Like Tree23Likes
 Old 09-28-2011, 09:07 AM   #1
^^that plus all necessary lines, gaskets, manifold options and a boost controller if required
ex: Steedspeed mani, new exhaust manifold gasket/dp gasket/mani-turbo gasket, gtx3071, necessary coolant/oil lines w/fittings, cpe whale dick tip for a total of XXXX dollars
These kits will include brand new 8.8 hardened studs, self locking 15mm nuts, oil return line, new banjo bolts for the oil feed and coolant return utilizing stock hard lines with those and the full brand new coolant to egr line.
I reused my stock gaskets as they are metal and all the kits I have installed and no one has yet to have any problems with them leaking. Also one last thing to order would be a 45* coupler 2''-2.5'' to fit from the turbo to hot pipe so its a direct bolt-up with your fmic
This is another great question, you are correct the stock map sensor only reads to 22 psi but I still run it without a hitch. To compensate all you need is a accurate boost gauge and to up the boost an mbc (i run the grimmspeed) or an ebcs. DJ (djuosnteisn) runs the same 2.5 and he is planning for 30+ psi so really it comes down to personal preference
8.5MS3 (09-28-2011), adlpb (09-28-2011), Alpha (09-28-2011), Broxer (09-30-2011)
 Old 11-09-2011, 09:20 PM   #2
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
What's this saying?
What boost do you run on your setup? You saying over 22psi? with stock map?
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbo-questions-92975/
Access port & KMD internals have arrived - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 11-15-2013 03:20 AM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 09:53 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.45258 seconds with 23 queries
