 Old 11-24-2012, 09:21 PM   #1
I_Heart_Haters's Avatar
Posts: 1,446   (View Stats)
I_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the world
Groaned at 63 Times in 39 Posts
Default Insight CTS
I have been looking at different ways to monitor multiple things at once...boost, afr, fuel pressure, engine temp...etc.
I found this on Edge's website. Never heard of it before, but looks promising?
If anyone has it or has heard things about it let me know.
If not, what would you suggest to monitor multiple things at once.
2011 Liquid Silver Mazdaspeed3 w/ Tech Package : Corksport SRI # Corksport TIP # Corksport DP # Corksport CBE # JBR RMM # OBX Test Pipe # Turbosmart 50/50 BOV # KMD HPFP # Cobb Stage 2 # 20%/35% Tint
# Varrstoen ES7's 18x9.5 w/ 235/40/18 Continental Extreme Contact DWS # KSport Kontrol Pro Coilovers
I_Heart_Haters is offline   Reply With Quote
 Old 11-24-2012, 09:29 PM   #2
madspd6's Avatar
Posts: 1,009   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 31
Used dashhawk.
Velocity Red Mica 06 Speed6 (ricer) #834
Some shitty; s300sx fmw turbo, home made fmic setup, home made 4" Intake, 3.5 blowthrough maf, home made downpipe, poorly self tuned. More motor mounts then necessary.
Gay and coated white enkei rpf1s with stupid 245/45 tires. Pointless drilled and slotted rotors. Clunky coilovers. Ricer lips and lights.
madspd6 is offline   Reply With Quote
The Following User Says Thank You to madspd6 For This Useful Post:
I_Heart_Haters (11-25-2012)
 Old 11-25-2012, 07:13 AM   #3
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Originally Posted by madspd6 View Post
Used dashhawk.
Fail. DH doesn't work on PU's
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 11-25-2012, 03:37 PM   #4
madspd6's Avatar
Groans: 31
Too bad. More reason for me to not want one.
The insight looks pretty but is the cheaper one just a smaller screen?
 Old 11-25-2012, 03:42 PM   #5
Mclovin80's Avatar
Posts: 229   (View Stats)
Mclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the world
Go with an Aeroforce Interceptor
Sent from my Nexus 7
Mclovin80 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mclovin80 For This Useful Post:
madspd6 (11-25-2012), Speed3eak (11-27-2012)
 Old 11-25-2012, 10:48 PM   #6
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
UltraGauge
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
 Old 11-26-2012, 07:06 AM   #7
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groans: 148
Groaned at 89 Times in 51 Posts
I use torque with a good bluetooth adaptor and a android tablet.
Some say it records too slow, but I have not found that to be the case. Of course the only bluetooth connection I run is that+tablet. I turn bluetooth off on all other devices so there's no interference.
However, there's also wired ODB2 Connectors to iphones and ipads.
DiGi Faggot is offline   Reply With Quote
 Old 11-26-2012, 07:48 AM   #8
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
jesus, that insight CTS is stupidly expensive. buy an ultragauge for everyday use (won't show KR though) and log ocassionally with your AP to check KR..
ultragauge is only $70. if being able to always monitor KR is worth $330, go for it. otherwise, ultragauge is where it's at.
The Following User Says Thank You to tddvrrn For This Useful Post:
evil MS3 (11-26-2012)
New paint, need insight oh_yeams6 Mazdaspeed3/6 General Discussion 6 02-21-2012 04:52 PM
Edge Insight cs 59ksmall Mazdaspeed3/6 General Discussion 37 12-15-2011 03:41 AM
Fuel pump insight SFWD 1934 2010 MS3 - Fuel, Nitrous & Water Injection 22 04-02-2011 01:44 AM
Add insight into why my car runs like ass. TruboPower MazdaSpeed 3/6 - ECU Computer Tuning 12 03-01-2010 04:24 PM
Where did my power go? Need insight... PeterSellers MazdaSpeed 3 - Engine, Transmission & Driveline 12 09-10-2009 01:49 PM
Page generated in 0.29513 seconds with 26 queries
