Like Tree3Likes
  • 3 Post By JP@edgeautosport.com
 Old 10-29-2012, 12:51 PM   #1
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Default METH/WATER INJECTION - How it works
Alan over here at EdgeAutosport wrote a great, quick write-up on methanol/water injection for the Subaru guys so I thought I'd copy and paste here. Read...
Here is a little info on water/meth injection that may help explain what is going on in the motor when you inject the mixture.
Injecting water can provide a number of benefits. Most people know that it helps when you are limited to running lower octane fuels, but I want to talk about why it helps. During combustion, the water is converted to steam. This conversion pulls heat out of the combustion process and slows down the rate that pressure in the cylinder rises. The steam particles that are created get in the between the fuel and oxygen molecules which also helps slow down the combustion and pressure rise rate. Meanwhile the piston is moving towards TDC (top dead center), squeezing the gases together. But, since there is less heat in the chamber and slower pressure rise, detonation is far less likely to occur. As the piston starts its descent a controlled burn continues, but the combustion flame now has to dodge around steam molecules plus an increasing number of exhaust molecules to get to fuel and oxygen molecules.
Now lets take a look at what meth brings to the table (besides making a lot of money but causing a ton of problems for certain high school chemistry teachers that is) /breaking bad reference
Methanol has a very high latent heat of vaporization compared to gasoline, but much lower compared to water. Because it vaporizes at a much lower temperature than water, the meth will pull heat from the intake tract, the piston crown, and the intake and exhaust valves where the temperatures are much cooler than that of the combustion event (where the water comes into play). Because internally, the engine is cooler, less heat will be put into the combustion charge resulting in higher mixture density in the cylinder. Furthermore, less heat means slower burn.
So with a cooler combustion chamber and steam molecules resulting in a slower burn, spark advance and boost pressure can be increased resulting in more horsepower and improved throttle response.
kritz, david001wj and lobitoPU like this.
The Following 19 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
12blkms3 (09-20-2013), atvfreek (10-29-2012), Grumpyjap (04-02-2013), JacksonMS30 (11-01-2012), JDW1 (10-29-2012), kritz (10-29-2012), Lanegrita11 (03-31-2013), leon78 (01-30-2013), Micha (01-30-2013), Pointless (01-11-2013), SC08Speed3 (01-30-2013), sidekick (01-30-2013), SparkySparks (11-01-2012), SPEEDRAC3R (10-29-2012), speed_freak91 (10-29-2012), stuntz89 (01-30-2013), triphop631 (01-11-2013), turboKart (02-16-2013), Twofer (03-30-2013)
 Old 10-29-2012, 01:41 PM   #2
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
Now you can recommend a good kit for me with a fail safe.
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
The Following User Says Thank You to JDW1 For This Useful Post:
EdgeAutosport.com (10-29-2012)
 Old 11-01-2012, 12:26 PM   #3
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
AEM makes an awesome Failsafe that will work with pretty much any kit.
Water/Methanol FAILSAFE Device - 1/4" SAE
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
The Following User Says Thank You to JacksonMS30 For This Useful Post:
JDW1 (11-01-2012)
 Old 10-29-2012, 01:45 PM   #4
Check out this one They dont have a solenoid with the kit but as long as you mount the tank below the pump you will be fine. We can get you a solenoid for 52.50 also
Performance Stage 2 Boost Cooler Methanol/Water Injection System
JDW1 (10-29-2012)
 Old 01-11-2013, 10:47 AM   #5
Bump! This is a good resource! Educate yourself and your experience with your car will be better!
 Old 01-30-2013, 10:31 AM   #6
LumberJack's Avatar
Nice write up, great info! Will be going with a Meth kit on my BT build!
10.36@148 Fastest Gen 2
EdgeAutosport.com (01-31-2013)
 Old 01-30-2013, 07:17 PM   #7
SC08Speed3's Avatar
Posts: 298   (View Stats)
SC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the world
Great info! Im trying to decide exactly which set-up I wont to go with when i go BT..
08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K
SC08Speed3 is offline   Reply With Quote
The Following User Says Thank You to SC08Speed3 For This Useful Post:
 Old 01-30-2013, 10:57 PM   #8
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
Most kits are going to be good such as Devils own and aem and snow.... what is important is how it is setup such as running of maf voltage.
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
The Following 2 Users Say Thank You to The Panda For This Useful Post:
EdgeAutosport.com (01-31-2013), SC08Speed3 (01-31-2013)
 Old 03-30-2013, 06:30 PM   #9
pwdunmore's Avatar
Posts: 368   (View Stats)
I was about to order the Snow Performance silicone adapter for the Stage 2 MAF kit I ordered already(through a GB)... was just wondering if I should be buying anything else. I was planning on mounting the kit somewhere it's easy to fill.
Is there a shopping list of crap I am going to need to do the install?
 Old 04-02-2013, 12:12 PM   #10
There isn't too much outside of the kit that you will need to buy. In order to mount the tank, you may need something to make a bracket out of and the hardware to mount it, but thats about it. Same for the pump too. Just something to make a bracket with.
-Alan
To the people with meth/water injection AntiStock MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 20 05-20-2010 04:50 PM
water/meth injection fillups? johnac08 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 14 01-20-2009 01:09 AM
Water-Meth injection EvilMonkey MazdaSpeed 3 - Engine, Transmission & Driveline 2 08-06-2008 10:41 AM
Page generated in 0.32201 seconds with 27 queries
