> CX-7 > Issues & Troubleshooting
  • 1 Post By djblast45
 Old 09-02-2016, 05:38 PM   #1
djblast45's Avatar
Posts: 4   (View Stats)
djblast45 is an unknown quantity at this point
Exclamation Starter not working after replacing head
i just finished replacing the head on my 2007 Mazda cx-7, went to start it and nothing, the starter isn't even trying to turn, I've checked relays, checked battery voltage, and gone over the wire looms. i never touched the starter or its connections so i am a bit confused, the battery was out of the car for around 3 weeks, when i turn the key to on the check engine light is on solid then for a few seconds it will flash then go solid again. The TCS and DCS lights are also on. Any ideas why the starter wont work?, i have no idea considering it worked fine before i replaced the head
djblast45 is offline   Reply With Quote
 Old 09-02-2016, 05:54 PM   #2
blackms3_71's Avatar
Posts: 2,250   (View Stats)
the harness on the left side of the motor(if you are looking at them motor) runs down under the intake mani and to the starter, there is a signal wire that is know to cause issues, wiggle that around and I bet she starts right up
 Old 09-02-2016, 07:17 PM   #3
djblast45's Avatar
i tried to wiggle around any connectors i saw on the left side near the intake, there was a big grey one and a little grey connector, i even messed with a few other connectors on the harness, but no luck, is it on the same part of the loom where the injectors plug in? would you possibly be able to provide a picture or reference to where or what connector it is? there are so many lol, im just afraid because i need it done yesterday and if i take it to a dealership they could end up telling me i need a new harness or something and charge me a huge amount when i dont need it
 Old 09-02-2016, 07:48 PM   #4
look up location of starter signal wire. that is the wire I am talking about
 Old 09-03-2016, 11:03 AM   #5
lildisco's Avatar
Posts: 332   (View Stats)
lildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond repute
When i was installing my OCC there was 1 tiny wire on the front of the engine that was knocked loose that wouldn't engage the starter. It's been a few years, but i believe the connector was sitting on a circular part on the front of the engine, slightly off center, favoring the passenger side. It was a single wire that was slightly loose that wouldn't allow my car to start. Assuming it's the starter solenoid.
Cooper Red Mica 2008 CX7 AWD GT w/Nav
K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors
Originally Posted by TopGear Magazine
This is a good car, a fine family SUV that will serve you well, if unremarkably. It's on sale from 18 May, and its arrival signals the phasing out of the larger CX-7, like the 2 supermini, one of Mazda's underrated, underappreciated cars. Let's hope the CX-5 avoids the same fate. It deserves to.
Tuned with
lildisco is offline   Reply With Quote
 Old 09-03-2016, 01:20 PM   #6
Omg. Lets just repeat the same shit over and over.
 Old 09-03-2016, 08:14 PM   #7
lildisco's Avatar
Did your tampon fall out? Eat a snickers & chill.
I was trying to help him get a better idea of where to look other than 'Google it'.
This is also under the CX-7 section if you weren't aware
Tuned with
 Old 09-03-2016, 08:19 PM   #8
of i get it but it isnt hard to find the wire. locate starter and then there are only 2 wires, power and signal wire
 Old 09-03-2016, 09:40 PM   #9
djblast45's Avatar
Well the engine bay is a bit tight so it's hard to reach everything, either way, I messed with a couple connectors around the engine and it started fine, thanks for the help guys
Thanks man, I appreciate you trying to give me more info
lildisco likes this.
Last edited by djblast45; 09-03-2016 at 09:40 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-04-2016, 11:07 AM   #10
i bet it was the signal wire, u are going to want to pull it off and clean the contacts on the starter and put some di grease. thats what i did and no more issues to report.
Replacing head need torque spec jerrodraven MazdaSpeed 6 - Engine, Transmission & Driveline 1 05-15-2015 06:42 PM
Questions about replacing head unit mpetruzz 2010 MS3 - Car Audio & Electronics 5 06-04-2014 02:38 PM
Alternative to replacing your head unit! narezzaspeed3 Interior 20 02-09-2013 10:30 AM
Replacing Head Unit j3d CX-7 > Car Audio & Electronics 7 07-20-2012 06:14 PM
Page generated in 0.29385 seconds with 22 queries
