 AM   #1
DRHaulsee's Avatar
Posts: 4   (View Stats)
DRHaulsee will become famous soon enough
Default Chasing a potential Bad Injector
My 2009 CX7(100,000 miles) posted a cylinder 4 misfire code several weeks ago. At the same time the dreaded timing chain rattle started. So, I ordered the parts and did the timing chain and VVT. Yes, the VVT was bad and the timing chain had just started to rub on the cover. It runs fine except the cylinder 4 misfire became more common. This misfire happens on cold start but disappears as the engine warms. I can reset the codes once it is warm and it doesn't come back until the next cold start.
I did new plugs with no change. Moved plugs around but the misfire stayed on cylinder 4. Swapped coil packs around but the misfire stayed on #4 . I bit the bullet and bought Cork Sport injector seals. When I took it apart there were no obvious signs of leaking injector seals.
When I reassembled it I moved the injectors around. #3 went to 1, #4 went to #2 , #1 went to #3 , and #2 went to #4 . Now I have a misfire on #2 . That tends to make me believe the #4 (now #2 ) injector is somehow "bad".
Have I missed something? How does a bad injector have this cold start behavior?
Oh, and I want to thank the posters here for the excellent write ups on the site. I've spent many hours reading through them.
DRHaulsee is offline   Reply With Quote
Chasing a Rattle Ezekiel81923 2010 MS3 - Suspension & Brakes 2 06-20-2018 07:45 AM
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Chasing Whoosh... dadasracecar MazdaSpeed 3/6 - Appearance 12 08-22-2013 06:36 AM
Page generated in 0.22881 seconds with 20 queries
