 Old 05-27-2015, 11:13 PM   #1
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Default Gtx29 turbo.... Is this real life
What's the point? Is it really a difference over the gtx28 frame?
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
The Following 2 Users Say Thank You to blake0521 For This Useful Post:
Agent_Orange (05-28-2015), EdgeAutosport.com (05-28-2015)
 Old 05-28-2015, 02:42 AM   #2
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
bigger turbine wheel = moar powa
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 05-28-2015, 05:27 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
That's what a 30 is for...
Blue Pu.
The Following 3 Users Say Thank You to anavrinIV For This Useful Post:
Agent_Orange (05-28-2015), Voltwings (05-29-2015), WAMBUSHHHH! (05-29-2015)
 Old 05-28-2015, 06:15 AM   #4
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
If your going to max out that turbo, your gonna be built. If your built, your going to want a bigger turbo and more power. At least for straight line speed.
Im curious about its spool characteristics. Might be a good turbo for twists and turns.
The Following 4 Users Say Thank You to Agent_Orange For This Useful Post:
EdgeAutosport.com (05-28-2015), Thepedigree13 (05-28-2015), Voltwings (05-29-2015), WhiTe_JeZebel (05-28-2015)
 Old 05-28-2015, 07:56 AM   #5
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
SuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond repute
It seems like a fun, yet slippery slope. Go big turbo, want to crank it up so you build the motor, and then you want more boost. And then you end up with an empty wallet and a grin from ear to ear. Meh, fair trade off.
2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan
SuckSqueezBangBlow is offline   Reply With Quote
 Old 05-28-2015, 01:42 PM   #6
Honestly, I don't really know. Other than giving people more choices... When it comes down to it, you are looking at 100 to 300rpm differences in spool between each turbo and a couple lbs/min differences in flow up top. But hey, they are available for anyone who decides that they want them!
Justin@Freektune (05-28-2015), Mauro_Penguin (05-28-2015), mxlplx71 (05-28-2015), Shwa (05-28-2015), Thepedigree13 (05-28-2015)
 Old 05-28-2015, 08:47 PM   #7
Shwa's Avatar
Posts: 322   (View Stats)
They seem to be releasing every size possible in the gtx line, maybe see more profits to be had.
Maybe on another platform this is the perfect turbo to max their block, who knows, more options are always good.
 Old 05-29-2015, 09:52 AM   #8
It really is just about giving more options. Some of these turbos are so close in size that you wouldn't notice the difference between them, but they just fill in the gaps between the bigger and the smaller turbos.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f539/gtx29-turbo-real-life-188951/
Gtx29 turbo.... Is this real life This thread Refback 09-24-2015 03:44 PM
Is this real life? Shwaykid CorkSport 22 04-22-2015 01:19 AM
Virtual Dyno VS Real Life Speeden6 MazdaSpeed 3/6 - Dyno Sheets/Discussions 6 06-19-2012 09:17 PM
Real-Life 'Alpha Dog' -- Murderer Haltech Celeberty Smut 2 07-08-2009 07:31 PM
Page generated in 0.29483 seconds with 27 queries
