> CX-7 > Issues & Troubleshooting
 Old 08-29-2018, 08:25 AM   #1
zaclaw's Avatar
Posts: 14   (View Stats)
zaclaw will become famous soon enough
Default P2088 DTC
2007 CX-7 AWD Grand Touring. I've been chasing this issue for a while to no avail. After having the engine replaced w/ a brand new OEM long block (w/ turbocharger, VVT actuator & other miscellaneous parts), a P2088 code (camshaft position "A", camshaft shaft position actuator control circuit low, bank 1) appeared. This code appears immediately, even after clearing it. Even before the engine is cranked. Always immediately returns. After a short while, the code is always succeeded by a P0012 code (camshaft position "A", timing over-retarded, bank 1). All steps in the Mazda diagnosis flow chart have been performed.
Experiencing loss of power (especially low-end torque) and poor fuel economy. It seems the intake VVT is not advancing because of the OCV not operating.
Replaced VVT actuator (twice)
Replaced OCV
Replaced PCM (twice)
Checked power circuit for voltage from main relay
Checked ground circuit for resistance from OCV to PCM
Checked connectors for damage/corrosion
No detectable issues with any of the above components. Seemingly no logical reason for this DTC to be triggered.
It appears to be an electrical fault, not mechanical, being that the code returns immediately before even starting the engine. No other related issues with the vehicle. It seems P0012 is caused by the P2088 issue.
Mods:
Mazdaspeed6 long block
Corksport turbocharger
Corksport 3bar MAP sensor
Corksport turbo inlet pipe
Corksport stage II SRI
VersaTune (base tune w/ MAP calibration)
2007 Mazda CX-7 Grand Touring AWD 2.3L 6AT - Electric Blue Metallic
CorkSport Turbocharger / CorkSport 3.5 Bar MAP Sensor / CorkSport Stage II Power Series Short Ram Intake / CorkSport Turbo Inlet Pipe / VersaTune / Yokohama Avid Ascend 235/60R18
zaclaw is offline   Reply With Quote
P0012, P0016 and P2088 mituc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 08-18-2017 04:13 PM
P2088 Code FatSauze CX-7 > Issues & Troubleshooting 1 04-27-2015 08:44 PM
P2088 after DP Install - Plz Help! drenkel MazdaSpeed 3 - Engine, Transmission & Driveline 8 10-17-2012 04:12 PM
P2088 code sallyspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 06-11-2012 07:20 PM
Gurus Plz Help - P2088 - Dont Understand drenkel Gen2 MS3 General Discussion 2 02-24-2012 09:11 PM
Page generated in 0.22513 seconds with 20 queries
