Like Tree6Likes
  • 2 Post By EdgeAutosport.com
  • 1 Post By Easter Bunny
  • 1 Post By Monotonous ONE
  • 1 Post By breakfstincluded
 Old 06-25-2014, 10:16 AM   #1
Default MZR DISI Remanufactured Cylinder Heads now available at EdgeAutosport!
So your valve met your piston, gave it a little kiss and decided to join together with it in holy matrimony...
Thats all well and good for them but it leaves you and the rest of your engine hanging out to dry on the side of the road in cold bitter loneliness. When this happens it often destroys the head but can leave the block in tact. From here there are a few paths you can take to get you and your poor car back on the road.
Path #1:
Purchase a Remanufactured Long Block - $3940
This option comes with a fresh head and block and is ready to be installed and ran in your car. Not to mention the 3 year unlimited mile warranty...
Path #2:
Its time to build that short block and make some big power but you still need to replace the head.
Enter the MZR DISI Remanufactured Cylinder Head - $1159
This Remanufactured Cylinder Head comes with the same 3 year unlimited mile warranty as the long block and makes replacing the head easy. All the tight tolerances and measurements are done by professionals and the head arrives ready to be installed.
The cores used for this product offering are completely cleaned and inspected for cracks or any damage that would disqualify it for reuse. Any valves, camshafts, springs etc that are out of spec, not useable, or can't be cleaned or prepped for use are replaced completely. All tolerances are within factory specs and the head is complete and ready for assembly.
Upon receiving your assembled cylinder head, you will be provided with a shipping label that you can send your old head back with inside the same crate the new head came in. The shipping of the new head as well as the return of the core is included in the initial cost of the head.
A core charge of $175 is included in the initial price and will be reimbursed to you upon the successful return of your head core in its crate.
Please call us at 303-268-2140 or email sales@edgeautosport.com to check availability of these remanufactured cylinder heads for the Mazdaspeed 3 and 6's.
trancehead and ItsNox like this.
The Following 17 Users Say Thank You to EdgeAutosport.com For This Useful Post:
802MS3 (06-25-2014), Easter Bunny (06-25-2014), Hush (06-25-2014), ItsNox (06-25-2014), JSmith (06-25-2014), Justin@Freektune (06-25-2014), m4tic (06-25-2014), magicka (06-25-2014), Mauro_Penguin (07-05-2014), Mazdazilla6 (10-16-2015), Micha (06-25-2014), Monotonous ONE (06-25-2014), mxlplx71 (06-25-2014), speed23 (06-25-2014), SpeedRebirth (06-25-2014), trancehead (06-25-2014), [R]usty (06-25-2014)
 Old 06-25-2014, 10:41 AM   #2
first
Monotonous ONE likes this.
EdgeAutosport.com (06-25-2014), Monotonous ONE (06-25-2014)
 Old 06-25-2014, 05:05 PM   #3
AshFromCan's Avatar
Posts: 295   (View Stats)
AshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the worldAshFromCan is the leader of the world
I would definitely consider this if I ever needed one.
2013 White MS3
Power |Cobb V3 AccessPort| |Ultimate Racing TBE w/ V2 DP| |Cobb FMIC| |Cobb SRI/TIP| |Autotech HPFP Internals|
Supporting |Cobb RMM| |Cobb Shift Weight|
AshFromCan is offline   Reply With Quote
The Following User Says Thank You to AshFromCan For This Useful Post:
EdgeAutosport.com (06-26-2014)
 Old 06-25-2014, 06:55 PM   #4
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
3rd
Easter Bunny likes this.
The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post:
Easter Bunny (06-25-2014), EdgeAutosport.com (06-26-2014)
 Old 06-25-2014, 06:58 PM   #5
3rd
What a useless post
Fourth.
breakfstincluded (06-25-2014), EdgeAutosport.com (06-26-2014), Monotonous ONE (06-25-2014)
 Old 06-25-2014, 07:10 PM   #6
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
The Following 3 Users Say Thank You to breakfstincluded For This Useful Post:
Easter Bunny (06-25-2014), EdgeAutosport.com (06-26-2014), Monotonous ONE (06-25-2014)
 Old 10-16-2015, 11:27 AM   #7
Hey Edge I have a favor to ask. I was looking at these pictures and noticed some gasket surfaces don't look that shiny. After running a head through a glass bead cabinet it removed the shiny gasket surface in the areas I blasted. If you have one of these in stock could you get some pictures of the exhaust manifold flange, intake manifold flange and injector bores?
 Old 10-16-2015, 12:37 PM   #8
Unfortunately we don't have any reman heads here at this time. They are special order only.
 Old 10-16-2015, 11:52 AM   #9
doctavus's Avatar
Posts: 1,728   (View Stats)
I noticed that right away. Would like to see pictures of the surfaces of a head ready to ship.
MZR DISI Remanufactured Long Blocks now Available at EdgeAutosport EdgeAutosport.com EdgeAutosport.com 148 08-13-2018 06:45 PM
NAPA remanufactured block Axel907 MazdaSpeed 6 - Engine, Transmission & Driveline 57 11-21-2014 09:55 PM
Alternate Cylinder Heads for EcoBoost 2.0L WPaDave_ST Ford Focus ST Ecoboost - Engine, Transmission & Driveline 6 01-19-2013 02:33 PM
HP Remanufactured Photosmart C5280 Color Flatbed All-in-One $64.98 Haltech Hot Deals Section 0 04-03-2008 09:20 AM
Page generated in 0.32085 seconds with 26 queries
