> CX-7 > Issues & Troubleshooting
 Old 11-24-2019, 05:59 PM   #1
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
Exclamation P0421 & Spark Plug fouler
2010 CX-7 2.3L, code P0421.
I used spark plug fouler in 2nd O2 sensor. Now getting P0137 & P0139.
Maybe i damaged the sensor when reinstalling with fouler? or Fouler is too long?
redboat is offline   Reply With Quote
 Old 11-24-2019, 11:08 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Remove the anti fouler. If your new Mils go away and you only have p0420, you can fix it with a diode on the signal lead of the sensor.
The Following User Says Thank You to SSinstaller For This Useful Post:
redboat (11-25-2019)
 Old 11-25-2019, 02:18 PM   #3
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
do you have a diagram and more details about this ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 11-26-2019, 09:16 PM   #4
Groans: 60
Nope. But did it on my ms6 for over a year. Rear o2 has 4 wires, two are for the heater, one is reference votage, and one is the signal to the ecm.
Cut the signal wire and splice in a diode with the stripe away from the sensor, it drops the voltage just enough for the p0420 mil to turn off.
 Old 11-27-2019, 07:10 AM   #5
Jeff23spl's Avatar
a standard black diode with a silver stripe or a zener model ?
Wife drive 2010 CX7
 Old 11-27-2019, 06:30 PM   #6
Groans: 60
Standard black diode.
Jeff23spl (11-28-2019)
Can someone help me with Spark Plug gap? Hapa88 Mazdaspeed3/6 General Discussion 67 10-08-2019 10:22 PM
Cylinder One Spark Plug Fouling - Oil on Plug Thread - Slow Start conrad51 2010 MS3 - Troubleshoot/Diagnostics 8 11-15-2016 05:37 AM
Spark plug gap? Sasha23 2010 MS3 - Engine, Transmission & Driveline 6 06-28-2014 01:19 PM
spark plug blackwidow Custom Performance Engineering (cp-e.com) 12 03-07-2011 04:08 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
Page generated in 0.26000 seconds with 22 queries
