Like Tree7Likes
  • 2 Post By EdgeAutosport.com
  • 2 Post By Micha
  • 1 Post By WetzMS3
  • 2 Post By Code Monkey
 Old 03-18-2015, 11:22 AM   #1
Default Kozmic Parts are In Stock!!
There are a lot of parts that we like to keep on the shelves and Kozmic is one of them. So when you order Kozmic through us it can ship the same day. We place regular stocking orders so that all the parts that are available from Kozmic are on our shelf and ready to ship!
For example...
We've got Catch Cans for both first and second gen speed 3.
We've Got Precision Downpipes for the Speed 6 and more for the 3 on the way.
We also have EGR Deletes!
Dump tubes for speed 6 and 3.
And finally, we've got Oil Lines!
If you need Kozmic, we've got it!
kashbringer and WetzMS3 like this.
Micha (03-22-2015), The Nut (03-22-2015), WetzMS3 (03-23-2015)
 Old 03-22-2015, 09:33 AM   #2
Micha's Avatar
Posts: 3,436   (View Stats)
Love it all.
I am slow again.
I modded it a little.
The Following 2 Users Say Thank You to Micha For This Useful Post:
EdgeAutosport.com (03-23-2015), WetzMS3 (03-23-2015)
 Old 03-23-2015, 01:03 PM   #3
Love it all.
Yeah, they make some really good stuff! Just need some precision flanged cp-e manifolds and we'd have complete PTE turbo kits...
Micha (03-24-2015)
 Old 03-23-2015, 01:40 PM   #4
Two weeks.
EdgeAutosport.com (03-24-2015), Micha (03-24-2015)
 Old 03-23-2015, 02:29 PM   #5
Silverdecepticon's Avatar
Posts: 277   (View Stats)
Silverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond repute
Has anyone developed a oil return for the MS6? Mine is a McGuyver job and I need to revisit the line as it tends to leak....
06 MS6
GTX3076R, Xs power exhaust manifold(suxs), ebay dp(sux), 3" catless exhaust, 4" HTP TIP, Sure shortshift & counterbalance, COBB V3, Autotech HPFP internals, Grimmspeed EBCS, CP-e RMM, Perm PCV plate, JBR EGR delete, JBR BSD, JBR Oil pan baffle plate, Kozmic OCC, rebuilt fuel injectors, safeseal injector seals, Bosch 3 bar MAP, new gaskets(valve cover, throttle body, intake manifold, exhaust manifold, dp), cleaned valves and chambers, CP-E motor mount & rear-diff mount, ATP-INT-003 FMIC, Stratified Guardian Angel set to 24psi, Stoptech rotors, Hawk HPS pads, Forge BPV, home-made strut mounted tower bar, badgeless, special edition 19" anniversary rims. Battery finally relocated to trunk with custom box. New VVT stuff, BC coilovers, new OEM Clutch, fidenza lightweight flywheel, replaced driveshaft again, replaced power steering pump again, busted rear diff side bolts again....FML
Silverdecepticon is offline   Reply With Quote
The Following User Says Thank You to Silverdecepticon For This Useful Post:
Micha (03-24-2015)
 Old 03-23-2015, 02:38 PM   #6
Nope, this is why I am extremely disappointed in the Kozmic "kit" for the MS6, my understanding was that they would fab an oil return line for us.
Micha (03-24-2015)
 Old 03-24-2015, 09:02 AM   #7
Yeah, we were hoping for that too. They told me why they weren't doing it but I can't remember the reason. I think it had something to do with a fitting they needed for it not being available and cost to machine said fitting being way to high.
Micha (03-24-2015), WetzMS3 (03-24-2015)
 Old 03-24-2015, 10:22 AM   #8
Micha's Avatar
And because when they installed my kit they vowed to never do another one again on a speed 6. LOL.
Kozmic was glad when my car got picked up and left.
Code Monkey and WetzMS3 like this.
I am slow again.
The Following 4 Users Say Thank You to Micha For This Useful Post:
Code Monkey (03-24-2015), EdgeAutosport.com (03-24-2015), Mauro_Penguin (03-24-2015), WetzMS3 (03-24-2015)
 Old 03-24-2015, 11:09 AM   #9
That's lame as fuck. Why did Edge even send that line then? Total waste of time.....buuuut I'm sure they knew that.
06 MS6
 Old 03-24-2015, 11:27 AM   #10
Neutral  +1 score
I will be there in person Saturday, will tell them to the face what I think of it.
Mauro_Penguin (03-24-2015), Micha (03-28-2015), Silverdecepticon (03-24-2015), WetzMS3 (03-24-2015)
 Old 03-24-2015, 11:36 AM   #11
They'll tell you its not an Evo, so zero fucks given. Do it anyway though.
Mauro_Penguin likes this.
Code Monkey (03-24-2015), EdgeAutosport.com (03-24-2015), Mauro_Penguin (03-24-2015), Micha (03-28-2015)
 Old 03-24-2015, 11:50 AM   #12
Neutral  +1 score
^ Yeah, but at least my blood pressure will drop for a few minutes after the tirade.
WetzMS3 and Silverdecepticon like this.
EdgeAutosport.com (03-24-2015), Mauro_Penguin (03-24-2015), Micha (03-28-2015), WetzMS3 (03-25-2015)
Page generated in 0.34286 seconds with 24 queries
