| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
(Thread Starter) | Not Ranked : 0 score Just wanted to let you guys know that we now carry the line of Manley Turbo Tuff Pro Series I-Beam Rods The Pro Series I-Beam rods are forged from 4340 aircraft quality vacuum degassed material. They are shot peened after machining and 100% magnafluxed. All Manley Connecting Rods are weight matched to +/- 1.5 grams and big and small end bores are final honed to a tolerance of +/- .0002". You have a choice between 22 and 22.5 (stock) mm wrist pins as well as ARP 2000 and ARP 625+ rod bolts. Manley Turbo Tuff Pro Series I-Beam Rods w/ ARP 625+ - $972.60 Manley Turbo Tuff Pro Series I-Beam Rods w/ ARP 2000 - $810 |
| The Following 7 Users Say Thank You to EdgeAutosport.com For This Useful Post: | ABolewski (11-18-2013), atvfreek (11-14-2013), LumberJack (11-17-2013), ms6mil (11-14-2013), Realgib3 (11-14-2013), rymanmazda (11-14-2013), taf0422 (11-14-2013) |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
| Them are some sexy rods
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 |
| The Following User Says Thank You to LumberJack For This Useful Post: | EdgeAutosport.com (11-18-2013) |
| Not Ranked : 0 score So what is the difference between the I beam and H beam "economical" rods they sell?
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 | |
| The Following 4 Users Say Thank You to LumberJack For This Useful Post: | atvfreek (11-18-2013), BigRedSpecial (11-18-2013), EdgeAutosport.com (11-18-2013), Realgib3 (11-18-2013) |
| Not Ranked : 0 score Most companies sell the h beam as the stronger rod and without actual dimensions we can't infer this. The description on the site labels the h beam as economical without giving any specs.
(Thread Starter) | Not Ranked : 0 score I believe it has to do with how and where the rods are made. I believe the I-beams are made in America while the H-beams are farmed out to somewhere else. They are likely made along side K1 and eagle rods. |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score Doesn't Carrillo offer an I beam as a stronger alternative to their H beam?
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
| The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post: | EdgeAutosport.com (11-18-2013), LumberJack (11-18-2013) |
| The Following 2 Users Say Thank You to LumberJack For This Useful Post: | BigRedSpecial (11-18-2013), EdgeAutosport.com (11-18-2013) |
| Well, I tried calling Manley to get a better explanation on this and I referred him to that picture I posted since he had actually seen that comparison online on the corvette forums where I found it. He said it is a very good example and the representation of difference in design and showing how strength is actually different between the 2
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 Last edited by LumberJack; 11-18-2013 at 11:03 AM. Reason: Doublepost |
Groans: 56
| Not Ranked : 0 score You're right, I was thinking of the A beams.
| Not Ranked : 0 score Carrillo makes a lower power rating A beam. These rods are also A beams as they flare out near the big end.
| The Following User Says Thank You to Lex For This Useful Post: | LumberJack (11-18-2013) |
(Thread Starter) | Not Ranked : 0 score I've always thought they were more like A-Beams, but Manley calls them I-Beams so thats what we sell them as. |
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | ABolewski (11-18-2013), LumberJack (11-18-2013) |
| Yeah, I agree. Every company sells them differently there is no "industry" standard name for rods. The turbo Tuffs are I beam, they look like the Carillo A beams. Then the Manley I beams are there highest rated rods, and Carillo rates there H beams higher than there A beams.
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
__________________ ![]() [SIGPIC][/SIGPIC] |
| MANLEY H BEAM RODS | SPEED6 KILLAH | Mazdaspeed3/6 General Discussion | 40 | 04-18-2015 03:26 PM |
| Manley "turbo tuff" I-Beam connecting rods *oem replacements | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 02-12-2009 04:40 PM |
