> CX-7 > Issues & Troubleshooting
 Old 02-20-2013, 08:50 PM   #1
mrbrace's Avatar
Posts: 14   (View Stats)
mrbrace will become famous soon enough
Default U0073 U0101 P2187 Check Engine Light ??
I had to dealership do all the latest PCM flash updates to the Mazda CX-7 on Monday, it appeared that after that the check engine light disappeared and all was well. Running some errands later that day the light re-appearing and now getting the codes as listed above.
I know what the P2187 code is but now I need to determine if the high pressure fuel pump is messed up or if its something more simple than that. I had the dealership we bought it from run a smoke machine through the vacuum lines to see if there are any leaks and they could not find any.
Anyone have any thoughts on this? Also, I am not sure what the other codes are related too.
mrbrace is offline   Reply With Quote
 Old 03-02-2013, 11:59 AM   #2
mrbrace's Avatar
So in more research I noticed last night I gunned the accelerator and the check engine light went off magically and has yet to return..I am thinking of cleaning the MAF sensor and the throttle body for a build up of gunk possibly causing the CEL to come on....stay tuned (no pun intended)
 Old 03-21-2017, 04:21 PM   #3
Daniel Freeman's Avatar
Posts: 1   (View Stats)
Daniel Freeman is an unknown quantity at this point
Default code u0073 and u0101
Hi, I'm new to the forums and have some questions but first let me say hello.
Hello!
I live in upstate New York and am on my 3rd Mazda. I've had great experiences with all three and owned one since 1998. I have a protege, had a mazda6 wagon that was a champ for our family and currently have a 2010 CX-9 that I loved right up until Friday. I've been watching the forums for a while and finally decided to join. Glad to be a part of it and hopefully I'll be an asset soon but I'm afraid I'm going to be a bit of a burden first, sorry bout that.
Sequence of events with the CX-9 goes like this:
- Was running flawlessly thursday, no issues.
- Had a state inspection done friday, passed emissions but failed for tie rod end.
- next day started seeing BSM off warning light flash.
- had the tie rod ends replaced and new sticker now in windshield.
- same day AT warning came on. Stuck in 3rd gear.
- wife limped the car home and when I went to investigate I couldn't reproduce the issue and the car ran fine.
- Next day go to head to work and AT light is on, Brake warning light is on, check engine light is on, TCS off is flashing, BSM off is flashing.
- CEL codes u0073, u0101, u1010, P0463 and 10 MIL codes, everything from catalyst, 02 sensor, evap misfire and more.
- enigine sounds fine though. purrs like a kitten.
Looks electrical to me. I assume not everything failed in one day. Looked through the forums but didn't see anything as extensive as this.
I'm Guessing but perhaps the BCM failed?
Thanks in advanced for any help you can provide.
Daniel Freeman is offline   Reply With Quote
 Old 07-21-2017, 05:37 PM   #4
ProjectMS6's Avatar
Posts: 8   (View Stats)
ProjectMS6 is on a distinguished road
Happened to me i cleaned maf and o2 and was good to go reset and go for a test drive
ProjectMS6 is offline   Reply With Quote
Check engine light came on after 7 months with light mods SwizzleSpd MazdaSpeed 3/6 - Turbo Induction 10 01-03-2013 05:15 PM
Check Engine Light gotboost MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 12-03-2012 05:37 AM
engine idle and check engine light msalva2 MazdaSpeed 3 - Engine, Transmission & Driveline 35 07-25-2012 04:48 PM
Check Engine Light rdfr14 2010 MS3 - Troubleshoot/Diagnostics 2 06-17-2010 04:08 PM
Check Engine Light is on armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 9 09-21-2009 11:37 AM
Page generated in 0.24635 seconds with 22 queries
