Like Tree10Likes
  • 1 Post By torq
  • 1 Post By Pu Manchu
  • 1 Post By shamie
  • 1 Post By breakfstincluded
  • 1 Post By mize13
  • 1 Post By EdgeAutosport.com
  • 1 Post By ItsNox
  • 1 Post By ibcrusn
  • 1 Post By anodizedeeznutz
 Old 01-30-2014, 09:36 AM   #1
Default ETS Top Mount Intercoolers at EdgeAutosport
Extreme Turbo Systems is very much defined by their name. ETS specializes in all things turbocharged including exhaust manifolds, downpipes, intercoolers, exhaust systems, intake systems, and full turbo kits. Everything they do screams quality and high performance.
The ETS Top Mount Intercooler for the Mazdaspeed 3 and 6 is no different than the rest of their high quality/high performance lineup.
The first thing that comes to mind when I see this intercooler in person is beautiful. Beautiful welds, beautiful fit, and beautiful finish.
This direct bolt on, easy to install intercooler is second to none and with this simple modification you can expect to see some very significant gains in power and torque. It is made with a bar and plate core that is 3.25" thick and will cool the air coming from your stock or upgraded turbo much more efficiently than the factory intercooler or even some lesser quality FMIC's that are on the market.
For an extra $100 you can have your ETS Intercooler anodized in one of many colors, including Black, Blue, Red, and Gold. Never before have form and function come together so perfectly!
ETS TMIC 06-07 MS6 07-09 MS3 - $565
ETS TMIC 10-13 MS3 - $565
trancehead (02-14-2014)
 Old 01-30-2014, 06:21 PM   #2
ihasmazda's Avatar
Posts: 1,011   (View Stats)
So beautiful but so pricey.
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 01-30-2014, 06:46 PM   #3
sidekick's Avatar
Posts: 3,093   (View Stats)
Especially when it doesn't offer significantly better performance than the other TMICs out there.
 Old 01-31-2014, 09:04 AM   #4
Emew's Avatar
Posts: 217   (View Stats)
My only issue is, as you can see in 1 of the pictures. Their idea on how to mount the shroud to the IC.
Example: You bring your car in for service and they need to remove your TMIC, they un-screw the top screws and what happens? They blindly drop a nut/washer into the abyss of the engine bay. A friend of mine had mentioned the idea of just JB Welding or some other means of just keeping the nut/washer combo stuck to the bottom of the shroud. If anyone has other ideas feel free to voice them!
Flow Student
 Old 01-31-2014, 10:05 AM   #5
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Agreed, all it takes to fix that is to tack the nut to the flange. I'm running a Gen1 ETS on my Gen2 and I used a bolt going from the bottom into a coupling and used loctite to help lock it in place and then I can just attach the mount from he top with another bolt.
On Order:
Coming Soon:
DIY Projects:
Emew (01-31-2014)
 Old 02-06-2014, 10:30 AM   #6
These intercoolers qualify for our tax sale so you can order them and save some money. Just use the coupon code Tax1 at checkout.
breakfstincluded (02-12-2014), trancehead (02-14-2014)
 Old 02-07-2014, 01:01 PM   #7
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
The ETS unit looks a lot better in terms of aesthetics and quality than every other TMIC readily available. Is it worth the extra $$$, you'll have to decide because hind sight is always 20/20.
Here's the solution if you let others wrench on your car....tamper proof hardware.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 02-07-2014, 03:36 PM   #8
torq's Avatar
Posts: 82   (View Stats)
torq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Heck you think it's hard managing bolts that are exposed, taking mine off requires hand contortions as I adapted my stock cover to the ETS to cover the ugliness of the fuel pump etc.
SKiZZ likes this.
Cobb AP Autotech HPFP Internals JBR RMM,SSP,Stage2 OCC. RSB CS Racepipe, SSB ETS TMIC Stratified Guardian Angel NGK Step Colder Plugs HTP 3" full intake. Michelin 245/40/18 Pilot Super Sports TSW 18x8.5+45 Nurburgring Wheels Swift Spec-R Springs Koni Yellow Struts/Shocks GFB BOV
torq is offline   Reply With Quote
The Following 9 Users Say Thank You to torq For This Useful Post:
ABOSWORTH (06-27-2014), Agent_Orange (02-14-2014), breakfstincluded (02-13-2014), Emew (02-07-2014), littleloogy (02-07-2014), Micha (02-11-2014), sidekick (02-28-2014), XxSmarTz (02-18-2014), Yatta (03-12-2014)
 Old 02-10-2014, 11:17 AM   #9
This is seriously the best looking TMIC setup I've ever seen! Very clean!!
 Old 02-10-2014, 07:25 PM   #10
torq's Avatar
Thanks, was a decent amount of work!
For a deal on some AEM gauges I might be convinced to rep edgeautosport, have a decent amount of parts from you.
 Old 02-10-2014, 08:48 PM   #11
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
i literally never remove the shroud from the intercooler, because it's not blocking any of the mounting hardware.
trancehead likes this.
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
breakfstincluded (02-13-2014), Liquid3Speed (02-11-2014), trancehead (02-14-2014)
 Old 02-11-2014, 07:44 AM   #12
Send me a PM and let me know which ones you need and I'll see what I can do!
 Old 02-12-2014, 05:01 PM   #13
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
dude... thats nice.
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
 Old 02-13-2014, 12:26 PM   #14
Just in case you guys didn't know already.. This intercooler is included in the tax sale
 Old 02-13-2014, 02:09 PM   #15
shamie's Avatar
Posts: 952   (View Stats)
So are there any discounts on this TMIC, like a sale or something?
EdgeAutosport.com likes this.
 Old 02-13-2014, 02:16 PM   #16
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Not as shiny as Torq's but here's mine on a genwon (:
Fits great!
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
Micha (02-13-2014), trancehead (02-14-2014)
 Old 02-13-2014, 03:42 PM   #17
Fits great!
Oh you tease me with carbon fiber! Did you make that your self?
 Old 02-13-2014, 06:17 PM   #18
I diid noot, I wish I did hehe. Bought the ETS here and the previous owner had made that shroud to cover the snake nest, and he just wrapped it in carbon fiber vinyl.
For anyone that has issues with their painted/anodized shroud having marks from the rubber ducting. This stands up pretty well. Doesn't peel from engine heat either like I thought might happen.
EdgeAutosport.com (02-14-2014), Micha (02-13-2014)
 Old 02-13-2014, 09:46 PM   #19
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
Had mine anodized black. Love it
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
The Following 3 Users Say Thank You to mize13 For This Useful Post:
EdgeAutosport.com (02-14-2014), ItsNox (03-05-2014), trancehead (02-14-2014)
 Old 02-14-2014, 08:07 AM   #20
Well we have some good looking ETS setups getting posted up! So, including the guys that have already posted, if you want an Edge sticker (or if even if you don't), just post up a picture of your ETS TMIC installed in here and I'll send you one
mize13 (02-14-2014), trancehead (02-14-2014)
 Old 02-14-2014, 09:35 AM   #21
trancehead's Avatar
Posts: 1,841   (View Stats)
All sexy black and annodized too @EdgeAutosport.com;
2012 CWP MS3
2014 SWP WRX
2014 SWP Mazda 3
 Old 02-14-2014, 09:59 AM   #22
racingrayson's Avatar
Posts: 190   (View Stats)
racingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the world
https://www.pegasusautoracing.com/pr...p?Product=6069 problem solved.
racingrayson is offline   Reply With Quote
 Old 02-14-2014, 02:51 PM   #23
Thats so... Depressing... lol!
But it counts!
trancehead (02-15-2014)
 Old 02-15-2014, 07:50 PM   #24
trancehead's Avatar
Hahaha well at least they decided to place the hod support in a great location.... Like the intake manifold.... Sigh lol this is why the car had to be sold. LOVED that ets while I had it though. Had a cold pipe tapped for meth and everything. Highly recommend it.
2012 CWP MS3
2014 SWP WRX
2014 SWP Mazda 3
The Following User Says Thank You to trancehead For This Useful Post:
EdgeAutosport.com (02-17-2014)
 Old 02-27-2014, 02:24 PM   #25
We have a Gen 1 TMIC left over from our last stocking order. But more will be coming soon. These are the best TMIC's on the market.
breakfstincluded (02-27-2014), ItsNox (03-05-2014)
 Old 03-05-2014, 08:22 AM   #26
ItsNox's Avatar
Posts: 3,076   (View Stats)
Ive got the ETS TMIC and I LOVE IT. I bought it second hand (originally bought from Edge lol) and with 20k miles on it. It still looks brand new and the workmanship is incredible.
If you're looking for a TMIC there's no better way to go than ETS & Edge.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
EdgeAutosport.com (03-05-2014)
 Old 03-10-2014, 08:31 PM   #27
ibcrusn's Avatar
Very happy with my ETS unit, thanks guys. You'll have to forgive the filthy engine bay it's winter in KS.
'10 VRM MS3
Sir Henry Royce
 Old 03-12-2014, 09:20 AM   #28
Looking good! Love the black anodized ETS TMIC's!
 Old 03-19-2014, 07:50 AM   #29
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
just curious why you guys are anodizing vs powder coating?
I had plans to pick up a tmic and get the shroud PC'd wrinkle black
08 cwp ms3
 Old 03-19-2014, 08:08 AM   #30
anodizedeeznutz's Avatar
Posts: 2,796   (View Stats)
anodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the worldanodizedeeznutz is the leader of the world
Powder coating is thick and will likely hurt the cooling ability of the tmic.
Anodizing actually aids in heat dissipation and can actually improve cooling ability.
Tapatalkin'
2013 CWP Mazdaspeed3 - SOLD
2014 Mitsubishi Evo X - time for some fun.
anodizedeeznutz is offline   Reply With Quote
The Following 3 Users Say Thank You to anodizedeeznutz For This Useful Post:
Boostin'likeAboss (03-19-2014), Gr8Speed (03-19-2014), ItsNox (03-19-2014)
 Old 03-19-2014, 08:18 AM   #31
ibcrusn's Avatar
Powder coating the shroud won't hurt but you don't want to powder the core or tanks for reasons mentioned above (heat retention).
Are you wanting to powder the shroud for aesthetic reasons or to prevent the rub marks from the shroud?
I'm not sure anodizing aids in the cooling abilities but it will help prevent corrosion to the aluminum.
'10 VRM MS3
Sir Henry Royce
The Following User Says Thank You to ibcrusn For This Useful Post:
EdgeAutosport.com (03-19-2014)
 Old 03-19-2014, 08:26 AM   #32
pretty much for both those reasons, I don't like excessive chrome/polish in an engine bay and I've seen anodizing fade over time (fwiw cheap ebay stub antennae). a professional anodizing job probably wouldn't fade, especially sitting under the hood.
08 cwp ms3
 Old 03-19-2014, 08:32 AM   #33
ibcrusn's Avatar
It difficult to see in my pic but I applied 3M anti-chafe tape to the top side if the shroud to prevent the shroud from getting scratched up from the seal. It can usually be found at body shops and I'm sure it can be had on eBay because its the same type material as head and hood masks.
A professional anodizing job would do the trick if you don't purchase one already dipped, just be aware if you purchase a IC used that has helicoils they will have to be removed before dipping.
'10 VRM MS3
Sir Henry Royce
 Old 03-19-2014, 11:16 AM   #34
Yeah you don't have to worry about powder-coating the shroud. That is definitely okay to do and won't effect performance at all. Like stated above, just don't coat the core!
 Old 03-19-2014, 11:19 AM   #35
Here's my TR6. I'm quite familiar with anodize and yes, improved heat dissipation can improve cooling ability.
Tapatalkin'
 Old 03-19-2014, 11:21 AM   #36
Also, UV rays kill the dye which is why anodize will fade over time. Most dyes are organic and will do this no matter what. The anodize is still there and will still have corrosion protection, but it will not look pretty. If It's under the hood or behind the grille the color will last much much longer.
Tapatalkin'
There Is architectural anodizing which is sealed using a different method with co-Deposits a different type of metal to prevent the fade. You often see this done on window frames and such.
Tapatalkin'
Last edited by anodizedeeznutz; 03-19-2014 at 11:21 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to anodizedeeznutz For This Useful Post:
Boostin'likeAboss (03-19-2014), ItsNox (03-19-2014)
 Old 03-19-2014, 11:33 AM   #37
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
I have seen aforementioned TR6 and it looks a lot better than that picture leads you to believe.
Intercoolers thomaswixted 2010 MS3 - Turbo Induction 35 11-26-2012 06:01 AM
CPe Intercoolers for the MS6/MS3 phailerider Custom Performance Engineering (cp-e.com) 24 11-10-2008 09:05 PM
Page generated in 0.55711 seconds with 38 queries
