| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
(Thread Starter) | Not Ranked : 0 score JP could you or Eric please see if you can find the KW V3 rear spring rate for me. I searched high and low on the net and have only found they are progressive. I know once the springs are static loaded they are linear and I'd like to know what they linear rate is. Once my build is done I guess you know what I'm getting next . . . . -Paul
__________________ Fueled by the haters. |
| The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post: | EdgeAutosport.com (03-09-2012), JP@edgeautosport.com (03-09-2012) |
| Approved MSF Vendor ![]() Join Date: May 2010 Location: Denver, CO
Rep Power: 1280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 906
| Not Ranked : 0 score Well this thread sure did sneak right past us didn't it? 400lb on the front but they don't release progressive rates because it has to do with where the ride height is set at. |
(Thread Starter) | Not Ranked : 0 score Thanks JP, I think, I'm going to use the rear springs from the Teins in the rear and the rest will be the V3 setup. This way I have linear 400lbs in the front and rear without going to custom.
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score I don't buy that the rear rate depends on the ride height, because you're not really preloading anything when you change the height in the rear. For all intents and purposes, when the weight of the car is resting on those rear springs, they are linear.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | Celestspeed3 (03-09-2012) |
(Thread Starter) | Not Ranked : 0 score Thank you, but everyone I ask gives me the same story. Its progressive, well I know that but once the chassis is settled the springs are linear and I want to know that rate.
| The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post: | JP@edgeautosport.com (03-09-2012), Nliiitend1 (03-10-2012) |
| Not Ranked : 0 score I'm going to pry KW on Monday and find this out for you. They can't make a spring and not know the technical info for it. |
| The Following User Says Thank You to JP@edgeautosport.com For This Useful Post: | Celestspeed3 (03-09-2012) |
| Not Ranked : 0 score Oh I understand completely. I'm just pointing out that the statement that claims that the rate depends on ride height in this application is patently wrong.
(Thread Starter) | Not Ranked : 0 score Either way you are still suppling the coils
| The Following User Says Thank You to Celestspeed3 For This Useful Post: | EdgeAutosport.com (03-10-2012) |
| Ms6 does anyone know stock spring rates and aftermarket rates? | darkcherry | MazdaSpeed 3/6 - Suspension & Brakes | 7 | 12-16-2011 03:31 PM |
| Spring Rates | tavio025 | 2010 MS3 - Suspension & Brakes | 1 | 10-04-2011 09:32 PM |
| Gen1 vs Gen2 Stock Spring Rates | Boother | MazdaSpeed 3/6 - Suspension & Brakes | 7 | 02-18-2011 09:26 PM |
| Coilover Spring Rates? | JMEngineer | MazdaSpeed 3/6 - Suspension & Brakes | 0 | 06-02-2009 11:25 PM |
