![]() Join Date: Mar 2017
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score New timing chain, tensioner, high pressure injection pump, phasers, and turbo. Let us know what you think. https://www.youtube.com/watch?v=xcjPWd-33EE |
Groans: 211
| Not Ranked : 0 score oooh, phasers! I want those on my car! really hard to say without knowing more. any CEL's?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
(Thread Starter) | Not Ranked : 0 score No CELs. Nothing that would help us lead to what's causing this noise. Car runs well. Only problem is this noise. Only does it when starting the engine ONCE and then when revving sharply between 2-3k rpm. We've tried pinpointing the noise with an electronic stethoscope and still not able to tell. Took out spark plugs one at a time with engine running to see if the noise in the piston would change. Made no difference. |
Groans: 211
| Not Ranked : 0 score Just watched your YouTube vid. That sounds awful! It has a complete miss. Timing? Who did the work? Take it back!
![]() Join Date: Feb 2012 Location: Cleveland, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score It looks like the engine is moving when the noise happens as well. Have you looked at your motor mounts?
__________________ Cooper Red Mica 2008 CX7 AWD GT w/Nav K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors ![]()
Groans: 211
OP, did you do the VVT work yourself? Perhaps you forgot to connect something or its loose.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| Not Ranked : 0 score Yes some movement is normal, but the engine moving & the noise is happening at the same time. There's something in common there.
| Steering wheel popping/clicking feel/noise | Absolut1l | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 04-04-2015 09:48 AM |
| Popping noise from Speaker on startup | rastlun | 2010 MS3 - Troubleshoot/Diagnostics | 13 | 05-30-2013 05:54 PM |
| Light Clunking/Popping noise after shifting | wrennels | 2010 MS3 - Engine, Transmission & Driveline | 0 | 11-13-2012 06:23 AM |
| Stereo makes popping noise when I hit the brakes. | Vansquish | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 10-01-2009 09:11 AM |
