Like Tree9Likes
 Old 06-16-2014, 04:24 PM   #1
Default South Bend Clutches at EdgeAutosport!
South Bend Stage 2 and 3 Clutches
Just wanted to give you guys another clutch option. South Bend offers stage 2, 3, and 4 clutches capable of holding up to 655 ftlbs of torque.
Stage 2
Stage 2 Daily South Bend Clutch Kit - $979.51
350 ftlbs.
Stage 2 Endurance South Bend Clutch Kit - $1088.34
400 ftllbs.
Stage 2 Drag South Bend Clutch Kit - $1088.34
450 ftlbs.
Stage 3
Stage 3 Daily South Bend Clutch Kit - $1197.17
430 ftlbs.
Stage 3 Endurance South Bend Clutch Kit - $1306.01
500 ftlbs.
Stage 3 Drag South Bend Clutch - $1414.84
625 ftLbs.
Stage 4
Stage 4 Extreme South Bend Clutch Kit - $1523.68
655 ftlbs.
Let me know if you guys have any questions!
The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post:
802MS3 (06-16-2014), Code Monkey (06-16-2014), JgamB (06-25-2014), Mauro_Penguin (06-16-2014), mxlplx71 (06-16-2014), silvapain (09-01-2014), Snyeed (06-16-2014), SpeedRebirth (06-16-2014)
 Old 06-16-2014, 04:32 PM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
flywheel weight? found it 22lbs
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
EdgeAutosport.com (06-17-2014)
 Old 06-16-2014, 04:37 PM   #3
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Hardest decision of my life right now! Twin disk or stage 3 south bend....
417whp 428tq 12.037@117.2mph
 Old 06-16-2014, 05:19 PM   #4
someguy's Avatar
Posts: 914   (View Stats)
Neat...so what are these like? Compared to OEM? Compared to ACT?
 Old 06-16-2014, 05:54 PM   #5
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I knew i could count on you guys!! Bringing the best for our speedy needs! Thumbs up!
You can read peoples views on them here: southbend-clutch-speed6
I can confidently say that they are the best clutch for our cars. Better engagement than act, less shatter, will hold alot of torque ect ect.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 06-16-2014, 08:14 PM   #6
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Think the link in the stage3 section for the endurance clutch might be wrong (pointing to the stage2 endurance option?).
Their part numbers are so damn confusing.
I ordered the stage2 option from RealTune's website, and the part list I got in the box states that it is part # 'KMZDSP SS TZ' but that doesn't seem to match any of their part numbers from their website. It closely matches the stage3 endurance option (KMZDSPD SS TZ) though. My clutch disc material felt like Kevlar FWIW...I'm hoping it is the stage3 option, since the pedal feel is barely heavier than stock. I am thinking of trying to push over the 400wtq line.
Wish you guys started selling these earlier this season, I defintiely would have bought one from you.
'08 CWP MS3 w/ T3 3071r
EdgeAutosport.com (06-17-2014), Mauro_Penguin (06-16-2014)
 Old 06-17-2014, 02:47 AM   #7
shaneski's Avatar
Posts: 505   (View Stats)
FYI everyone, these are a few bucks cheaper than realtune ($20 cheaper for the clutch I ordered).
Not 100% sure but i think real Tune use a modified clutch plate (different material) hence they don't offer different categories for each stage.
 Old 06-17-2014, 08:18 AM   #8
That is a difficult decision... I think I would take a twin disc over the South Bend, if money wasn't an issue, but as far as bang for buck goes, you can't go wrong with South Bend.
These are very good clutches. I would definitely take one of these over the ACT if money isn't an issue. Not saying ACT is bad, just saying South Bend is better. No overly aggressive pedal, and can hold loads of torque.
 Old 06-17-2014, 09:08 AM   #9
SneakySin's Avatar
Posts: 780   (View Stats)
SneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the worldSneakySin is the leader of the world
Groaned at 7 Times in 4 Posts
I've heard the name Southbend but dont know anyone who runs one. Can anybody explain the hype? Whats so great about them? May be interested
2008 Speed 3
CS 3" Intake//BNRS3v2//GS EBCS//3BAR MAP SENSOR//AT FP Internals//ATP DP catless//Custom FMIC//JBR Stage 3 SSP//CP-e Stage 2 RMM//MD OCC w/Sight Tube//EGR Del//NGK Iridium IX Plugs//Cobb AP//FreekTuned!!!!!
SneakySin is offline   Reply With Quote
 Old 06-17-2014, 01:12 PM   #10
They make clutches for a lot of extreme diesel trucks and stuff like that which need to hold tons of torque. And now they are making them for import cars like the mazda. So they no what it takes to make a clutch hold some torque.
Micha (06-24-2014)
 Old 06-17-2014, 01:27 PM   #11
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
Groaned at 20 Times in 11 Posts
steel flywheel too right?
dan7225 is offline   Reply With Quote
 Old 06-18-2014, 11:30 AM   #12
Yes, it is a steel flywheel.
 Old 06-24-2014, 04:03 PM   #13
These are really good clutches! They are quite capable of holding up to the abuse of a lot of torque.
 Old 06-24-2014, 09:03 PM   #14
cletusb's Avatar
Posts: 488   (View Stats)
My order is awaiting shipment
EdgeAutosport.com (06-25-2014)
 Old 07-14-2014, 10:35 PM   #15
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
Just installed mine and it catches just off the ground. Is there any way to adjust this? Also since it has been installed my reverse gear is a bitch to get into. Any help?
"under construction"
 Old 07-15-2014, 08:01 AM   #16
timmcc02's Avatar
Posts: 253   (View Stats)
timmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the worldtimmcc02 is the leader of the world
Groaned at 9 Times in 3 Posts
Bleed your slave cylinder
timmcc02 is offline   Reply With Quote
The Following 5 Users Say Thank You to timmcc02 For This Useful Post:
06Speed6 (07-15-2014), 2012FailWheelDrive (07-15-2014), Cevaes_64 (07-16-2014), EdgeAutosport.com (07-15-2014), Mauro_Penguin (07-15-2014)
 Old 07-15-2014, 08:53 AM   #17
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I have a relined oem disc by South Bend with the stock flywheel and pressure plate, the quality was perfect, the measurements were spot on, and the customer service was awesome. This is the second time I have ordered from them and I haven't been disappointed yet.
2006 Mazdaspeed 6
 Old 07-15-2014, 09:05 AM   #18
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
I will be running the stage 4 with my new set up, the clutch actually arrives tomorrow.
860whp/677wtq
2.7 V6 Ecoboost
 Old 07-15-2014, 06:05 PM   #19
Bled slave and lost all pressure in clutch pedal. After a full bottle of brake fluid some pressure is back but not like at fist. When car is on and clutch pushed in the car will not go in gear. After searching it may be a backwards clutch disk but I drove the car yesterday so idk if thats it. Any help appreciated.
 Old 07-15-2014, 07:01 PM   #20
timmcc02's Avatar
Normally backwards clutch disc and you aren't getting that transmission back in, but it could be different with the getrags on the speeds. Maybe the fork is not seated on the trans properly
 Old 07-15-2014, 08:32 PM   #21
Thanks for your help. I had a hunch that there was still air in the slave and what I did was take it off and position it that the bleeder was pointing straight up then bled it that way. Put it back on and everything is nice and smooth now.
The Following User Says Thank You to 2012FailWheelDrive For This Useful Post:
EdgeAutosport.com (07-16-2014)
 Old 07-15-2014, 08:53 PM   #22
timmcc02's Avatar
That's good to hear man, always sucks to take apart something twice when it's something like a trans so that's good
 Old 07-16-2014, 03:14 AM   #23
shaneski's Avatar
Good to hear its working, i'm waiting on mine to be shipped. How does the engagement feel, and what spec did you get.
 Old 07-16-2014, 07:53 AM   #24
I have the stage 3 endurance. Engagement is very smooth and easy with a slightly stiffer pedal and just a bit more chatter than stock. Its a great performance clutch without losing drivability. Can't wait to really beat on it.
The Following 3 Users Say Thank You to 2012FailWheelDrive For This Useful Post:
EdgeAutosport.com (07-16-2014), JTMS3 (07-29-2014), shaneski (07-17-2014)
 Old 07-16-2014, 08:24 AM   #25
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
^^ Then Dont wait.. set LC at 4K and spin out the shop or garage...
 Old 07-16-2014, 08:36 AM   #26
South bend says not to launch hard in the first couple hundred miles, plus its mated to a newly built motor which is breaking in as well.
EdgeAutosport.com likes this.
 Old 07-16-2014, 08:45 AM   #27
Glad you got the issue sorted and are enjoying the clutch! We have been very impressed with South Bend and their quality as well as their customer service!
 Old 07-16-2014, 08:52 AM   #28
Yes, so far I'm very satisfied with the clutch. Top notch product indeed.
 Old 07-16-2014, 10:01 AM   #29
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Looks like I know which clutch I will be going with in a couple of months. This car loves keeping my pockets empty.
On Order:
Coming Soon:
DIY Projects:
 Old 07-28-2014, 04:42 PM   #30
Seriously awesome clutches here! Anyone looking to upgrade should definitely consider these.
 Old 07-29-2014, 02:32 AM   #31
shaneski's Avatar
the stage 3 enduros back in stock?
 Old 07-29-2014, 08:40 AM   #32
Not yet unfortunately... :/
We have the Stage 2 Daily in stock. The Stage 3 Endurance is on backorder, but the rest are available to be drop shipped from South Bend.
shaneski (07-29-2014)
 Old 08-13-2014, 01:09 PM   #33
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
What type of lifespan could one expect from the stage 2 endurance kit? Haven't been able to find any info on that, probably because there haven't been enough people running them long enough.
My stock clutch has started slipping with 97k miles on it, 12-13k miles since installing the BNR S3.I'm making the power in my sig, strongly considering going with an oem replacement after speaking with some people on here about it, but the Southbend option is intriguing. I just don't want to have to replace the clutch again 20k-30k miles down the road. I don't auto x or drag race my car (I've been to the drag strip 3 times in 4 years and don't see myself going much more), but I do go WOT on a daily basis while driving around town.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 08-13-2014, 01:48 PM   #34
Its hard to give a good estimate of lifespan on a clutch because it depends very heavily on the driver. Also, you are correct. There are not enough Mazdaspeeds running this clutch for long enough to have any basis to go off of.
 Old 08-15-2014, 07:27 AM   #35
JTMS3's Avatar
Posts: 2,306   (View Stats)
Beefy!
The Following 3 Users Say Thank You to JTMS3 For This Useful Post:
Brendanb (06-13-2015), Cevaes_64 (08-15-2014), Mauro_Penguin (08-17-2014)
 Old 08-15-2014, 10:00 AM   #36
Originally Posted by JTMS3 View Post
Beefy!
Its so pretty!
JTMS3 (08-15-2014)
 Old 08-17-2014, 02:35 AM   #37
Nel Mazdaspeed's Avatar
Posts: 407   (View Stats)
I just got my stg3 Daily Driver installed on Friday.. The clutch pedal feel to me is nothing like stock, it's really heavy and stiff, hard to push back. Has any one else experienced the same thing?
I read an earlier post that his pedal was barely different than stock feel but a little more chatter than stock, which by the way I have zero chatter!
Any Ideas on the heavy pedal?
 Old 08-17-2014, 11:17 AM   #38
Give it time to break in.
The Following 4 Users Say Thank You to 2012FailWheelDrive For This Useful Post:
EdgeAutosport.com (08-18-2014), JTMS3 (08-17-2014), Mauro_Penguin (08-17-2014), Nel Mazdaspeed (08-17-2014)
 Old 08-17-2014, 06:11 PM   #39
That's what I was hoping to hear Thx.
 Old 08-17-2014, 10:08 PM   #40
Mylifeiseasy's Avatar
Posts: 74   (View Stats)
Mylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud of
Groaned at 6 Times in 3 Posts
i got about 1k on mine so far. it was stiff for a wile but seems normal now. egagment seemed close to floor but that has got better and again feels normal almost stock like now. i used to have work hard to get the tires to chrip 3rd now it does with ease. i got the stage 3 430lbs. i couldnt be happier. sbc is the best option we have now. i also have less vibs now. the stock fw was fucked at 63k it was fallin apart.
2008.5 gtx fmic dm pd Manley
Mylifeiseasy is offline   Reply With Quote
The Following 3 Users Say Thank You to Mylifeiseasy For This Useful Post:
EdgeAutosport.com (08-18-2014), IMASA (08-18-2014), JTMS3 (08-18-2014)
ACT Clutches In Stock at EdgeAutosport. EdgeAutosport.com EdgeAutosport.com 7 09-30-2013 03:42 PM
3" crush bend vs 2 1/2" mandrel bend exaust chuckdaiceman MazdaSpeed 6 - Engine, Transmission & Driveline 7 05-04-2009 11:18 PM
Page generated in 0.61144 seconds with 40 queries
