  • 1 Post By tddvrrn
 Old 11-23-2012, 02:28 PM   #1
phahengpro's Avatar
Posts: 351   (View Stats)
phahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the worldphahengpro is the leader of the world
Default JBR rsb
Once again I sent the guys at Edge some of my cash. I am chasing the rear-end "clunk" on my MS3. The stealership said it was the rsb bushings or shocks. Not wanting to give them the money for the work or parts I bought a new rsb from Edge. JBR's stuff is always top-notched as are the Edge guys. It didn't take complete care of the "clunk" but it is better. I'll be ordering some Konis next.
MS3 traded in after VVT eruption
2013 WRX - no mods and slower
phahengpro is offline   Reply With Quote
 Old 11-23-2012, 02:35 PM   #2
claudio's Avatar
Posts: 128   (View Stats)
claudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond repute
Did you replace your endlinks yet?
claudio is offline   Reply With Quote
The Following 2 Users Say Thank You to claudio For This Useful Post:
kabobulate (11-23-2012), Raider (11-24-2012)
 Old 11-23-2012, 02:40 PM   #3
^this swaybar clunk is the endlinks not the sway bar itself
 Old 11-23-2012, 02:56 PM   #4
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
tighten them down as tight as you can, then another 1/4 turn. mine started clunking about 200 miles after i put it on, and i retightened it and have not had any issues since.
 Old 11-23-2012, 03:24 PM   #5
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
sometimes not so much. i still had the clunk after replacing bushings and endlinks.. then i bought a JBR RSB and my clunk is gone.
however, since the OP already replaced the RSB and bushings, @Easter Bunny; is spot on.
did anyone else laugh at this sentence?
Last edited by tddvrrn; 11-23-2012 at 03:24 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to tddvrrn For This Useful Post:
JBR (11-23-2012), Kdawg207 (11-23-2012)
 Old 11-23-2012, 03:31 PM   #6
exentix's Avatar
Groans: 46
Lol why?...
 Old 11-23-2012, 06:39 PM   #7
phahengpro's Avatar
Thanks for the input. I was just going by the dealership's diagnosis after a ride in it.
The Following User Says Thank You to phahengpro For This Useful Post:
tddvrrn (11-23-2012)
 Old 11-23-2012, 09:21 PM   #8
tddvrrn's Avatar
Groans: 103
Lol why?...
i just thought it was funny that you said to tighten it down as much as you can, implying that there is no way you'll be able to tighten it any more. then tighten it 1/4 turn more. even though you've tightened it as much as you can..
i know, it's stupid when it is explained, but the original sentence made me chuckle. thanks!
GunGuru727 likes this.
The Following User Says Thank You to tddvrrn For This Useful Post:
GunGuru727 (11-23-2012)
 Old 11-24-2012, 05:25 AM   #9
exentix's Avatar
Groans: 46
..ok lol I thought there was something else to it. That was the whole point I was trying to get across. Make sure its tight.
 Old 11-24-2012, 08:26 AM   #10
phahengpro's Avatar
I am going to pull the shocks today to see how they look. They don't bounce, but they seem to be bottoming out. Oklahoma roads are really shitty. I will give everything a twist for good measure.
 Old 11-24-2012, 10:46 AM   #11
speeda's Avatar
Posts: 114   (View Stats)
speeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond reputespeeda has a reputation beyond repute
Default RSB clunking
Had the same issue with JBR RSB clunking .Replaced Endlinks same issue after few days clunking back again. My permanent fix was by coincidence when I installed GTSPEC Rear Subframe Reinforcement Panel Part #: GTS-SUS-1429 that took care of it I have been running for a year now with no issues.
speeda is offline   Reply With Quote
The Following User Says Thank You to speeda For This Useful Post:
mroclimbr (01-14-2013)
 Old 11-24-2012, 11:35 AM   #12
phahengpro's Avatar
Thanks, I will keep that in mind.
 Old 11-24-2012, 02:15 PM   #13
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I've had the JBR rsb on for 6 months or so now, no clunks. I had some squeaks that were taken care of by greasing the bushings, but never a clunk. you really do have to tighten the shit out of the end links.
Blue Pu.
 Old 11-25-2012, 02:46 PM   #14
phahengpro's Avatar
I got down there and cranked them up as tight as I could. I didn't get to the shocks cause I opened up my thumb when I slipped a socket on the bottom nut. I am pretty sure they need to be changed. The ass seems to bottom quite a bit. I think I will go with the endlinks first as that is what many of you are saying, and they are cheaper to replace. I appreciate the advice!!!
 Old 01-14-2013, 08:50 AM   #15
phahengpro's Avatar
Front and rear endlink change=no more clunk. Put in some Moogs and fsb bushings and all is well. Thanks for the info!
Page generated in 0.35916 seconds with 25 queries
