| EdgeAutosport.com EdgeAutosport.com is committed to being the best at what we do. High performance aftermarket parts is what we do but not who we are. We operate at the highest level of integrity and honesty, all while bringing you superior products and unmatched customer service and support. We hold ourselves to the highest standards, just like we do for our cars! Let us know how we can help! |
(Thread Starter) | Not Ranked : 0 score Hey guys, we are always looking to make things easier for you when purchasing stuff on our site. We want to make sure you get everything you need. In some cases people don't know exactly what they need and that's why we have put together kits for motor build, VVT, and OE clutch as well as a few others. For our latest "kit" we have the Supertech Valve Train. Its nothing crazy, and is just to save you a step when ordering parts for your head. ![]() The Supertech Valvetrain Kit comes with guides and seals as well as the springs of your choice. With this kit, we are just trying to make it a little bit easier and save some people having to call back and order again after they realize they need the valve guides and seals as well. The Supertech Valvetrain Kit is $496.98 and you can have your choice of 55lb, 70lb, or 83lb springs. As always, let us know if you have any questions, and we'll be happy to help!! |
| The Following 11 Users Say Thank You to EdgeAutosport.com For This Useful Post: | dan7225 (12-10-2014), Hammology (12-23-2014), hatchedspeed3 (12-16-2014), jack_hammer (12-16-2014), kbz0129 (12-10-2014), Micha (12-10-2014), Mr. T (12-11-2014), rob ms6gt (12-10-2014), SparkySparks (12-10-2014), SpeedRebirth (12-10-2014), WetzMS3 (12-16-2014) |
![]() Join Date: Jan 2011 Location: Naval Station Guantanamo Bay, Cuba
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score @EdgeAutosport.com; you all know how to make the decision to buy or not to buy a whole lot easier.... I noticed that the Exh valve and Intake valve you sell from supertech (their catalog here: Exh and Intake) difference in valve dimensions: Exhaust - Supertech Head Diam: 30mm(std) Stem Diam: 5.48mm Length: 104.7mm Exhaust - OEM spec from manual- Head Diam: 28.3 (not accounting for margin thickness) Stem Diam: 5.965-5.980mm Minimum: 5.935mm Length: 104.25--105.05mm Intake- Supertech Head Diam: 35mm(Std) Stem Diam: 5.48mm Length: 103.40mm Intake - OEM spec from manual Head Diam: 33.5mm (not accounting for margin thickness) Stem Diam: 5.970-5.985mm Minimum: 5.940mm Length: 102.99--103.79mm I am assuming that the supertechs head diameter are larger because they account for the seat length while Mazda does not, but why the difference in stem diameter? I saw in an earlier post from you all that supertech valve guides are needed, and I assume this valve stem diameter is the reason?
__________________ 2006 "GTMO Green" Speed 6 { Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals } { TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy} {TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs } { HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge } { AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt } { Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs } { Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint } |
It probably has something to do with the manufacturing process. These valves are most likely used in a few other platforms so its easier and more cost effective for supertech to make a valve with a certain stem thickness and just change the the seals to fit the different applications. | |
(Thread Starter) | Not Ranked : 0 score Valvtrain kit comes with everything but the valves might as well build your engine once and build it right! |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | WetzMS3 (09-29-2015) |
(Thread Starter) | Not Ranked : 0 score Doing a build? Build it right the first time! |
| Supertech Valvetrain Info | holeinmypocket | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 03-06-2015 11:29 AM |
| E30 UOA results with SuperTech 5w-30 Synthetic | cld12pk2go | MazdaSpeed 3/6 - E85 Fueling | 6 | 08-27-2014 10:31 AM |
| Supertech Valvetrain at EdgeAutosport | EdgeAutosport.com | EdgeAutosport.com | 5 | 05-28-2014 05:12 PM |
| Supertech valve into | jracer | Mazdaspeed3/6 General Discussion | 28 | 09-25-2012 03:20 PM |
| Supertech wants our head | zx2man | MazdaSpeed 3 - Engine, Transmission & Driveline | 38 | 07-17-2011 07:03 PM |
