![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
(Thread Starter) | Not Ranked : 0 score I used spark plug fouler in 2nd O2 sensor. Now getting P0137 & P0139. Maybe i damaged the sensor when reinstalling with fouler? or Fouler is too long? |
Groans: 60
| Not Ranked : 0 score Remove the anti fouler. If your new Mils go away and you only have p0420, you can fix it with a diode on the signal lead of the sensor.
| The Following User Says Thank You to SSinstaller For This Useful Post: | redboat (11-25-2019) |
| Not Ranked : 0 score do you have a diagram and more details about this ?
Groans: 60
| Not Ranked : 0 score Nope. But did it on my ms6 for over a year. Rear o2 has 4 wires, two are for the heater, one is reference votage, and one is the signal to the ecm. Cut the signal wire and splice in a diode with the stripe away from the sensor, it drops the voltage just enough for the p0420 mil to turn off.
| Not Ranked : 0 score a standard black diode with a silver stripe or a zener model ?
Groans: 60
| Not Ranked : 0 score Standard black diode.
| The Following User Says Thank You to SSinstaller For This Useful Post: | Jeff23spl (11-28-2019) |
| Display Modes | |
| Can someone help me with Spark Plug gap? | Hapa88 | Mazdaspeed3/6 General Discussion | 67 | 10-08-2019 10:22 PM |
| Cylinder One Spark Plug Fouling - Oil on Plug Thread - Slow Start | conrad51 | 2010 MS3 - Troubleshoot/Diagnostics | 8 | 11-15-2016 05:37 AM |
| Spark plug gap? | Sasha23 | 2010 MS3 - Engine, Transmission & Driveline | 6 | 06-28-2014 01:19 PM |
| spark plug | blackwidow | Custom Performance Engineering (cp-e.com) | 12 | 03-07-2011 04:08 PM |
| Spark plug gap | Jesse MS3GT | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 03-16-2008 04:53 PM |
