![]() Join Date: Dec 2016
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Car runs fine starts fine no smoke or issues to notice except get overfull on oil. The plugs all looked ok put in new while out. Color was good. I am not that familiar with high pressure gas fuel injection, is it possible the lower compression cyl is letting that much gas past the rings?? My only other thought now is INJ? I am a diesel truck mechanic for many years. Thanks for any help that may be out there. Seems when I try to research nothing comes up. Last note car is all stock. |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Are you sure its fuel thats getting in the oil (did you smell it)? The only way fuel can get in the oil is by the cam side of the HPFP and pass the piston ring (like you stated) HPFP is out of the equation since you changed it...piston 3 is only left option...unless its not fuel that gets in the oil! Coolant may get in the oil if the head gasket is worn out...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
(Thread Starter) | Not Ranked : 0 score definetly gas. coolant level is steady. I dumped 10 qts at work and passed the oil dump later, yes it is gas. So it is feasibley the lower compression cylinder? I was afraid of that. Since it came up with oil not a valve issue. rather costly changing oil every 1500 miles. |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score This engine is known to have a lot of fuel washdown and oil dilution, but a quart high in 1000 miles is a problem of a whole other magnitude. I'd have to imagine the oil film is not that great even after a few hundred miles with that degree of dilution. Is the PCV system operating correctly? What does the usage of the car look like, is it 1000 miles that takes a year to accumulate at 5 miles a day or something? Where are you located? Arizona vs. Alaska might make a difference too.
__________________ 2013 'speed3, silver Stage Bro |
| Not Ranked : 0 score Did you change the whole HPFP or just the o-ring? New or rebuilt pump? Ill check on the forum if low compression in one cylinder can have this much of an effect on the oïl level!
| Not Ranked : 0 score Could'nt find a link to heavy fuel dilution because of low compression in one cylinder...a bad screw-seal in the HPFP is the most probable cause...
(Thread Starter) | Not Ranked : 0 score wife drives to work about 5 miles round trip. Central Minnesota for weather. It is was a new hpfp fuel pump I installed. need to decide if I fix or get it gone? Trouble is owe too much. How are the 6 cylinders in cx9? We have had the car 1 1/2 years and seems to be getting worse. Much worse than cold operation. Alright I just went out and checked when we I had the 1000 mile number we had made some longer trips like 1 hour one way. took 1000 miles to make the oil. I just went out and verified, 1-19-17 changed oil and filter at 88944 now at 89029 I am at least 1/2 inch over the full mark on dipstick. I am careful to check it the same each time, cold, wipe stick and recheck level. So that said only 85 miles in town and it is over full . I put in about 5 1/2 quarts of a little better with filter. was careful to be on the full mark not over at change. Yes it smells of gas. Appreciate the input |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
If you can’t... keep the OCI at 3k and use something like Rotella T6... it helps.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// Last edited by Yatta; 02-10-2017 at 02:09 PM. Reason: added ‘If you can’t' | |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score Fuel dilution tends to be worse on DI gasoline engines. I guess you need to get the oil up normal operating temp for the fuel to flash off. At least take it onto the highway once a week for at least 15 minutes.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Yatta (02-10-2017) |
If she's got that short a daily drive, you changed the oil 1/19 (22 days ago), and you're a half quart high then it sounds like you get nearly as much gasoline in the oil as you burn running the damn thing.
__________________ 2013 'speed3, silver Stage Bro | |
(Thread Starter) | Not Ranked : 0 score I know cold running is an issue but she has never driven more than 2 1/2 miles to work for any job for a lotta years and a number of vehicles. This is worse than cold running. she has instructions to use the auto start and has been. I drove it for a week and ran it hard, manually shifted etc ran higher rpm to get it warmed up. May be my imagination but I think that was actually worse! It was like if I kept the inj pressure higher it made issue worse. Next step I guess is to try a bore scope in cylinder. Are these aluminum cylinders? May have had an injector injecting too much and washed cylinder wall? |
(Thread Starter) | Not Ranked : 0 score Used bore scope today inconclusive. Hard to see any real issues. Used a smoke tester to try and determine where compression is going. It is going to crankcase. using the flow meter and pressure diffrential changes. # 3 has the least pressure change and the highest flow when tested. Also the smoke from the oil fill streams out more than the other cylinders. Changed oil again. will drive about 140 mile tomorrow, sunday, see what happens. thanks for letting me vent! Still not sure how to fix. Or if i will fix... |
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// | |
Groans: 211
| Not Ranked : 0 score Here is what you need to do. Remove the hex plug on the side of the fuel pump. Does fuel spill out? Bad screw seal o-ring. New pump or not, that is the issue. No fuel spills out? Possible leaky fuel injector after motor is off. Start the car and run for a short time. No need to come up to temp. Immediately pull the plugs and see which one is wet with fuel. Or use your bore scope to look around. I have the screw seal O-rings or Wes3id has an entire rebuild kit. just do a search for HPFP rebuild kit.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
(Thread Starter) | Not Ranked : 0 score thanks for additional ideas. hopefully new pump is ok. i have wondered on injectors. But it does start fine and as I say that it did stutter today when i started it. stumbled on start had to crank again slightly longer crank? |
