Mazdaspeed Forums
-   CX-7 > Issues & Troubleshooting (http://www.mazdaspeedforum.org/forum/forum/f518/)
-   -   P0421 & Spark Plug fouler (http://www.mazdaspeedforum.org/forum/forum/f518/p0421-spark-plug-fouler-223176/)
redboat 11-24-2019 05:59 PM
2010 CX-7 2.3L, code P0421.
I used spark plug fouler in 2nd O2 sensor. Now getting P0137 & P0139.
Maybe i damaged the sensor when reinstalling with fouler? or Fouler is too long?
SSinstaller 11-24-2019 11:08 PM
Remove the anti fouler. If your new Mils go away and you only have p0420, you can fix it with a diode on the signal lead of the sensor.
Jeff23spl 11-25-2019 02:18 PM
Quote:
do you have a diagram and more details about this ?
SSinstaller 11-26-2019 09:16 PM
Nope. But did it on my ms6 for over a year. Rear o2 has 4 wires, two are for the heater, one is reference votage, and one is the signal to the ecm.
Cut the signal wire and splice in a diode with the stripe away from the sensor, it drops the voltage just enough for the p0420 mil to turn off.
Jeff23spl 11-27-2019 07:10 AM
a standard black diode with a silver stripe or a zener model ?
SSinstaller 11-27-2019 06:30 PM
Standard black diode.
Page generated in 0.16877 seconds with 11 queries
