 Old 02-20-2014, 10:31 AM   #1
Default Mazda OEM Clutch Kit at EdgeAutosport!
Lets face it. The Mazdaspeed 3 and 6 were blessed from the factory with a pretty decent clutch. While it does depend on what you do with it and how you drive on it, in most cases the OEM Clutch will hold some pretty decent power and torque and last a decently long time. And there are a lot of people on higher mileage Mazdaspeeds that are wearing out their clutch more from time than power and don't really want to pay close to $1k for an upgraded clutch that will hold crazy amounts of power that they don't have or want. So the solution is simple. Just get another factory clutch. We get calls, emails, and PM's all the time asking what parts are needed when replacing the factory clutch so we decided to make it simple and create a Mazda OEM Clutch Kit for the MS3/MS6.
The kit includes the following:
Mazda OEM Pressure Plate
Mazda OEM Clutch Disc
Mazda OEM Release Bearing (throwout bearing)
Mazda OEM Pilot Bearing
Mazda OEM Flywheel Bolt x6
And you have an option to add the OEM Flywheel or the Fidanza Aluminum Flywheel (recommended to save cost). You may also want to add in the ACT Alignment Tool to help with the install.
The kit starts at $423.36 for just the clutch.
Click HERE to purchase from our website.
I hope this makes it easier on some of you guys who are just looking to replace your factory clutch!
The Following 16 Users Say Thank You to EdgeAutosport.com For This Useful Post:
8.5MS3 (03-19-2014), 802MS3 (03-08-2014), Amnesiac (03-14-2014), BruhhWill (02-20-2014), BZiggy10 (02-20-2014), Cheapspeed (03-15-2014), chomorro (03-18-2014), cnoon (05-02-2014), dan7225 (02-20-2014), magicka (02-20-2014), Polish_Eagle (04-07-2014), RageATL (03-14-2014), smelvinwrong (03-19-2014), speed3 britz (03-19-2014), SpeedRebirth (04-07-2014), WetzMS3 (03-14-2014)
 Old 03-14-2014, 09:25 AM   #2
I've talked to a few people this week that needed a clutch but were not making the power or wanting spend the money needed for an upgraded ACT or spec clutch. That's where this guy comes in. The OEM clutch is perfectly capable of holding some decent power. And not everyone needs an ACT 6 puck or a Spec Stage 3 clutch...
8.5MS3 (03-19-2014)
 Old 03-18-2014, 10:58 AM   #3
chomorro's Avatar
Posts: 667   (View Stats)
chomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the world
Does the fidanza flywheel create and extra drive train noise?
2009 Subaru WRX STI Hatchback
2007 GTI - Package 2 w/ Nav - Dieselgeek Short Shifter / TWM Weighted Etched Shift Knob / AWE 2.5" Turbo Back Exhaust w/Metal Cat / APR Stage 2+ Tune / APR Flapper Delete / APR HPFP / Vogtland 2" Springs / R8 Coils / NGK Iridium / P3Cars Digital Vent Gauge / 18" OEM Detroit Rims (SOLD)
2007 Speed 3 - Stratified Tuned with bolts ons (SOLD)
chomorro is offline   Reply With Quote
 Old 03-19-2014, 10:47 AM   #4
It is going to be a little bit louder than the factory flywheel but it shouldn't be too bad.
 Old 03-19-2014, 11:00 AM   #5
speed3 britz's Avatar
Posts: 1,155   (View Stats)
How does this compare to the LUK+Fidanza clutch combo?
 Old 03-19-2014, 11:12 AM   #6
I'm not familiar with the LUK clutch kit other than what I've seen on ebay.
 Old 04-04-2014, 03:21 PM   #7
08ms3grey's Avatar
Posts: 69   (View Stats)
08ms3grey is infamous around these parts
Groaned at 34 Times in 13 Posts
I noticed owhen i was on the highway tosay...i dropped the car back to 5th and noticed once in higher rpm it felt like the clutch was slipping then into 6th and the samething happened, i'm assuming its the clutch starting to go. If thats the case would i actually need the complete kit or would just the clutch be enough?
SOrry if thats a general question.
08ms3grey is offline   Reply With Quote
 Old 04-07-2014, 11:53 AM   #8
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
Luk is the same as OEM...
redboat is offline   Reply With Quote
 Old 04-07-2014, 04:12 PM   #9
As long as your flywheel is in good condition, you will probably be ok just replacing the clutch disk and pressure plate.
Clutch Masters Twin Disc Clutch Kit now Available at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 67 03-17-2015 03:39 PM
ACT Clutch at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 6 05-08-2014 04:15 PM
Clutch disc snapped - new CM clutch experience Absolut1l MazdaSpeed 6 - Engine, Transmission & Driveline 4 05-08-2013 05:07 AM
Will a DIY clutch adjustment help a slipping clutch? Greekfreak MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-20-2012 05:53 PM
REPORT: NHTSA investigating Ford F-150 airbags, Mazda RX-8 clutch pedals Haltech Automotive News 0 10-06-2009 08:30 AM
Page generated in 0.30894 seconds with 24 queries
