Like Tree23Likes
 Old 02-04-2013, 01:59 PM   #321
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Eric,
Can you recommend a turbo for us facing CA smog checks? I just went through one and had to take off my downpipe. So, without having to change a bunch of stuff every two years, what would you recommend?
I have an MS-CAI, which is Carb legal. But I also have a TIP, HPFP and TMIC, all of which is hidden. I can change to a testpipe and catback, but would like to keep the OEM downpipe, just bacause its a pain to take on and off every two years.
I'm thinking of an GTX2861R IWG. What do you think?
BNR S3
2009 CWP Speed3
 Old 02-05-2013, 02:22 PM   #322
Ferdball's Avatar
Posts: 1,340   (View Stats)
Researching...
@JP@edgeautosport.com
So, stock downpipe with a 2871. Waste? Thoughts please
The Following User Says Thank You to Ferdball For This Useful Post:
EdgeAutosport.com (02-08-2013)
 Old 02-05-2013, 11:16 PM   #323
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
@JP@edgeautosport.com;
I ordered the gt2871r turbo for the MS6 from you guys and I wanted to make sure what exactly comes with the turbo. I have the coupler, the boost tap source for the coupler, 2 hose clamps, and a new gasket with 2 bolts for the oil feed line.
I'm thinking because I have the gasket and 2 bolts for the oil feed line I might be missing the oil feed line(s) themselves. Can you clarify this or do we reuse the factory lines?
Researching...
Cheapest option...
gut the cat
Performance:
Stratified Tune in progress
 Old 02-06-2013, 09:13 PM   #324
Ferdball's Avatar
gut the cat
Yeah, but I need to pass the sniffer test too.
 Old 02-08-2013, 05:35 PM   #325
Researching...
I don't think it's a waste but at the same time, I don't think it's a good idea. Turbo cars need exhaust piping to be freed up more than a NA car. Back pressure would be bad I would imagine and I'm not sure the cats would like that too much either. You have to let a turbo car breathe.
Ferdball (02-08-2013)
 Old 02-08-2013, 07:20 PM   #326
Swinger13's Avatar
Groans: 53
@EdgeAutosport.com;
Performance:
 Old 02-09-2013, 09:44 PM   #327
Kfunk's Avatar
Posts: 33   (View Stats)
Kfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to behold
Really informative thread. Thanks for the info!
Kfunk is offline   Reply With Quote
The Following User Says Thank You to Kfunk For This Useful Post:
JP@edgeautosport.com (02-11-2013)
 Old 02-11-2013, 04:26 PM   #328
Davsetz's Avatar
Posts: 458   (View Stats)
Davsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the worldDavsetz is the leader of the world
I saw a guy with that IWG bracket from Cobb anyone else attest to it Im considering due to the fact I dont think Im savy enough for the hotside swap
Davsetz is offline   Reply With Quote
 Old 02-11-2013, 06:38 PM   #329
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Cheapest option...
gut the cat
Sorry for the delay. With the MS6s, you reuse the factory drain line. It should come with some stepdown studs to mate the factory line to the new turbo.
Yes, it works. But get the longer Subaru bracket if you have a big turbo. The hotside swap isn't hard at all but you need to clock the turbo correctly which isn't that bad with just the hotside.
Last edited by JP@edgeautosport.com; 02-11-2013 at 06:38 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
Davsetz (02-11-2013), Swinger13 (02-11-2013)
 Old 02-11-2013, 09:05 PM   #330
Davsetz's Avatar
Once again JP and the gang show their prowess at customer support and knowledge
 Old 02-11-2013, 10:05 PM   #331
mrsmith's Avatar
Posts: 85   (View Stats)
mrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud of
Groaned at 4 Times in 1 Post
I was looing into boost controllers and was wondering is it better to go mbc or ebc with a bt if im tying to reach 400+ hp. And witch brand would be better to go with.
mrsmith is offline   Reply With Quote
 Old 02-12-2013, 04:21 AM   #332
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
ebc imo.
Having control over your boost curve is pretty nice once you get to those power levels. It can nake it a lot easier to manage wheel spin in lower gears.
As far as brand goes, im pretty sure that they are all just rebranded mac solenoids, so there is really no difference.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
JP@edgeautosport.com (02-12-2013)
 Old 02-12-2013, 08:50 AM   #333
mrsmith's Avatar
And the aem tru boost is a mbc with a digital controller right? and would I tue it with the ap. if that's the case im just going to go cobb.
 Old 02-12-2013, 01:36 PM   #334
It's really your choice. I use a MBC because it's super easy and I can go give it a couple turns and get more boost just like that (if the tune allows for it). I personally like just choosing my boost level then getting there whenever I stand on the throttle. Some guys like tuning boost per gear which is cool too. It's just preference for how you like the boost to operate.
The AEM Tru Boost is an electronic solenoid just like the Cobb except it's not plug and play like the Grimmspeed and the Cobb.
 Old 02-12-2013, 01:51 PM   #335
ABolewski's Avatar
Posts: 1,279   (View Stats)
Do you guys have a similar package that CP-E offers? with the vband downpipe and manifold and choice of turbo, with lines/gaskets/studs etc included? and the EWG dumping into the downpipe? Really want all that with a 3076. and I'll need a FMIC too, preferably the UR with the slim crash bar.
(sold)
 Old 02-14-2013, 09:22 PM   #336
Other than CPE we don't have anything like that. Not sure if you realized but we do sell the CPE kit in whatever configuration you want.
ABolewski (02-14-2013)
 Old 02-14-2013, 11:09 PM   #337
ABolewski's Avatar
@EdgeAutosport.com; didn't realize that! Only poked around on my phone for the most part. I'll definitely check it out a little more on the Mac. Thanks
(sold)
 Old 03-15-2013, 11:37 PM   #338
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
Looking at turbos and have a question. With the gt3071 does the anti surge porting option help with the boost creep and what exactly is the benefit?
"under construction"
 Old 03-17-2013, 08:37 AM   #339
thered rocket's Avatar
Posts: 83   (View Stats)
thered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond reputethered rocket has a reputation beyond repute
If you are going to do anti surge porting on a gt3071r just get the gt3076 it already comes with it. The cost to do the porting is about the difference in turbos If I'm not mistaken.
Cobb Sri, Cobb Tip, Cobb FMIC, Cobb downpipe, Cobb AP, Auto X HPFP internals, Turbosmart BOV/BPV, SU Rear Engine Motor.
thered rocket is offline   Reply With Quote
 Old 03-18-2013, 12:33 PM   #340
That's true but does it help with the boost creep or did that issue get fixed?
 Old 03-18-2013, 06:15 PM   #341
Fizzyb's Avatar
Posts: 26   (View Stats)
Fizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to beholdFizzyb is a splendid one to behold
Anti-surge porting is to do with the compressor surge when you let off (that should escape through the bov. The rear housing that causes boost creep I believe is still an issue even if you pay for the anti-surge porting. I was of the same belief as you though JP corrected me when I originally started looking for my turbo upgrade.
Fizzyb is offline   Reply With Quote
 Old 03-18-2013, 06:41 PM   #342
Little John's Avatar
Posts: 494   (View Stats)
Little John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the world
Groans: 55
@EdgeAutosport.com; I can't find an option for a gtx3076 EWG do you sell them??
I may just be blind
Little John is offline   Reply With Quote
The Following 3 Users Say Thank You to Little John For This Useful Post:
EdgeAutosport.com (03-21-2013), lilred (03-18-2013), Micha (03-19-2013)
 Old 03-18-2013, 07:13 PM   #343
dantes5823's Avatar
Posts: 6,576   (View Stats)
I may just be blind
http://www.edgeautosport.com/atp-tur...o-kit-ms3-ms6/
The Following 3 Users Say Thank You to dantes5823 For This Useful Post:
 Old 03-18-2013, 07:15 PM   #344
Groans: 55
I knew i was just blind. Thanks @dantes5823;
dantes5823 (03-18-2013), lilred (03-18-2013), Micha (03-19-2013)
 Old 03-18-2013, 07:37 PM   #345
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by crazyp View Post
do you guys only sell GT30 series turbos?
any precision, Borg warner, etc. journal vs ball bearing.
I had a garret fail on me recently and the fact I cant really rebuild it sucks
Got my precision through edge!
 Old 03-18-2013, 07:40 PM   #346
Okay. Thanks for clearing that up. And all you have to do is port it and it won't creep correct?
 Old 03-18-2013, 08:16 PM   #347
Davsetz's Avatar
Read this it takes more then porting although porting helps..
http://www.mazdaspeedforum.org/forum/foru...es-atp-110456/
The Following User Says Thank You to Davsetz For This Useful Post:
2012FailWheelDrive (03-19-2013)
 Old 03-19-2013, 09:09 AM   #348
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Not necessarily. It depends how well you flow intake and exhaust side. But porting and a good high flow 3" cat will stop creep.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 03-19-2013, 09:14 AM   #349
Damn I have everything on the list that causes creep. Would my best bet be going ewg instead of switching out everything I have?
 Old 03-19-2013, 09:19 AM   #350
86AmishMs3's Avatar
Groans: 338
You don't have to replace everything. You must make the call...ewg is more costly especially if you want to re route to DP to be quieter and it's a little easier to tune.
Iwg is set for the get go, but tuning can be a bitch. The only way to know if you'll creep is putting it on. If you do...buy a 3" cat and weld it into the DP and you'll be fine.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 03-19-2013, 09:20 AM   #351
Ok thanks for the help.
 Old 05-28-2013, 11:37 PM   #352
Swinger13's Avatar
Groans: 53
@EdgeAutosport.com; is it possible to order just turbine housings from you guys? I may have future plans to get a hotside for the GT2871R for the mazdaspeeds. Also if you are able to get JUST the hotside? I know there isn't a GT28 EWG hotside so is there a service you can provide where you can shut the IWG hole via welding or some other method?
Performance:
 Old 05-29-2013, 09:17 AM   #353
We do sell turbine housings by themselves. Just let me know what you need. We do not weld the iwg shut, but you can get this little guy (Cobb Tuning IWG Bracket) which will do that job for you. Let me know if you have any other questions
Swinger13 (05-29-2013)
 Old 05-29-2013, 09:26 AM   #354
Swinger13's Avatar
Groans: 53
can you PM me a quote price for the bracket and the GT28 hotside mazdaspeed version?
Performance:
 Old 05-29-2013, 09:29 AM   #355
Voltwings's Avatar
Posts: 3,713   (View Stats)
Sorry Edge, but I wouldn't recommend that bracket at all. Maybe its install error on my part but I had mine come loose 3 times on my 3071 and I ended up with no boost, and it is a BITCH to get under the car and fix it. The problem is it doesn't cleanly bolt to the turbo (or at least not mine) because one of the coolant hoses is in the way, and then, the arm is WAY too long to hold the flapper shut so you have to trim it back a bit ... its just really not worth the effort man, I threw mine straight in the trash when I went EWG.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 05-29-2013, 09:44 AM   #356
Etipp98's Avatar
Agreed the Cobb bracket is junk. @Last_Loser; can attest to that!
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
Swinger13 (05-29-2013), Voltwings (05-29-2013)
 Old 05-29-2013, 09:44 AM   #357
Swinger13's Avatar
Groans: 53
Thanks for the info. I was questionable about that actually, it works great on the k04 as I've helped install one before. I can adjust my WG no problem on my gt28 installed but to take the whole wastegate bracket off it's actually a 3 bolt bracket and I had to take my turbo out completely to do so when I not knowingly installed my turbo with an 8 psi wastegate when I ordered 14 psi.
I would have to see pictures of the bracket installed on the GT28 before I invest in it
Performance:
 Old 06-07-2013, 12:52 PM   #358
bhamitgeek's Avatar
Posts: 362   (View Stats)
bhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the world
@EdgeAutosport.com I have a question for ya. I am looking at the GTX2867R kit. I wouldn t have to change the TIP out with that kit since I have a JBR Stage II correct? as soon as my internals come in I will have the test pipe on and internals. I should then pretty much need just to upgrade to the IC.... would the CP-E IC work just fine with this set up?
bhamitgeek is offline   Reply With Quote
 Old 06-07-2013, 01:21 PM   #359
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Jbr doesn't have an intake to fit the 3 inch inlet. I posed this question in the jbr forum. You'll either need a aluminum version with reducer or a new intake. I chose the htp 3 inch. I'll be using the cs tmic with the same turbo so I hope the cpe version would be fine.
bhamitgeek (06-07-2013)
 Old 06-07-2013, 02:53 PM   #360
We have just recently been made aware of another GTX2867 option that will allow you to retain the factory size turbo inlet pipe should choose to do so. It will also fit the with factory intercooler configuration. We will be posting up details about this very soon
bhamitgeek likes this.
The Following 6 Users Say Thank You to EdgeAutosport.com For This Useful Post:
agentgordon27 (06-13-2013), Andrewbox (06-07-2013), bhamitgeek (06-07-2013), Dimenus (06-07-2013), Poohster (06-07-2013), SarcasticOne (06-07-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/big-turbo-questions-92975/
Access port & KMD internals have arrived - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 11-15-2013 03:20 AM
Access port & KMD internals have arrived - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 12-02-2011 09:53 PM
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 05:47 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
MS6 Turbo back exhaust Questions Mazdagoat324 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-16-2009 03:33 AM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 12:08 PM
Page generated in 0.64915 seconds with 40 queries
