> CX-7 > Issues & Troubleshooting
View Poll Results: Sky-Activ or Rotary ?
Sky Activ 0 0%
Rotary 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
 Old 02-18-2017, 02:52 AM   #1
black_cx7's Avatar
Posts: 1   (View Stats)
black_cx7 is an unknown quantity at this point
Unhappy CX-7 shuts off after idling/driving 30 min
hello to all. My '08 CX-7 2.3L turbo has an issue that causes the vehicle to lose power and shut off after only approximately 30-45 minutes of driving (even at highway speeds) or simply idling. In addition, it may take approx. another 2-3 hours for the car to start again inorder to drive another 30-45min. before repeating the same issue. If you try to restart right after it shuts off, it just keeps turning but not start. Oddly, you have to wait atleast 30 min to successfully start the CX-7 again and even then you would only be able to drive for approx 5-10 minutes before shutting off once again.
A bit of background:
- Motor has just had a head & valve job by local mechanic and machine shop.
- In addition to the headjob and after informing the mechanic about the issue, fuel pump, fuel injectors, thermostat, radiator, intercooler as well as sparkplugs have been replaced.
Any Suggestions Out There. PLEASE HELP !!! Not sure what can be the problem: pcm, reprogramming, relay, electrical ?
Also, here's another fun-fact. The radiator fan is no longer switching on, even at +190F. Although it used to work properly when the head/valvejob was first completed (the 1st day), it now seems like the are not functioning.
black_cx7 is offline   Reply With Quote
Idling issues with datalogs h0rsies MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 10-22-2014 04:11 PM
Weird idling issue Mandinca Mazdaspeed3/6 General Discussion 12 07-22-2014 05:02 PM
Does this idling sound normal? mrQQ MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 02-28-2014 01:06 PM
Why would VVT jump to 8 degrees idling? mrQQ Mazdaspeed3/6 General Discussion 11 02-25-2014 10:52 AM
Strange idling after HTP 3.5 install Redline143 2010 MS3 - ECU Computer Tuning 80 01-11-2013 09:34 AM
Page generated in 0.23267 seconds with 21 queries
