> CX-7 > Issues & Troubleshooting
 Old 08-20-2019, 10:12 PM   #1
budgiee's Avatar
Posts: 5   (View Stats)
budgiee will become famous soon enoughbudgiee will become famous soon enough
Default cx-7 all dash lights on and stopped
Hey everyone!
Was hoping that this wouldn't be my first post in this area but hey here it goes!
So the missis CX-7 had an issue today she was taking off from a set of lights normal acceleration and she said all the dash lights came on with the needles going up and down then a clunk and the engine stopped she had enough time to pull over, she then started it again to drive to the servo in a safer area 100m down the road and it did it again.
i met up with her and she took the fourby and our 3month old home, i jumped in the Mazda drive it home with out any dramas, giving it a good right foot under load up hills ect and didn't skip a beat!
My first thought was maybe the alternator is not charging, battery was replaced about 3 months ago, i checked alternator with multi meter and battery and there is no issue with the charging side of things. servicing is always done on time
any help would be appreciated
Thanks,
Budgiee
budgiee is offline   Reply With Quote
 Old 08-20-2019, 10:36 PM   #2
Police - Grammarhead
Vansquish's Avatar
How are the battery leads? I've seen similar behavior when the leads aren't properly connected to the battery terminals.
budgiee (08-20-2019)
 Old 08-20-2019, 10:53 PM   #3
budgiee's Avatar
Hey Vansquish,
The battery leads are fine just double checked they have good connection the crimps are still good and all earth leads are nice and tight!
The Following User Says Thank You to budgiee For This Useful Post:
Vansquish (08-21-2019)
 Old 08-22-2019, 06:10 PM   #4
budgiee's Avatar
Ok so I think its definitely a power issue. Battery or alternator. I test drove it to work thismorning with a live code reader plugged in aswell. Same thing happened 3 times but the engine never stopped. Just dash lights and radio would turn off and on then all warning lights.
And when I made it to work put the window up once it reached the top dash lights went out.
Maybe battery dropped a cell?? I'll load test the battery again tonight.
 Old 08-23-2019, 02:19 AM   #5
budgiee's Avatar
So just an update. I did a load test on the battery and showed up weak. Took the car where I got the battery from they did a test. And faulty battery was reading 348cca and the battery is rated at 600. So I think that the new battery has dropped a cell
Vansquish (08-23-2019)
What causes the DSC, ABS and the skidmark dash lights tripped at the same time? Marcus MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-05-2014 03:49 PM
Dash lights joewarner 2010 MS3 - Troubleshoot/Diagnostics 6 09-07-2013 11:48 PM
Dash lights looks like xmas CruZ_MS6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 02-17-2012 03:22 PM
dash lights Toms_speed6 MazdaSpeed 3/6 - Car Audio & Electronics 6 02-06-2011 10:32 PM
two indicator lights on the dash 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 7 03-31-2009 07:14 PM
Page generated in 0.28704 seconds with 21 queries
