| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
9Likes ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, you read that right! Kozmic just released a downpipe that fits the Precision Turbo V-band discharge. What does that mean you ask? That means that running a Precision Turbo on your Mazdaspeed 3 just got a thousand times easier! Now there is a way to pretty much make a Precision turbo a bolt on turbo with no fabrication necessary. And yes, I'm about to tell you how. cp-e offers a precision flanged version of their LRT Exhaust Manifold - $854.05 Kozmic offers an Oil Return Line as well as an Oil Feed Line for a Precision Turbo. - $199.98 for both Kozmic also offers a 44mm Dump tube that fits with cp-e manifold and their downpipe and a Tial MVR 44mm Wastegate. - $139.99 ($519.98 with the MVR WG) And last but not least you just need to pick up any Precision Turbo with a V-band Turbine Inlet and Outlet. Total for the parts not including the turbo or intake (of which there are several choices). Manifold - $854.05 Downpipe - $539 Oil Feed/Return - $199.98 Dump Tube - $139.99 44mm WG - $379 Total: $2112.02 All this together makes for an awesome Turbo setup at a bargain price considering what you get. Let me know if you have any questions! |
| The Following 17 Users Say Thank You to EdgeAutosport.com For This Useful Post: | 2.0t03speed (02-15-2014), 802MS3 (02-17-2014), alexryan (02-15-2014), Amnesiac (02-15-2014), atvfreek (02-17-2014), daafisch (02-15-2014), Hammology (02-17-2014), ms3blackmica (02-15-2014), ms3driver213 (02-15-2014), msantana101 (02-15-2014), NCspecV81 (02-17-2014), SarcasticOne (02-15-2014), smoogs12 (02-17-2014), speed3 britz (02-17-2014), SpeedRebirth (02-15-2014), speed_freak91 (02-17-2014), xTRELLx (02-17-2014) |
![]() Join Date: Feb 2012 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
| Not Ranked : 0 score That lumberjack setup! Sent from my iPhone using Tapatalk
__________________ FreekTuned |
| The Following User Says Thank You to msantana101 For This Useful Post: | EdgeAutosport.com (02-15-2014) |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Kozmic stepping up!
__________________ 417whp 428tq 12.037@117.2mph |
| The Following User Says Thank You to Snyeed For This Useful Post: | EdgeAutosport.com (02-15-2014) |
![]() Join Date: May 2012 Location: West Hempstead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 572
__________________ //2012 Black Mica Mazdaspeed 3// //Sure Torq R3//Cobb AccessPort//Autotech Internals//Ultimate Racing Axelback//Resonator Delete//Ebay Catless DownPipe //TR8L & Protege Garage piping//Devils Own Stage 1//NGK One Step Colder(failed) Denso ITV22//GoFastBits Blow Off Valve//Ksport Coilovers //GTX 2867r//Protege Garage Externally Gated Manifold//Precision Turbo Wastegate//Bosh 3 Bar Map//HTP 3.5" Full Intake //Grimmspeed 3 Port//Cobb Wastegate Lockout//Selfmade Screamer Pipe//ACT 6 puck w/ streetlite flywheel // R3X Tune in Progress (self tune) 310whp 354wtq (CF 1.01) w. DO7 KO4 ......GTX2867r 22psi: 357whp 353wtq (CF1.01) Needs installing: JBR BSD kit, OCC |
![]() Join Date: Jul 2011 Location: NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 66
| Not Ranked : 0 score Top notch edge, top notch...fucking tits sent while riding Pegasus through the fiery depths of tartarus
__________________ You're probably the idiot that goes wot in 6th gear at 2000 rpm |
| The Following 2 Users Say Thank You to ms3driver213 For This Useful Post: | alexryan (02-15-2014), EdgeAutosport.com (02-17-2014) |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Edge, Could you guys find out if this downpipe will fit properly for those who want to go with a Garret turbo and utilize the Tial V-Band hotside with the CP-e manifold?
__________________ www.tunedbynishan.com |
| The Following 2 Users Say Thank You to ms3blackmica For This Useful Post: | EdgeAutosport.com (02-17-2014), smoogs12 (02-17-2014) |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
| [Q UOTE=ms3blackmica;2455275]Edge, Could you guys find out if this downpipe will fit properly for those who want to go with a Garret turbo and utilize the Tial V-Band hotside with the CP-e manifold?[/QUOTE] From my understanding these will not fit on the flange aspect. Tial, Garrett, and precision all use there own "style" vband flange. This down pipe was specifically fabricated for the precision vband inlet outlet turbos on a cpe ltr exhaust manifold. I'm not saying it might not work on another style setup utilizing a precision turbo. This down pipe is top quality, welds, design, bung placements this is one of if not the nicest production down pipes for our cars. Sent from my iPhone using Tapatalk
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
| The Following 3 Users Say Thank You to LumberJack For This Useful Post: |
| Not Ranked : 0 score I know that. What I meant was if the DP can be made to order with the appropriate flange. The tial hotside and precision Vband hotsides are not very different in size and geometry and considering the CPe manifold places them in the same location, it may work. Hoping to find out.
| The Following 5 Users Say Thank You to ms3blackmica For This Useful Post: | 2.0t03speed (02-15-2014), atvfreek (02-17-2014), EdgeAutosport.com (02-17-2014), LumberJack (02-15-2014), smoogs12 (02-17-2014) |
I don't see why they wouldn't offer it with a different flange. David at Kozmic is an awesome guy, he can talk your ear off if you'd let him . Sent from my iPhone using Tapatalk
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 | |
| The Following 2 Users Say Thank You to LumberJack For This Useful Post: | 2.0t03speed (02-15-2014), atvfreek (02-17-2014) |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score No speed6 love again? tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() Join Date: Jun 2013 Location: Anchorage, AK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 164
Groaned at 27 Times in 14 Posts
Sent from my SAMSUNG-SGH-I337 using Tapatalk | |
| The Following User Says Thank You to xTRELLx For This Useful Post: | EdgeAutosport.com (02-17-2014) |
![]() Join Date: Aug 2013 Location: Jefferson, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 516
| Not Ranked : 0 score I have this setup, I purchased it from David... @EdgeAutosport.com; The kozmic primary egr block off is also necessary to make this whole setup fit. And as far as this dp working with a Garrett turbo idk if it would happen. These pte turbos sit alot lower than the Garrett's. @ms3blackmica; Your also going to have to either chop a exhaust manifold stud or use a bolt instead on one of the studs on the egr side for the compressor housing to fit. You will have to remove both heat shields off the alternator as well for the pipe to fit, I would highly suggest wrapping the down pipe and the dump tube to keep temps down. My hot pipe was also custom fabricated to fit the pte turbo it sits alot lower like I said. As far as the downpipe, dump tube, oil feed & return lines everything is top notch quality on kozmic's part and David is a great guy to do business with.
__________________ OMWTFYB Last edited by darkstar5440; 02-17-2014 at 07:48 AM. |
| The Following 4 Users Say Thank You to darkstar5440 For This Useful Post: | 2.0t03speed (02-17-2014), atvfreek (02-17-2014), EdgeAutosport.com (02-17-2014), xTRELLx (02-17-2014) |
From my understanding these will not fit on the flange aspect. Tial, Garrett, and precision all use there own "style" vband flange. This down pipe was specifically fabricated for the precision vband inlet outlet turbos on a cpe ltr exhaust manifold. I'm not saying it might not work on another style setup utilizing a precision turbo. This down pipe is top quality, welds, design, bung placements this is one of if not the nicest production down pipes for our cars. Sent from my iPhone using Tapatalk[/QUOTE]
So to recap, it ONLY fits with the Precision Vbands, you must delete the EGR completely (which Kozmic has a solution for, Primary EGR Delete), and you do need a shorter stud like mentioned before. We'll make sure we take care of people when they order this and make sure they know what's going on. -JP | ||
| The Following 3 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
| Not Ranked : 0 score Your better off using a bolt instead of a shorter stud or cutting the existing stud but either will work. And you will have a issue with your hot pipe. Sent from my iPhone using Tapatalk
__________________ OMWTFYB |
![]() Join Date: Jul 2013 Location: Sacramento, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 382
;P
__________________ - Bryan '08 MS3 CWP BNR s3 // Corksport; SRI, TIP // COBB AP V3 // Autotech internals // Weapon R; 3" DP, 3" TP, Secret Weapon Air Filter // Grimm Speed EBCS // HKS SSQV BOV // JBR BSD // ACT 6 puck w/ Prolite FW // Escort Max // Bosch 3 bar MAP // FreekTune in progress Corksport; RSB, Shifter Bushings // Ground Control; coilover kit, camber plates // JBR; Trilogy, EGR delete, Battery box, TIIG, TITG // Weapon R OCC // Motegi MR 125 18x8 +45 // Potenza S-04 Pole Position 235 // Eibach 5mm spacers // Stoptech slotted rotors // TWM; SSP, Competition Series 7" knob // Ralco RZ STS // Hawk HPS // Goodridge SS lines // ARP studs // Cometic HG Corksport; lic plate kit, fog light kit // RallyArmor flaps // HD lip // Whispbar roof rack // Yakima Load Warrior // trailer hitch [SIGPIC][/SIGPIC] | |
| Not Ranked : 0 score Wow...it seems I am sent while riding Pegasus through the fiery depths of tartarus
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | LumberJack (02-17-2014) |
![]() Join Date: Jul 2008 Location: Sunrise, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,592
Groaned at 24 Times in 24 Posts
| Not Ranked : 0 score This. Come on guys. We're still around -___- Sent from my Galaxy S3 using FuckThisShit
__________________ Wanna know if those wheels you found will fit your ride? Click HERE to find out!! |
| The Following 3 Users Say Thank You to Koenig For This Useful Post: |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Dude look at the picture, does it look long or short??? Does it look like it has a cat? Lol Sent from my iPhone using Tapatalk
| The Following 5 Users Say Thank You to darkstar5440 For This Useful Post: | 802MS3 (02-17-2014), Hanzodurrr (02-17-2014), LumberJack (02-18-2014), Sterling (02-21-2014), xTRELLx (02-17-2014) |
![]() | | #21 | ![]() |
| The Following User Says Thank You to xTRELLx For This Useful Post: | Koenig (02-17-2014) |
![]() | | #22 | ![]() |
Here is the link. Kozmic Motorsports Downpipe for Precision Turbo VBand | |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | xTRELLx (02-17-2014) |
![]() | | #23 | ![]() |
Sent from my SAMSUNG-SGH-I337 using Tapatalk Last edited by xTRELLx; 02-17-2014 at 04:36 PM. Reason: MSF Database - Automerged Doublepost | ||
| M2 Downpipe V-band gasket | Cameron Letcher | Mazdaspeed3/6 General Discussion | 7 | 02-01-2018 06:31 AM |
| ms3 v-band downpipe | 2008_zoomzoom | Mazdaspeed3/6 General Discussion | 18 | 09-30-2013 12:48 PM |
