  • 1 Post By EdgeAutosport.com
 Old 01-11-2013, 10:28 AM   #1
Default Motor Build Component Resource
Hey guys, we get many requests to put lists together for motor builds and instead of creating it over and over again, we've decided to put a list together so you can more easily prepare for what you need.
We've broken it down into parts that you ABSOLUTELY need when rebuilding your motor, parts that we recommend you replace but sometimes aren't necessary depending on the condition once torn apart, and then the aftermarket options for building it to be able to handle more power.
Please let us know if you have any questions. We'll update this soon with other parts that have become available recently. Yes, Mahle makes a FULL bearing set for these motors now after I worked with one of their representatives to get them to make additional bearings than what was available. We'll also put pricing for short blocks since many blown motors go out the unfortunate way with a window in the block.
mr.speedy3 likes this.
The Following 21 Users Say Thank You to EdgeAutosport.com For This Useful Post:
adlpb (01-11-2013), atvfreek (01-11-2013), Ayaritz (01-11-2013), beachshoer (01-11-2013), blackms3_71 (02-11-2013), btstarcher (01-11-2013), cocoanton (06-10-2013), Code Monkey (01-11-2013), dantes5823 (01-11-2013), Don06speed6 (01-11-2013), GunGuru727 (01-11-2013), Lex (01-11-2013), Manny3 (08-05-2013), moomooz12 (01-11-2013), NeoKraSH (02-16-2018), NJSPEED3 (01-11-2013), psychophyr (01-11-2013), SpeedRebirth (01-11-2013), stevehuff (01-11-2013), taf0422 (01-11-2013), Tommy_y0 (02-08-2016)
 Old 01-11-2013, 10:59 AM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
timing chain should be under most important. i had 10k miles on my built motor and my chain was technically stretched.
also add pauter rods.
great job otherwise!!!!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
dantes5823 (01-11-2013), EdgeAutosport.com (01-11-2013), Jh8909 (01-11-2013), NJSPEED3 (01-11-2013), trf5000 (01-11-2013)
 Old 01-11-2013, 11:35 AM   #3
I actually thought of changing that but hadn't yet. I'll change it. Thanks Anthony.
 Old 01-11-2013, 12:01 PM   #4
Ayaritz's Avatar
Posts: 586   (View Stats)
Ayaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the worldAyaritz is the leader of the world
This is great! Thanks for sharing it.
Ayaritz is offline   Reply With Quote
The Following User Says Thank You to Ayaritz For This Useful Post:
 Old 01-11-2013, 12:21 PM   #5
trf5000's Avatar
Posts: 2,290   (View Stats)
+1 for Pauters......
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
What You Need to Know to Build a Motor TWOptSL0W Mazda MZR DISI Engine Builds (2006-2013) 73 07-26-2019 03:57 PM
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
component speakers dealerjohn1 MazdaSpeed 3/6 - Car Audio & Electronics 6 03-17-2011 03:14 PM
everything neded to build motor? ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-04-2009 11:14 PM
Page generated in 0.29172 seconds with 24 queries
