Like Tree8Likes
 Old 04-16-2014, 03:18 PM   #1
Default Got Bilstein? These B14 Coilovers are Sick!
It helps if you've seen them in person to truly be able to appreciate them, but we are very impressed with the quality and performance that Bilstein wraps up in this awesome little package for the Mazdaspeed 3. But then they are Bilsteins so we expect nothing less than perfection!
The B14's are a step down from the B16's which are the top of the line offering from Bilstein. The B14's offer ride height adjustment to go along with specifically paired dampers and springs to make for an excellent road and track combo.
They are surface coated for corrosion resistance for a long hassle free life, and they have also TUV certified which is the highest standard by which German made suspension components are tested.
Get them now on our website by following the link below.
Bilstein B14 Coilover Kit Mazdaspeed 3 2007-2013
- $1069.10
Let me know if you have any questions!
kritz likes this.
blam1 (04-16-2014), Domino81 (04-16-2014), himurax13 (04-18-2014), kritz (11-09-2015), Neverlift (04-21-2014)
 Old 04-16-2014, 05:24 PM   #2
Ezekiel81923's Avatar
Posts: 535   (View Stats)
Ezekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the world
Spring rates?
2011 VMR Mazdaspeed 3
Cp-e | Cobb | JBR | Freektune
Ezekiel81923 is offline   Reply With Quote
The Following User Says Thank You to Ezekiel81923 For This Useful Post:
 Old 04-16-2014, 10:36 PM   #3
JMONTI's Avatar
Posts: 27   (View Stats)
JMONTI has a spectacular aura aboutJMONTI has a spectacular aura about
looking for a DD not to track this will work?
JBR SRI // TIP // RMM 88 DURO // AT INTERNALS // AP V3 // STRATIFIED OTS STAGE 1 // NGK SPARK PLUGS // 50% 93 OCTANE 50% E-85 // H&R SPRINGS // SPC REAR CAMBER ARMS // 5000K DDM HID'S // 35% FRONT 15% REAR CERAMIC WINDOW TINTS // CPE TOW PLATE // ZAPTEK PAINT PROTECTION //
JMONTI is offline   Reply With Quote
The Following User Says Thank You to JMONTI For This Useful Post:
EdgeAutosport.com (04-18-2014)
 Old 04-16-2014, 10:43 PM   #4
LatinKraze's Avatar
Posts: 804   (View Stats)
Ooo fuck, do want. Already running Bilstein B8 and Cobb springs tho.
2016 CX-5 GT AWD
The Following 2 Users Say Thank You to LatinKraze For This Useful Post:
EdgeAutosport.com (04-18-2014), himurax13 (04-18-2014)
 Old 04-18-2014, 12:53 PM   #5
Originally Posted by Ezekiel81923 View Post
Spring rates?
I can't find the rates so I'm gonna call and find out. I'll post up when I get a response from them on this.
These will be good for a daily driver. They are comparable to the H&R coilovers which make for great street/mild track use coilovers.
EDIT:
No springs rates listed, but this is from Bilstein's site.
Descriptor: Front Lowered Height: 10-25mm, up to 1100kg Axle Load
Descriptor: Rear Lowered Height: 5-25mm, up to 1090kg Axle Load
JMONTI (04-18-2014)
 Old 04-18-2014, 01:39 PM   #6
CodeMan's Avatar
Posts: 261   (View Stats)
CodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the worldCodeMan is the leader of the world
I have these on my Pu, bought from Edge actually. Front spring should be a linear main spring and tender spring. Main spring at 379.62 lbs and tender at 114 lbs. Rears are a progressive at 377.34 lbs. These are great for the street IMO. They're not going to "stance" you though if you're into such things.
CodeMan is offline   Reply With Quote
The Following 4 Users Say Thank You to CodeMan For This Useful Post:
Easter Bunny (04-18-2014), EdgeAutosport.com (04-18-2014), jrotaryb (04-18-2014), LatinKraze (04-18-2014)
 Old 04-18-2014, 02:39 PM   #7
JMONTI's Avatar
how's the handling and installation? Any pics?
 Old 04-18-2014, 02:45 PM   #8
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Do the rear spring perches mount on the bottom or the top?
Pickles Tune in progress
 Old 04-18-2014, 03:41 PM   #9
CodeMan's Avatar
Installation is straightforward. Car handles well for me, it's fairly neutral. There was already a RSB on the car and the coils didn't change much in terms of balance, which is a good thing IMO. There's a pic on here somewhere, not on the phone I'm on now.
Rear perches mount on the top.
The Following 2 Users Say Thank You to CodeMan For This Useful Post:
EdgeAutosport.com (04-18-2014), JMONTI (04-18-2014)
 Old 04-18-2014, 04:06 PM   #10
himurax13's Avatar
Groans: 255
So are they as useless as the ones for the HR coliover kit?
 Old 04-20-2014, 09:41 PM   #11
mWindu's Avatar
Posts: 244   (View Stats)
mWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the worldmWindu is the leader of the world
I have the H&R's. It did shock me that they designed the spring perch to mount on the bottom inside the lower arm. But when it actually came time to adjust it it was fairly easy. Just pull out the bolt holding in the arm in and it loosens it up enough to remove the spring and perch. Make adjustment and slap it back in.
Granted it *should* be easier to do than that but in reality its not that bad.
\\2008.5 MGM Speed3//
POWER
\\Autotech HPFP//HTP 3.5" Intake\\CNT Catback//Corksport TP\\TR1035 FMIC//P&P Intake Mani\\JBR TIGS//EGR Delete\\
HANDLING
\\JBR 88 Duro Trilogy Mounts//H&R Coilovers\\JBR RSB//Whiteline Adjustable Rear Endlinks\\Corksport Camber Plates//JBR Camber Arms\\SS Brake Lines//
\\Stoptech Drilled Rotors\\
\\STRATIFIED TUNED//
mWindu is offline   Reply With Quote
The Following User Says Thank You to mWindu For This Useful Post:
EdgeAutosport.com (04-21-2014)
 Old 04-21-2014, 11:18 PM   #12
himurax13's Avatar
Groans: 255
Dropping the bolt is easy but time consuming, putting it back in, not so much. You don't need to remove the end links? In any event that is a pain in the dick just to make a quick adjustment and if the Bilsteins are the same way that is fucking retarded.
Sent from Stockish Pu
 Old 04-21-2014, 11:21 PM   #13
mWindu's Avatar
The endlinks is a good point. When I adjusted mine my sway bar was already out (I can't remember why) and I just remember it being easier to do than it looked. Like I said before, more complicated than it should be, but not too bad realistically.
POWER
HANDLING
 Old 04-21-2014, 11:52 PM   #14
mWindu's Avatar
I would have preferred it to be a different way for sure. But I also enjoy working on my car a lot. Making small adjustments here and there don't really bother me all that much. Even if they are time consuming.
POWER
HANDLING
 Old 04-21-2014, 11:56 PM   #15
himurax13's Avatar
Groans: 255
Some of us would rather drive the car. But you have to admit, that is the worst way to do rear height adjustment short of adding spacers/shims.
 Old 04-21-2014, 11:59 PM   #16
mWindu's Avatar
It is the worst way lol. But what other ways are there? Do other kits have the perch on the top of the spring?
POWER
HANDLING
 Old 04-22-2014, 12:01 AM   #17
himurax13's Avatar
Groans: 255
BC does it from the top and KW does it from the bottom. Neither requires disassembly for adjustment ...
 Old 04-24-2014, 07:20 PM   #18
jeffdevo's Avatar
Posts: 395   (View Stats)
jeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond repute
Need more reviews! on the fence about ordering these!
-Low Beam/ Fog HIDS - Lamin-X Yellow Tint on Fog Lights - TSW Mallory Wheels - Thule Bike Rack with 598 Criterium Bike Mount - GX-65 with Blendmount - Corksport RMM - Corksport Mudflaps - Corksport SRI - Corksport Rear Sway Bar - GX-65 radar laser detector - TRS Angel Eyes - Rear bumper LED Light - H&R Springs - Koni Yellow Struts - JBR Camber Arms - AP v2 -Autotech internals - Tork Motorsports Tuned - Halos - Strips - D2 Xenon Lights - SST brake lines - Stoptech Sport brake and rotors w/ sst Brake lines
[/I][/SIZE][/FONT]
jeffdevo is offline   Reply With Quote
 Old 04-24-2014, 07:27 PM   #19
Jap11g's Avatar
Posts: 287   (View Stats)
Jap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond reputeJap11g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Also on the fence between these, ksport and SonicTuning...
JP
Jap11g is offline   Reply With Quote
 Old 04-25-2014, 07:27 AM   #20
jrotaryb's Avatar
Posts: 416   (View Stats)
You just compared Bilstein TUV approved coilovers with Ksport/SonicTuning made-in-china stuff??
pedal2plastic.wordpress.com
The driving game blog
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
 Old 04-25-2014, 08:39 AM   #21
Jap11g's Avatar
Hell idk what's made where! Lol
I just don't want something that's gonna ride like shit on the street. I need something comfortable lol
Car will not be tracked.
Tapa Tapa Tapa
JP
Last edited by Jap11g; 04-25-2014 at 08:39 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-25-2014, 09:41 AM   #22
himurax13's Avatar
Groans: 255
Tapa Tapa Tapa
Coilovers are not for you then.
 Old 04-25-2014, 09:43 AM   #23
Jap11g's Avatar
Well there's my confusion then lol because I read that sonic tuning was similar in ride comfort to stock. Are Bilstein rough rides?
Tapa Tapa Tapa
JP
 Old 04-25-2014, 10:03 AM   #24
jrotaryb's Avatar
Like much with this hobby, there are too many contributing factors to make such blanket statements IMHO. There is a difference between a firm ride and an uncomfortably stiff ride...
I'd take a budget coilover from a real suspension company like KW/H&R/Bilstein who can produce/match springs and dampers rather than the cookie-cutter china stuff that is really made to just hold together, slam your car and let you make adjustments.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 04-24-2014, 11:49 PM   #25
himurax13's Avatar
Groans: 255
I wish I could just buy the fronts.
 Old 04-25-2014, 10:08 AM   #26
Jap11g's Avatar
Well, for the price these are barely more expensive than the competition I was considering.....
Do these come with front camber plates?
Tapa Tapa Tapa
JP
 Old 04-25-2014, 10:29 AM   #27
jrotaryb's Avatar
Tapa Tapa Tapa
At that price? No way - you re-use your stock top mounts and you'd be well advised to buy new ones. Besides, if you're concerned about comfort, the stop top mounts will be more comfortable than say a metal camber plate.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 04-25-2014, 10:31 AM   #28
Jap11g's Avatar
Knew it was too good to be true lol just figured id need aftermarket camber plates to avoid running crazy camber on a drop
Tapa Tapa Tapa
JP
 Old 04-25-2014, 10:38 AM   #29
jrotaryb's Avatar
Tapa Tapa Tapa
Nope - do some more research - these coilovers won't slam you and will only work correctly in their limited recommended lowering range. They will drop you and they will look good but it's a functional street suspension and form follows function on this set.
The negative camber you'll end up with up front (due to lowering) is fine and actually desirable. You will want camber adjusters for the rear for sure.
Once you choose a set of coilovers and get them installed, get an alignment, zero toe and less negative camber in the rear compared to front will get you a decent street alignment IMHO for a fwd car. Something like -1.5 degrees up front and -1.0 in rear for the street.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
The Following 2 Users Say Thank You to jrotaryb For This Useful Post:
EdgeAutosport.com (04-25-2014), patback (02-13-2020)
 Old 04-25-2014, 12:31 PM   #30
Tapa Tapa Tapa
These will have excellent ride compared to BC/Ksport/ whatever basic coilovers. I'm not saying those are bad, but the Germans know what they are doing when building suspension.
Tapa Tapa Tapa
These do not come with the camber plates so you will need to reuse the factory top hats. Like Jrotaryb said, the camber in the front will be fine but the camber in the rear will need to be pushed back out a bit.
As with pretty much everything, you get what you pay for. Higher end suspension kits come with less compromises than the entry level kits. We have Ksport Kontrol Pro's on our shop Speed 3 and they work great! They lower the car and we can adjust them and they are not too harsh. We put KW V3 coilovers on our shop Focus ST and my mind was absolutely blown by how well they performed compared to how well they ride. I had never experienced a high dollar suspension kit before first hand. We can barely tell the difference from stock in comfort and the car just goes around a corner like it is on rails. It really is impressive how much more performance you get out of the higher end suspension systems.
allo80 (04-28-2014), dh5077 (05-09-2016)
 Old 04-25-2014, 12:47 PM   #31
jrotaryb's Avatar
PLUS, there is Bilstein's warranty AND their advance replacement program where should you need service, they will send a new damper unit out to you (charged to your cc) and let you return the old one in the box from the new one. If under warranty or defect, they will refund you once the damaged piece is received.
For those of us without beater cars, no down time for service is HUGE in my book...even if I never need to use it.
EdgeAutosport.com likes this.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
 Old 04-25-2014, 12:40 PM   #32
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Is a stiffer rear setup possible? I still stand by the thought that we could forgo a RSB altogether and just have stiffer springs for both corner & straight-line handling with no more jouncing over highway bumps.
 Old 04-26-2014, 03:30 AM   #33
himurax13's Avatar
Groans: 255
Corksport Camber plates and camber arms will run you another $500 and you have to drill out the strut towers to fully utilize the camber adjustments.
Don't forget new strut bearings so that will bring up the price another $100 or so. I have the B8's and I am running all of that stuff with them. Then you need the rear sway bar and end links.
Coilovers usually need adjustable front end links so that you can adjust the preload on the front sway bar.
Then you could get different springs and perches.
Of course you should get a corner balance afterwards with the 4 wheel alignment to get the full benefit. This shit gets pricey fast.
*EDIT*
When adjusting the front coilover, make sure that there is enough preload/tension on the front springs to keep the strut bearings and top mounts from binding. If you don't the strut bearings and or top mounts will break, quickly.
The Following 2 Users Say Thank You to himurax13 For This Useful Post:
EdgeAutosport.com (04-28-2014), Jap11g (04-26-2014)
 Old 05-22-2014, 09:52 AM   #34
We currently have one set in stock and ready to ship. These are definitely a killer deal for what you get.
 Old 05-22-2014, 11:22 AM   #35
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
After running H&Rs, I don't feel the adjustment perch is a huge issue in the rear. They are easy to pull once the car is in the air and amount to 5-10 minutes of extra work.
Typically, the average user will adjust these a couple times over the life of the coils. And knowing an alignment generally follows any height change, it's going to be an "effort" regardless.
I'll also add that Bilstein, H&R and KW technically use a two-step linear spring in the rear. The bottom 3-4 coils should be fully compressed at static height.
09 CWP MS3 GT
Ownership & Build Thread
The Following 2 Users Say Thank You to Design For This Useful Post:
EdgeAutosport.com (05-28-2014), VaporOnly (11-11-2015)
 Old 08-12-2014, 03:14 PM   #36
These coilovers are in stock! We have the B16's as well!
The B14's are a great bang for the buck coilover option!
 Old 10-06-2014, 06:24 PM   #37
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I got my B14's not too long ago...
I haven't installed them yet but I plan on taking pics of the install
EdgeAutosport.com (10-07-2014)
 Old 10-07-2014, 12:05 PM   #38
Feel free to post your pics here along with your thoughts on the setup!
djrich26 (12-08-2015)
 Old 10-08-2014, 04:30 PM   #39
B14 and B16 Coilovers are in stock and ready to ship!
 Old 10-24-2014, 02:03 PM   #40
Make sure you guys check out our weekly deal!
MS6 Suspension Data & DIY Bilstein Coilovers phate MazdaSpeed 3/6 - Suspension & Brakes 1144 02-08-2020 10:53 AM
Anybody running Bilstein B14 PSS Coilovers? Derp MazdaSpeed 3/6 - Suspension & Brakes 116 01-20-2016 03:02 PM
BC Coilovers or Bilstein Dampers/H&R Springs Bleupit80 MazdaSpeed 3/6 - Suspension & Brakes 6 02-12-2013 07:35 AM
Page generated in 0.61188 seconds with 32 queries
