![]() Join Date: Mar 2010 Location: Lewistown, PA (State College)
Rep Power: 1938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,144
(Thread Starter) | Not Ranked : 0 score My only thoughts are that the starter is taking a dump or the electrical connections to the starter are corroded. Anybody experience anything like this on their CX/MS3/MS6? I remember reading that the speeds sometimes have the corrosion on the terminals, but I didn't know if there was any CX7 specific advice.
__________________ 2010 MS3 - Sold 2015 CX-5 GT AWD - Current ![]() |
![]() Join Date: May 2012
Rep Power: 0 ![]() ![]() Thanks: 6
| Not Ranked : 0 score You could try checking to see if the cut off switch from the remote start is not staying engaged even after alarm is deactivated , had similar problem with my friend cx7. He ended up buying a new one. Hope this helps! |
| Not Ranked : 0 score purge valve. |
![]() Join Date: Jul 2013
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score My CX-7 will not start after being driven for a while and brought up to temperature , once I shut it off the lights etc still work but no cranking , just a very faint click , wait 15 minutes and it starts right up .... very frustrating .... any suggestions on what to check , cleaned the battery terminals but no help .... Thanks |
| Car won't start... | ahfunaki | Gen2 MS3 General Discussion | 17 | 03-29-2012 10:48 AM |
| where to start | jlaudioman18 | Mazdaspeed3/6 General Discussion | 4 | 12-20-2011 07:24 AM |
| Car won't Start | funka09 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 06-30-2011 12:17 PM |
| If you could start over | Whiteboy | Mazdaspeed3/6 General Discussion | 28 | 02-14-2011 06:29 PM |
| Let's Start Getting Some CX-7's Over Here! | rexrzer | CX-7 > General Lounge + New Member Welcome | 28 | 11-08-2010 02:19 PM |
