| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
(Thread Starter) | Not Ranked : 0 score We hope you enjoy this install guide and find it helpful when installing yours. As always, ask us if you have any questions during install, we're here to help! Step 1: Locate the license plate area you will be working with. Usually, this is in the rear of the vehicle. Step 2: Using the appropriate screwdriver, remove either screw by inserting the flat end into the slot on head of the screw and rotating. Remember, righty tighty lefty loosey. Turn counterclockwise to remove the screw. A flathead or standard screwdriver is used in this particular install. Step 3: With the help of a friend, hold the license plate in place so that it doesn't fall down while removing the second screw. You don't want to scuff up the bumper paint. Remove the second screw. This is done in the same fashion as the first screw. Step 4: When reinstalling the license plate with the new frame. Make sure the orientation is correct. You don't want to draw any attention from the local authorities or have any girls laugh at you when they find out your frame is upside down. Step 5: Again, using the help of a friend, hold the license plate and frame in place and insert one of the screws in the place it was removed from. Now, use a clockwise movement from left to right to tighten down the screw. Don't tighten all the way! Allow for movement on the other side to line up the holes. Step 6: With the other side slightly loose, insert the second screw into the other side and tighten down, remember, clockwise. Now you can fully tighten the other side down. The end result should look like this. If it doesn't, trace your steps back to where you lost all hope, you might be going back to when you fell on your head as a child if you are having a hard time with this. Cheers!! The EdgeAutosport Team |
| The Following 23 Users Say Thank You to EdgeAutosport.com For This Useful Post: | Agent_Orange (02-17-2015), ArmanRus (02-17-2015), Bob-o (02-13-2015), Code Monkey (02-13-2015), CWP_MS3 (02-13-2015), cyclist20 (02-13-2015), Easter Bunny (02-17-2015), G Sp33dy (02-13-2015), g00s3y (02-17-2015), Ingle (02-14-2015), jack_hammer (02-14-2015), juxt3r (02-15-2015), kylejenson (02-13-2015), Mauro_Penguin (02-13-2015), mazdaspeedmyk (02-13-2015), Mr. T (02-16-2015), mr.speedy3 (02-13-2015), Rommel043 (02-17-2015), rymanmazda (02-14-2015), SofaKingAwesome (02-17-2015), swsmailman (02-16-2015), ThizSpeed3 (02-16-2015), trancehead (02-13-2015) |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| First. Lol
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post: |
![]() Join Date: Jun 2013 Location: Edmond, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,349
| Not Ranked : 0 score No carbon fiber option? WTF?! Also, what are the torque specs on those screws? So many good How To's, so few torque specs.
__________________ 2013 LSM Speed BNR S3v3 AP V3 Corksport: HPFP Internals, Injector Seals, bpv, battery box, intake manifold Full Race: Exhaust Manifold, ceramic coated for lovliness CNT:Catted DP Treadstone TR8 with Cobb piping CP-e: Stage II RMM HTP:3" intake Stratified: 3port, Guardian Angel JBR RSB, Shifter Bushings, EGR Delete/Blockoff Matt Damond:OCC, PMM, TMM UR Axleback Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers Tuned by PURPLE DRANK |
| The Following 3 Users Say Thank You to cyclist20 For This Useful Post: |
![]() Join Date: May 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score :O I finally figured out what I was doing wrong...
__________________ Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM Cobb SoCal tuned |
| The Following User Says Thank You to razerer For This Useful Post: | EdgeAutosport.com (02-13-2015) |
90 ftlbs I think. But it could be inlbs... Just know that our License plate frame warranty doesn't cover installer error. ![]() Good luck! | |
| The Following 5 Users Say Thank You to EdgeAutosport.com For This Useful Post: | cyclist20 (02-13-2015), Easter Bunny (02-17-2015), jack_hammer (02-14-2015), jdmage_mx5 (02-13-2015), Mauro_Penguin (02-13-2015) |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score But I haz speed3 and not ST
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following 3 Users Say Thank You to tegxsi For This Useful Post: |
![]() Join Date: May 2013 Location: CO
Rep Power: 2406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score I totally was looking for a "how to" to accomplish this task. Thank you for this nugget of knowledge. Can someone please now tell me which oil is best for my car? What about which lowering kit I can use to stance my ride? Thanks. In all honesty this was awesome and gave me a good chuckle. |
| The Following 2 Users Say Thank You to monkey.bones.007 For This Useful Post: | Easter Bunny (02-17-2015), EdgeAutosport.com (02-13-2015) |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score Thanks for clarifying the torque specs. I thought the bolts were torque to yield bolts and couldn't be re used.
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
| The Following User Says Thank You to macdiesel For This Useful Post: | EdgeAutosport.com (02-16-2015) |
| Banned ![]() Join Date: Jan 2015 Location: Space Mountain, Honey
Rep Power: 0 ![]() ![]() Thanks: 142
Groans: 30
Groaned at 132 Times in 57 Posts
| Not Ranked : 0 score Two days after I changed my last one, thieves at a trail head showed me how easy it was to remove it with a flat head, and steal the plate. They left the brand new chrome frame sitting on the bumper. Get the tamper-proof screws! |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score silver screws on a black frame?! 2/10, would not bang
__________________ it's fun to do bad things |
| The Following 4 Users Say Thank You to jack_hammer For This Useful Post: | Easter Bunny (02-17-2015), EdgeAutosport.com (02-16-2015), rymanmazda (02-14-2015), swsmailman (02-16-2015) |
(Thread Starter) | Not Ranked : 0 score That is what plastidip is for right? |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Subbed for windshield wiper install thread. Please tag me when created, I need help with those. Much appreciated.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following 3 Users Say Thank You to WetzMS3 For This Useful Post: |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Will this how-to apply to Mazda vehicles too?
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | Agent_Orange (02-17-2015), WetzMS3 (02-18-2015) |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score I learned from experience that if you prove an officer wrong two times in a row, he will write you up for these plate frames covering 1/3 of your tabs. Would be nice if they were notched in the corners. Cop: I pulled you over because you have no front license plate. Me: Yes I do, go take another look. (Plate mounted on tow hook) (Cop walks to front of car then turns around to come back to the window) Cop: Your window tint on the back window's is to dark. Me: Not according to the cop that pulled me over 3 month's ago for my front windows. I have a slip saying I'm legal with his badge number and phone number. You want it? Cop: Yes, let me see it. (Cop goes back to his car and comes back 5 minutes later) Cop: Im not going to argue with another cop about tint. I don't like how your license plate frame covers your tabs though. (hands me "fix-it" ticket) |
| The Following 2 Users Say Thank You to speed_freak91 For This Useful Post: | Easter Bunny (02-17-2015), EdgeAutosport.com (02-17-2015) |
![]() Join Date: Nov 2014 Location: Niagara Falls, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 108
| Not Ranked : 0 score LOL most helpful! I wonder if these frames fit a Canadian license plate.. |
| The Following User Says Thank You to tparker14 For This Useful Post: | EdgeAutosport.com (02-17-2015) |
![]() Join Date: Sep 2013 Location: Miramar, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 613
| Not Ranked : 0 score Sweet! Now if you guys could do an install guide with how to change my blinker fluid that would be perfect.
__________________ Alpine White/coral red 135i (N54) 24 psi, e70, catless downpipes, midpipes, axleback. FMIC and piping, synapse bov. G5 ISO board, e85 backend flash, stage 1 lpfp, turbo inlets, Federal 595 RSR-R tires. |
| The Following User Says Thank You to Mr. T For This Useful Post: | EdgeAutosport.com (02-17-2015) |
(Thread Starter) | Not Ranked : 0 score Yes but you have to look up the conversion chart online.
They fit but could throw off the conversion from mph to kph... | |
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | speed_freak91 (02-17-2015), tparker14 (02-17-2015) |
Groans: 438
| Not Ranked : 0 score How much hp does this add? Do I need to tune for it?
| The Following User Says Thank You to g00s3y For This Useful Post: | EdgeAutosport.com (02-17-2015) |
![]() | | #19 | ![]() |
![]() Join Date: Dec 2014 Location: Saint Johns, FL
Rep Power: 213 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score I'm mainly concerned about the weight of this mod. Will it throw off the balance? I already have my car tuned for my wife's big titties and don't want to jeopardize that in any way, whatsoever.
__________________ 2007 MS3 GT Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks 2006 MS6 GT (ZZB Rebirth) Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts 1990 Miata I like it raw |
| The Following 3 Users Say Thank You to sporkbomb For This Useful Post: |
![]() | | #20 | ![]() |
Groans: 549
| The Following 2 Users Say Thank You to jack_hammer For This Useful Post: | Easter Bunny (02-18-2015), WetzMS3 (02-18-2015) |
![]() | | #21 | ![]() |
| The Following User Says Thank You to monkey.bones.007 For This Useful Post: | EdgeAutosport.com (02-19-2015) |
![]() | | #22 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score I used a dremmel tool and notched out a section to fully expose my sticker. Will doing this result in an imbalance destroying the integrity of the frame? I don't want my plate falling off and cause a pile up behind me.
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Why you guys no use loctite? I thought it was a must...
![]() | | #24 | ![]() |
| Not Ranked : 0 score Typical ST owner.
| The Following User Says Thank You to Easter Bunny For This Useful Post: | WetzMS3 (02-18-2015) |
| JBR License Plate Frame Poll | JBR | JAMES BARONE RACING | 154 | 06-05-2013 06:28 PM |
| JBR License Plate Frame Development Thread | JBR | JAMES BARONE RACING | 187 | 03-26-2013 09:59 AM |
