| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
(Thread Starter) | Not Ranked : 0 score In the description it says that it has a 3/8" rod bolt, what is the length of that bolt inder the head? I am thinking of picking up a set of these from you guys, rods are the last thing I need for my bottom end. Thanks!
| The Following User Says Thank You to 06Speed6 For This Useful Post: | EdgeAutosport.com (05-03-2012) |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | 06Speed6 (05-03-2012) |
(Thread Starter) | Not Ranked : 0 score Hells yeah! Put em to work! :-)
| Not Ranked : 0 score lol WHAT!?!?!?!?! how come no carrillo? you have the most ridiculous and best of everything else haha
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Why u no buy $10000 fordged carbon titanium custom rods?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following User Says Thank You to Tokay444 For This Useful Post: | 06Speed6 (05-03-2012) |
(Thread Starter) | Not Ranked : 0 score I have a line on some carillo rod bolts lol, im not gonna blow eagle rods anyway... not even close.
| EAgle GT tires | MS3Zoom24 | MazdaSpeed 3/6 - Wheels & Tires | 19 | 12-15-2009 03:30 PM |
| Eagle Rods | ilusch | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 10-10-2009 06:40 PM |
| New American Eagle Outfitters Coupon Codes - 15% Off Storewide at American Eagle Outfitters | Haltech | Hot Deals Section | 0 | 04-10-2008 03:00 PM |
