  • 1 Post By EdgeAutosport.com
 Old 03-25-2015, 02:11 PM   #1
Default Redline Tuning Hood Struts at EdgeAutosport!
How many times when working under the hood have you moved just right and slammed your head into the hood support? Well for me, its every time. Never fails... I'm surprised I haven't knocked it loose yet and slammed the hood down on my head. Maybe I just don't have very good situational awareness when working on cars, but fortunately for guys like me there is a solution!
Redline Tuning Hood Struts!
Redline Tuning QuickLIFT PLUS Hood Struts MS3 2010+ - $89.95
Redline Tuning QuickLIFT ELITE Hood Struts MS3 2010+ - $119.95
Redline Tuning QuickLIFT Hood Struts MS3 07-09 - $69.95
Redline Tuning QuickLIFT PLUS Hood Struts MS3 07-09 - $89.95
Redline Tuning QuickLIFT ELITE Hood Struts MS3 07-09 - $119.95
And MS6 because apparently these are still around...
Redline Tuning QuickLIFT PLUS Hood Struts MS6 06-07 - $89.95
Redline Tuning QuickLIFT ELITE Hood Struts MS6 06-07 - $119.95
(pictures for MS6 listing are generic for now)
QuickLIFT
QuickLIFT PLUS
QuickLIFT ELITE
Click the links above to check these out on our site!
Amnesiac (04-15-2015), cody red (04-15-2015), Mauro_Penguin (03-25-2015), MD1032 (03-25-2015), WetzMS3 (03-25-2015)
 Old 03-25-2015, 10:16 PM   #2
tytanium's Avatar
Posts: 137   (View Stats)
tytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant futuretytanium has a brilliant future
just saw these on the site today. will be ordering soon
2007 CWP MS3
Powered by Purple Drank @ 22psi // ATP GT2871r // J2 Engineering catless downpipe // Continental Extreme Contact DW 245/40/17 // Rays Gram Lights 57DR 17x9 // // CP-e Nexus catback // resonator delete // Damond Motorsports rmm // GoFastBits bov // Maisonvi piston style shift knob // Cobb shift weight // Street Unit testpipe // Cobb Accessport V3 // JBR shifter bushings // Treadstone TR8L // JBR intercooler piping // Damond Motorsports power steering cooler // Denso 1-step colder plugs // Ramfab 4" intake // coolant bypass // Damond Motorsports egr block-off // Rally Armor mudflaps // Defi boost gauge // 3 bar MAP sensor // 3 port ebcs // Stratified Guardian Angel // JBR short shifter // Hotchkis rear sway bar // Stoptech ss brake lines // Centric premium brake rotors // Powerstop Z23 brake pads // Koni yellow shocks // Corksport springs // MOOG front and rear endlinks
tytanium is offline   Reply With Quote
 Old 03-25-2015, 10:23 PM   #3
@EdgeAutosport.com; you forgot the links for the ms6.
dagrimey1 (03-26-2015), EdgeAutosport.com (03-26-2015), He Hate Me (03-26-2015), ItsNox (03-26-2015), WetzMS3 (03-26-2015)
 Old 03-25-2015, 11:03 PM   #4
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Ive got these on my pu and are absoulutely what should have came with the car.
TEAM LUXURY
 Old 03-25-2015, 11:12 PM   #5
acemanz's Avatar
Posts: 224   (View Stats)
acemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the worldacemanz is the leader of the world
something is missing from this list...
MS3
MS3
MS3
MS3
MS3
hmm.. i wonder...
Oh yup yup.. there it is...---> (MS6)
dont worry i found it for ya.
acemanz is offline   Reply With Quote
The Following User Says Thank You to acemanz For This Useful Post:
mooseaidz (06-19-2016)
 Old 03-26-2015, 12:18 AM   #6
nekret's Avatar
Posts: 421   (View Stats)
Do these require drilling or do the rivets use existing holes?
Drivetrain
Chassis
Rice
 Old 03-26-2015, 09:02 AM   #7
cyclist20's Avatar
Posts: 636   (View Stats)
cyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the world
I have these. They work amazingly well. You will have to drill holes in the hood. Not hard but requires care and you to measure, remeasure, measure again, then one more time, then double check that.
I wish they would come out with an easy to use template for this to make it slightly easier.
EDIT: To anyone running a Guardian Angel on top of the fuse box, you may have to move the GA back further on the box. The strut hit the GA where I initially placed it (luckily I did a test fit before dropping the hood on it and having a bad day).
2013 LSM Speed BNR S3v3
AP V3
Corksport: HPFP Internals, Injector Seals, bpv, battery box, intake manifold
Full Race: Exhaust Manifold, ceramic coated for lovliness
CNT:Catted DP
Treadstone TR8 with Cobb piping
CP-e: Stage II RMM
HTP:3" intake
Stratified: 3port, Guardian Angel
JBR RSB, Shifter Bushings, EGR Delete/Blockoff
Matt Damond:OCC, PMM, TMM
UR Axleback
Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers
Tuned by PURPLE DRANK
cyclist20 is offline   Reply With Quote
The Following User Says Thank You to cyclist20 For This Useful Post:
 Old 03-26-2015, 12:26 AM   #8
prototype_x9's Avatar
Posts: 174   (View Stats)
prototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the world
I've had these on my car since 2008 and they are a great product. I have no idea why these didnt come on the car from the factory. Everyone should buy something like this
07 GT: JBR 3.5 wide path intake, FMIC, 51R small battery, grimmspeed EBCS, Cobb DP
3Bar map sensor, Kozmic primary and secondary EGR deletes, Bilstein PS14, whiteline endlinks,
hawk brake pads, rear camber arms. Speedbakery tuning in the works
prototype_x9 is offline   Reply With Quote
The Following User Says Thank You to prototype_x9 For This Useful Post:
 Old 03-26-2015, 08:50 AM   #9
KCi
KCi's Avatar
Posts: 93   (View Stats)
The motion when popping up the hood is so much superior than Corksport without the needs of hand assist to stop it at full opening. Corksport hood strut is just so gross and no decelerate motion at the end of opening.
https://www.youtube.com/watch?v=ZYZOq8q2Czo
The Following User Says Thank You to KCi For This Useful Post:
cyclist20 (03-26-2015)
 Old 03-26-2015, 10:22 AM   #10
Shwaykid's Avatar
Posts: 646   (View Stats)
What's the difference between the standard, plus and elite? Just finish color?
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
The Following User Says Thank You to Shwaykid For This Useful Post:
trancehead (03-26-2015)
 Old 03-26-2015, 10:52 AM   #11
MS3
MS3
MS3
MS3
MS3
hmm.. i wonder...
Oh. My. God... You speed 6 guys are still around? Nobody cares...
But serioiusly. We can get them for the speed 6, just don't have them on the site yet. They are the same price for Plus and Elite as the 3, just message me if you want some.
Yes you will have to drill for these. But its totally worth it!
Standard has uncoated brackets. Plus has coated brackets. Elite has coated brackets and stainless shock bodies.
EDIT: Added MS6 to site and updated OP!
taf0422 likes this.
The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Code Monkey (03-26-2015), cyclist20 (03-26-2015), EvoFire (03-31-2015), mazdafreak (03-26-2015), Nliiitend1 (03-26-2015), Sandman978 (03-26-2015), Shwaykid (03-26-2015), WetzMS3 (03-26-2015)
 Old 03-26-2015, 10:52 AM   #12
EvoFire's Avatar
Posts: 389   (View Stats)
^ Want to know about that as well
 Old 04-14-2015, 02:41 PM   #13
You know you guys want some!
 Old 04-15-2015, 09:18 AM   #14
tytanium's Avatar
installed mine last weekend. so amazing not having that hood prop in the way now
2007 CWP MS3
The Following User Says Thank You to tytanium For This Useful Post:
EdgeAutosport.com (04-15-2015)
 Old 04-15-2015, 01:50 PM   #15
cody red's Avatar
Posts: 142   (View Stats)
cody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond reputecody red has a reputation beyond repute
wow, what a great price for something so useful!
cody red is offline   Reply With Quote
The Following User Says Thank You to cody red For This Useful Post:
 Old 04-15-2015, 02:38 PM   #16
Everyone says Rmm/AP/HPFP should be first mods. This should be the precursor to those.
 Old 04-16-2015, 09:22 AM   #17
SparkySparks's Avatar
Posts: 1,314   (View Stats)
I love my set, for anyone installing these, since they require drilling, make sure you don't just leave the metal bare when installing. I didn't have any paint handy when I did mine so I used some RTV to seal around the rivets on both sides of the sheet metal. I actually used enough that it created a gasket between the bracket and the hood.
I went HPFP>AP>Hood Struts>Everything else
On Order:
Coming Soon:
DIY Projects:
Last edited by SparkySparks; 04-16-2015 at 09:22 AM. Reason: MSF Database - Automerged Doublepost
EdgeAutosport.com (04-16-2015)
 Old 04-21-2015, 01:38 PM   #18
Got them in stock!
We've got them. Everyone needs these!
Last edited by EdgeAutosport.com; 04-21-2015 at 01:38 PM. Reason: MSF Database - Automerged Doublepost
Installed Redline Tuning Hood Struts GreyGhost Gen2 MS3 General Discussion 37 06-30-2013 10:43 AM
Hood Lifts - Redline Tuning Zeya Appearance - RED 29 10-19-2009 07:08 AM
Redline Hood Struts bioevolve MazdaSpeed 3/6 - Appearance 33 09-09-2008 04:40 PM
Page generated in 0.41900 seconds with 32 queries
