Like Tree3Likes
 Old 10-13-2012, 10:25 AM   #41
Bob-o's Avatar
Posts: 1,312   (View Stats)
Who needs to get built by edge?
The Following User Says Thank You to Bob-o For This Useful Post:
EdgeAutosport.com (10-15-2012)
 Old 10-24-2012, 06:09 AM   #42
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
Are any of you guys just dropping pistons,Rods and rod bearings without machine work?
If not what are you guys paying for the whole deal?
@eric@edgeautosport
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
The Following User Says Thank You to GunGuru727 For This Useful Post:
EdgeAutosport.com (10-24-2012)
 Old 10-24-2012, 09:29 AM   #43
Dooby's Avatar
Posts: 42   (View Stats)
Dooby is a name known to allDooby is a name known to allDooby is a name known to allDooby is a name known to allDooby is a name known to allDooby is a name known to all
Yes kinda...
I was also referring to something Alan is assigned to in getting pricing and parts list together for us directly to offer built motors built here locally and I will keep you posted with those prices when I find them out
+1 Interested on built packages as well..
Dooby is offline   Reply With Quote
The Following User Says Thank You to Dooby For This Useful Post:
 Old 11-07-2012, 02:30 PM   #44
Snotrocket's Avatar
Posts: 900   (View Stats)
I need everything except pistons and rods.... Could you PM me cost shipped to canada (K9J4L1)?
Main Bearings-123.50
Rod Bearings-92.52
Head Studs-174.42
Main Studs-122.35
Rear Main Seal-68.73
Front Oil Seal-9.13
Crank Pully bolt-11.58
Friction Washers-45.60
Overhaul Gasket Set-299.00
Cometic Head Gasket-89.00
VVT Actuator -119.06
Timing Chain-41.00
Timing Chain Tensioner-74.00
ACT 6 Puck Clutch + flywheel
Flywheel Blolts-40.00
I'm afraid i will get raped on duty tho Any way to avoid this?
2010 MS3 Black
395whp/386wtq
The Following 2 Users Say Thank You to Snotrocket For This Useful Post:
EdgeAutosport.com (11-07-2012), GartzSpeed (12-12-2012)
 Old 11-07-2012, 03:44 PM   #45
Rod Bearings-92.52
Head Studs-174.42
Main Studs-122.35
Front Oil Seal-9.13
Timing Chain-41.00
You mean on fee's? We can help you out I will pm you now.
 Old 11-25-2012, 02:47 PM   #46
Mattcinnc1's Avatar
Posts: 573   (View Stats)
Mattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the world
Yes kinda...
so what's the word on the builds happening
2006 Mazdaspeed 6 WWP
Mods: Cobb ap, Freektune ots+, rebuilt ko4(hhskinny), Autotechs, AEM CAI, ETS tmic, Sure sidewinder, JBR RMM, Cpe diff mount, sure charge tubes, Corksport strut tower, catless test pipe, Magnaflow CBE, Forge BPV(v1), JBR shift bushings, corksport rear sway bar, VTCS delete, Dba 4000 slotted rotors, ebc red stuff
Interior: Block Vent pod, Prosport boost gauge, Redline leather boots, Mazdaspeed E-brake, Ipod integration, Corksport LEDs
Looks: 15% tint all around, 40% entire windshield, Corksport LED fogs, Corksport stub
Fluids: Rotella T6, Motorcraft XT-M5-QS, Redline 75w90
waiting to install (in garage):
Cpe catted dp
Mattcinnc1 is offline   Reply With Quote
 Old 12-12-2012, 08:32 AM   #47
GartzSpeed's Avatar
Posts: 155   (View Stats)
GartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the worldGartzSpeed is the leader of the world
Ok, that's it!!! Ima pm you tonight, or do I pm Jp now?
Let me know, I'll try and keep the vaping to a minimum tonight so you understand what I am saying, and not assume I am completely coherent
GartzSpeed is offline   Reply With Quote
 Old 02-08-2013, 03:34 PM   #48
brandonf's Avatar
Posts: 511   (View Stats)
brandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the worldbrandonf is the leader of the world
Email sent for an inquiry!
2011 Silver MS3: Totaled
2006 Silver Speed 6: Modification in process
Speed3: 1/4: 12.8@115.71
Build log for the 6: http://www.mazdaspeedforum.org/forum/forum/f498/brandonf-flo-s-bt-speed6-build-191584
brandonf is offline   Reply With Quote
The Following User Says Thank You to brandonf For This Useful Post:
EdgeAutosport.com (02-08-2013)
Weston's MS6 Build Thread Weston MazdaSpeed 3/6 - Build Diaries 23 08-14-2014 03:37 PM
Captain KR's build thread Captain KR Mazda MZR DISI Engine Builds (2006-2013) 28 04-17-2013 08:41 AM
Page generated in 0.30110 seconds with 27 queries
