  • 1 Post By axiom
 Old 07-02-2014, 09:51 AM   #1
Default Koni Sport Suspension Kits at EdgeAutosport!
You guys asked for them, now we have them!
Koni Sport Suspension Kits are in stock and ready to ship!!
Koni has combined with H&R springs to provide you with the perfect upgrade over stock suspension. If you are wanting better performance than stock with a slightly lower ride height but don't want to get too crazy with coilovers, then these kits are for you.
With this kit, you can expect big handling improvements as well as a reasonable ride quality. The Koni shocks are rebuild-able for custom setups and paired for an excellent match up with the H&R Springs.
Koni STR.T Suspension Kit MS3
The STR.T kits are going to be geared more for street driving but still give you a nice drop on the h&R springs.
RICE:
Koni STR.T Suspension Kit MS3 2010-2013 - $509.60
Koni Sport Suspension Kit MS3 2010-2013 - $750.40
Koni Sport Suspension Kit MS3 2007-2009 - $750.40
In stock and ready to ship!
 Old 07-02-2014, 04:02 PM   #2
axiom's Avatar
Posts: 36   (View Stats)
axiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to beholdaxiom is a splendid one to behold
Koni STR.T look like a great and cost effective stock replacement, not available on Gen 1?
getemslough likes this.
axiom is offline   Reply With Quote
 Old 07-02-2014, 04:34 PM   #3
Hal
Hal's Avatar
Posts: 233   (View Stats)
Hal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the worldHal is the leader of the world
That's a ridiculous deal as long as the springs don't give the GenPu saggy ass.
www.emeraldtuning.com
twittter: @emeraldtuning
YouTube: https://www.youtube.com/user/EmeraldTuning
2013 CWP w/ Tech
JBR Shortie
JBR TIP
JBR Boost Tubes
JRB RMM
JBR RSB
JBR 5mm Spacers
JBR Heavy Shift Knob
JBR Flaps
Buddy Club Custom 3" Exhaust
Koni Yellows
Corksport 4-Piston Brake Upgrade
Corksport Springs
Corksport Adjustable End Links
Stoptech Slotted
Stoptech Sport Pads
Stoptech SS Lines
Hal is offline   Reply With Quote
 Old 07-02-2014, 04:52 PM   #4
getemslough's Avatar
Posts: 163   (View Stats)
getemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the worldgetemslough is the leader of the world
@EdgeAutosport.com
i am also curious about this
---2009 CWP---ATP GTX2867r---COBB AP V3---CS HPFP---CS BERYLLIUM/COPPER INJECTOR SEALS---SELF PORTED INTAKE MANIFOLD---CS 3.5 SRI---
---PROTOTYPE XSPOWER V3 IWG MANIFOLD (BETA TESTER)---CS CATTED DP---CNT CATBACK---RPM/CX FMIC PIPING---TREADSTONE TR8---
---GRIMMSPEED 3 PORT EBCS---3BAR MAP/RPM HARNESS---NGK 6510---JBR 51R TRAY---3P/HKS SSQV IV---CS RECIRC TUBE---KOZMIC OIL DRAIN---KOZMIC EGR DELETES---
---JBR TB/IM TIGS---CS PMM---CS RMM---CS OCC---CS SKID PLATE---
---CS STEERING WHEEL---CS SHIFTER BUSHINGS---SURE SHORTCUT---JBR SHORT SHIFT LEVER---SURE AGS 621g---SURE AGS EXTENDER---
---KONI STR.T---H&R SPRINGS---PROGRESS RSB---MOOG ENDLINKS---17X9+45 RPF1---5MMSPACERS---255/40/17 NITTO NT555---JBR FLAPS---
--GTX BUILD COMPLETE--
--FREEKTUNE 383/404 ON PUMP--
--METH COMING SOON--
getemslough is offline   Reply With Quote
 Old 07-02-2014, 05:07 PM   #5
Matt H.'s Avatar
Posts: 137   (View Stats)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Is that a different spring for the STR.T kit. If so does this also mean there may be two different ride heights between the kits???
Matt H. is offline   Reply With Quote
 Old 07-02-2014, 11:58 PM   #6
msantana101's Avatar
Posts: 1,517   (View Stats)
Any idea how much these kits lower the vehicle? Primarily the STR.T?
FreekTuned
 Old 07-03-2014, 08:02 AM   #7
Originally Posted by getemslough View Post
@EdgeAutosport.com
Unfortunately the STR.T Kits are not available for the first gen's according to Koni. I don't know why though because they have the rear struts for the first gen and thats the only thing that is different. I'm sure the springs are a little different too though.
They will give you about a 1.5" drop all around.
msantana101 (07-03-2014)
 Old 07-03-2014, 09:17 AM   #8
I have a set of H&R springs already on the car and the rears sag a bit. Any idea if the springs that come with this kit are the same ones that are already out for our cars, or are they completely different/new?
FreekTuned
 Old 07-03-2014, 11:44 AM   #9
I think they are the same springs that are already available.
 Old 07-03-2014, 12:10 PM   #10
manila's Avatar
Posts: 1,767   (View Stats)
Anyone have any experience running the SRTs?
I wonder if its worth the extra for the adjustability?
This deal is a steal!
'12 MS3 Black Mica w/ Tech
 Old 07-08-2014, 05:18 PM   #11
Unfortunately, Koni says that the STR.T kits are not going to be available for the first Gen speed 3.
 Old 07-08-2014, 08:59 PM   #12
smelvinwrong's Avatar
Posts: 150   (View Stats)
smelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond reputesmelvinwrong has a reputation beyond repute
Groaned at 3 Times in 1 Post
Booo.. wouldve gotten a set myself if it was
09 CWP Speed3
COBB SRI / CPE RMM / TWM Short Shifter / Apex'i Turbo Timer
smelvinwrong is offline   Reply With Quote
 Old 07-09-2014, 08:27 AM   #13
Yeah, I'm not sure why they are not making it for the Gen 1. You could probably make the kit work for the Gen 1 as I believe you would just need a shorter bolt for the strut. But then I'm not sure if there would be any differences in spring rates for the different model years.
Precision Turbo Kits at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 601 07-03-2015 09:53 AM
V2 AEM Meth Kits at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 10 03-31-2014 03:56 PM
Koni Sport Suspension Kit boardjnky4 MazdaSpeed 3/6 - Suspension & Brakes 91 12-02-2010 08:11 PM
Koni Sport Suspension Kit for MS3 bergj1986 MazdaSpeed 3/6 - Suspension & Brakes 2 04-07-2010 07:27 AM
Page generated in 0.34036 seconds with 27 queries
