| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
(Thread Starter) | Not Ranked : 0 score Aquamist has really thought this tank through. Designed with space savings in mind, at only 2.6" wide, 13" deep, and 13" tall. It will also hold a very respectable 5 quarts. The bracket is ergonomically designed to minimize installation time. Offering chassis floor or cross-rail mounting options. Four holes at the center section of the bracket are intended for mounting an Aquamist pump below. The bracket is constructed with 2mm zinc plated mild steel plate and powder-coated (light grey). The structure is very strong. All fixing fasteners are supplied as well. But more than that, look how neatly this tank fits in the trunk! ![]() ![]() But enough with all this form. Where this tank really shines is its function! The narrow shape coupled with internal baffles will insure you never starve the pump for meth even in hard corning or acceleration. [video=youtube;gXszFa3MkKM]https://www.youtube.com/watch?v=gXszFa3MkKM&x-yt-cl=85027636&x-yt-ts=1422503916[/video] Check out this tank on our site by clicking any of the pictures. Or you can click below to purchase! Aquamist Water/Methanol Tank with Baffle - $142.50 |
| The Following 9 Users Say Thank You to EdgeAutosport.com For This Useful Post: | 09TrueRedGTX (01-30-2015), chaser27 (01-30-2015), Hush (02-02-2015), John596 (02-05-2015), lobitoPU (01-30-2015), Mauro_Penguin (01-30-2015), tegxsi (01-30-2015), trancehead (01-30-2015), WetzMS3 (09-25-2015) |
![]() Join Date: Nov 2011 Location: hollywood Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,448
Groans: 42
| Not Ranked : 0 score Sweet. Now give us that tax return discount code!
__________________ i got a useless big fucking turbo Fuck mazdaspeeds Fuck shayne |
| The Following 5 Users Say Thank You to lobitoPU For This Useful Post: | BLKSTIG (02-01-2015), cyclist20 (02-01-2015), EdgeAutosport.com (02-02-2015), ms6mil (01-31-2015), Speedster13 (01-30-2015) |
(Thread Starter) | Not Ranked : 0 score Regardless of what meth kit you go with, this is the tank you need! |
| Not Ranked : 0 score I may be retarded, but how do you install the meth level sensor and the filter in this tank? IIRC, both have to be dropped inside the tank and then you tighten a nut on the outside so there are no leaks.
(Thread Starter) | Not Ranked : 0 score I believe that is still what you do with this tank. I suggest a really long flat head screw driver and some needle nose pliers to get the job done. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | Code Monkey (09-25-2015) |
![]() Join Date: Oct 2013 Location: Raleigh, Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
| Not Ranked : 0 score I think by tightening the nut on the outside, the grommet is compressed causing it to flair out or "bulge" and seal on the inside of the tank. So I think you just stick it in the outside and turn the nut. Or at least that's what I did. Not sure if yours is different but I most definitely did not need to drop anything into the tank and hold it there while tightening the nut from the outside.
__________________ 2013 Liquid Silver Metallic MS3 GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks TunedbyNishan |
| The Following 2 Users Say Thank You to mize13 For This Useful Post: | Code Monkey (09-28-2015), EdgeAutosport.com (09-29-2015) |
| in tank meth?? | david001wj | 2010 MS3 - Fuel, Nitrous & Water Injection | 7 | 06-19-2013 07:16 AM |
