Like Tree10Likes
  • 1 Post By EdgeAutosport.com
  • 1 Post By 2.0t03speed
  • 2 Post By EdgeAutosport.com
  • 1 Post By ms3blackmica
 Old 09-10-2014, 02:56 PM   #1
Default Aquamist at EdgeAutosport!!
The best Water/Meth kit on the market is now available through EdgeAutosport!
Aquamist has been pioneering the IDC based water injection system since 2003 and have been doing so with great success! Their HFS3-pwm system is designed to complete the Aquamist's PWM-valve delivery system line-up. It allows precise metering of water/methanol injection for modern high performance engines. It also comes with a dash gauge, flow sensor and “Plug and Play” features are standard to minimize installation time.
This is the GTR of meth kits. It is loaded with technology and safety and is the last meth kit you will ever need to buy.
Easy color coded plug and play terminals on the controller make installation a breeze.
We have both the HFS3 and HFS2 in stock and ready to ship! You can read more about them on our website by clicking the links below!
Aquamist HFS3 Water/Methanol Injection System w/ Gauge, Failsafe - $753.11
Aquamist HFS2 Water/Methanol Injection System - $591.52
Mauro_Penguin likes this.
Captain KR (09-11-2014), jack_hammer (10-17-2014), kRs2PhO (09-10-2014), Mauro_Penguin (09-10-2014), SpeedRebirth (09-11-2014)
 Old 09-10-2014, 03:26 PM   #2
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
This is bad ass! But how come you don't mention the HFS-4, or is that coming in the future?
btstarcher (10-02-2014)
 Old 09-10-2014, 03:59 PM   #3
No HFS-4, no care.
btstarcher (10-02-2014), Mauro_Penguin (09-10-2014)
 Old 09-10-2014, 04:58 PM   #4
gdawg25's Avatar
Posts: 248   (View Stats)
Me love you long time!
 Old 09-11-2014, 12:04 PM   #5
The HSF3/2 are just what we have available at this time. I will amend the thread to add the HSF4 later.
Mauro_Penguin (09-11-2014)
 Old 09-16-2014, 03:23 PM   #6
HSF4's are on the way
btstarcher (10-02-2014), Code Monkey (09-16-2014), jack_hammer (10-17-2014), Mauro_Penguin (09-17-2014)
 Old 09-16-2014, 04:03 PM   #7
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
One thing to note is that the FAV's on these are limited to 1500cc/min so good enough for 500-550whp. i use 2 1.2mm nozzles on my hfs-3 kit, and i'm at 100% idc w/ 500whp. @EdgeAutosport.com; are you guys setting up the boards or is this something that Rich @ Aquamist or Jeff @ Howerton is doing. Only reason i ask is because of the different flow mappings on the controller.
When i first bought my kit it was setup on the highest flow map for 2 nozzles and i did not know it. I tried to use one .8mm nozzle and the system just kept tripping the fail safe.
2011silverspeed likes this.
The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post:
Code Monkey (09-17-2014), EdgeAutosport.com (09-17-2014), Mauro_Penguin (09-17-2014)
 Old 09-17-2014, 04:05 PM   #8
At this point we are not doing anything to the boards. The kit does come with instructions for cutting and soldering to run with the DI fuel systems as well as changing the flow maps to run anywhere from 1 to 5 injectors.
Here are some pictures to help illustrate what has to be done to run this kit on the MS3/6.
Default configuration:
This is how the board comes (here I have it removed from its little housing). These six pads represent different gains used depending on your fuel system. The default setup is for port injection as you can see the 1.0x gain pads are connected and in use.
DI Configuration:
In order to run this kit properly with a DI fuel system (such as with a MS3 or MS6), you will need to cut the link between the 1.0x pads and solder a link between the 2.5x pads shown above. This will change the configuration so that it works with the DI fuel system.
Flow Configuration:
To adjust the flow for different jet configurations, you must modify this part of the board. The default configuration is to run two jets. In order to run 1 jet, you must solder a link between pad 1 and pad 2. To run 3 or more jets, you must solder a link between pad 2 and pad 3.
All of this is outlined in the user manual with pictures and diagrams. If you have any questions, feel free to ask us and we'll be happy to help!
Code Monkey (09-17-2014), Mauro_Penguin (09-17-2014)
 Old 10-01-2014, 02:48 PM   #9
We have the HFS4 kits now by the way...
silvapain and Mauro_Penguin like this.
btstarcher (10-02-2014), Mauro_Penguin (10-01-2014), silvapain (10-02-2014), SpeedRebirth (10-03-2014)
 Old 10-17-2014, 10:59 AM   #10
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
But it's not in stock right? It doesn't show up on any search.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Mauro_Penguin (10-17-2014), Nliiitend1 (10-17-2014)
 Old 10-17-2014, 03:54 PM   #11
We sold the kit we ordered in for stock the day it got here. Didn't get the chance to take pictures of it so we haven't gotten it on the site yet.
 Old 10-02-2014, 06:11 AM   #12
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
FUCK. YEAH.
EdgeAutosport.com (10-17-2014), Mauro_Penguin (10-02-2014), rfinkle2 (10-20-2014)
 Old 10-17-2014, 10:43 AM   #13
Check out our weekly deal! It is relevant to this thread
 Old 10-17-2014, 04:42 PM   #14
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
The Aquamist HFS is high quality stuff.
Tuned many types of cars with this system and loved it.
www.tunedbynishan.com
EdgeAutosport.com (10-20-2014), Mauro_Penguin (10-17-2014), SpeedRebirth (10-17-2014)
 Old 10-20-2014, 02:01 PM   #15
^^ Truth! See it in person and you know there is nothing that compares!
ms3blackmica (10-20-2014)
 Old 10-21-2014, 08:39 AM   #16
@Lex;, the DDS3 is no longer available.
 Old 12-05-2014, 10:22 AM   #17
Meth injection doesn't have to be scary. It can be very safe when setup properly. Aquamist is one of the few kits that provides every measure of performance in conjunction with every measure of safety to ensure you have an excellent experience with meth injection. Don't miss out on on an excellent power and efficiency upgrade to your car!
Mauro_Penguin (12-05-2014)
 Old 01-02-2015, 01:14 PM   #18
Gotta love the amount of support you get from Aquamist when you've got one of their kits!
Mauro_Penguin (01-04-2015)
 Old 01-23-2015, 09:28 AM   #19
Aquamist Tanks are now available too.
We have them in stock. They are 5L or 1.32 Gallons which is pretty impressive considering how little area these will take up.
Mauro_Penguin (01-26-2015)
 Old 03-19-2015, 11:48 AM   #20
These meth kits are way beyond any other meth kit available.
taf0422 likes this.
 Old 03-19-2015, 11:51 AM   #21
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Well stop making me buy other awesome things from you guys and maybe I would have money for this. Lol
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
EdgeAutosport.com (03-19-2015)
 Old 04-09-2015, 02:37 PM   #22
Meth! Its good for your soul...
taf0422 likes this.
 Old 10-20-2014, 03:27 PM   #23
@EdgeAutosport.com; do you guys carry the DDS3 Failsafe?
I can't find any information on price or where to purchase it. Was it discontinued? Would be a great option to other failsafes out there.
Howerton Engineering, LLC ? Aquamist DDS3 Failsafe and Flow Monitoring System
I'll see if we can get it.
Aquamist HFS-4 Install skeurton 2010 MS3 - Fuel, Nitrous & Water Injection 40 05-04-2015 10:36 AM
Aquamist HFS-4 quick review more to come YokiMazoku MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 50 02-01-2015 10:14 AM
The all new affordable Aquamist HFS-3 system Richard L Mazdaspeed3/6 General Discussion 2 11-03-2010 02:18 AM
Welcome Aquamist to MSF Haltech Mazdaspeed3/6 General Discussion 28 03-24-2010 05:05 PM
Page generated in 0.43490 seconds with 28 queries
