Like Tree5Likes
  • 1 Post By EdgeAutosport.com
  • 1 Post By Dmurray06
  • 1 Post By helmetface
  • 1 Post By Sid3wayS
 Old 08-22-2012, 03:05 PM   #1
Default Vacuum Blocks 3P
Hey guys we have some new vacuum blocks from 3P performance. These are prototype units so get in on them now and we are the only one carrying them, we just bought 3p's entire first run.
We are offering free shipping on these blocks and they are 49.99 shipped
Here are a few pics of the some of them
Dmurray06 (08-22-2012), PapaSmurf (08-22-2012), rfinkle2 (08-24-2012), speed14 (09-05-2012), uncorked11 (09-05-2012)
 Old 08-22-2012, 03:10 PM   #2
Dmurray06's Avatar
Posts: 3,279   (View Stats)
They come with nipples and or plugs?
4cefedauto likes this.
EdgeAutosport.com (08-22-2012)
 Old 08-22-2012, 03:11 PM   #3
Since they are prototype versions I have to check if they are going to include those on this run but I find out asap. When we put a full race one on the shop car we had to go buy all new fittings anyways because the ones supplied with the kit were too big for our application
 Old 08-22-2012, 03:13 PM   #4
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
do you have the a picture of the outer sides? is there also ports there?
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-22-2012, 03:13 PM   #5
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
interested.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
The Following User Says Thank You to dereeek For This Useful Post:
 Old 08-22-2012, 03:16 PM   #6
Yeah there are ports on both ends. I know I was a little slow and didnt take pics of that part.
Edited op with pics of le side
Last edited by EdgeAutosport.com; 08-22-2012 at 03:16 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-22-2012, 03:25 PM   #7
PapaSmurf's Avatar
word.. you need more tabs open.
I might pick one of these up, have to check under my hood tonight to see how many ports I would need.
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-22-2012, 03:26 PM   #8
Let me know I can take it to the 4 corners meat
 Old 08-22-2012, 03:26 PM   #9
Niceeee
 Old 08-22-2012, 04:20 PM   #10
Here are some pics of the full race one on the shop car we mounted it on the front of the battery box.
 Old 08-22-2012, 04:26 PM   #11
PapaSmurf's Avatar
Where did you end up getting the fittings at?
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-22-2012, 04:26 PM   #12
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Technicolor engine bay yo!
uncorked11 likes this.
 Old 08-22-2012, 04:33 PM   #13
Bought all the fittings at ace hardware
JP raves it all over the place lol
Last edited by EdgeAutosport.com; 08-22-2012 at 04:34 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-22-2012, 04:34 PM   #14
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Ace hardware carrys them in the plumbing section. Thats where I got mines at.
Edit: damn to slow.
EdgeAutosport.com likes this.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
EdgeAutosport.com (08-22-2012), PapaSmurf (08-22-2012)
 Old 08-22-2012, 04:35 PM   #15
Exactly
Sid3wayS (08-22-2012)
 Old 08-22-2012, 04:38 PM   #16
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Um... K so what are these things?
The Following User Says Thank You to Fatguy729 For This Useful Post:
 Old 08-22-2012, 04:45 PM   #17
So what these things help is consolidate all the vacuum lines you have and t fittings that run all over the place that could cause either leaks or in some instances different pressure because of the size of the vacuum lines
The blocks help make sure the bov, wastegate, boost gauge and the other vacuum lines you run to it see the same amount of pressure. Ultimately they clean up the engine bay and help with consistency of what your hard parts see. Depending on peoples current configuration this could potentially help you with better spool and over all better operation for the hard parts this is hooked up with.
PapaSmurf likes this.
Buildabong (08-23-2012), Fatguy729 (08-23-2012), PapaSmurf (08-22-2012)
 Old 09-05-2012, 07:31 PM   #18
dereeek's Avatar
Groans: 386
pm'd for purchasing.
BNR3-FREEK-PU-398HP
EdgeAutosport.com (09-06-2012)
 Old 09-06-2012, 07:49 AM   #19
bump pm replied
 Old 09-11-2012, 08:58 AM   #20
ttt
BatSlobber (12-28-2015)
 Old 09-11-2012, 12:46 PM   #21
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
i'm going to put my ignorance on display for the benefit of others, so...
why do these vacuum blocks have so many ports. what the hell could you hook up that needs so many?
boost gauge
BPV
wastegate
boost controller
would you have it to both your stock wastegate and, say, a GS controller? or would you do just one or the other?
is that it?
it's fun to do bad things
 Old 09-11-2012, 01:32 PM   #22
You also need them say you have a boost a tap, or the port of the IM. Also if you run dual wastegates this really helps.
Also yeah I would have it to the stock iwg and GS also.
jack_hammer (09-11-2012)
 Old 09-13-2012, 10:54 AM   #23
ttt
 Old 12-10-2012, 06:56 PM   #24
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
boost controllers are supposed to be hooked up on the turbo itself or on the intercooler piping right after turbo.
boost source needs to be closer to turbo ???
im sure it might work hookedmup to IM but from what i understand its dangerous or wont work as well.
fyi I do want a vacuum block i was looking into one, i wish i could run wastegate and boost controller and everything off of one block but your not supposed to do it that way, i want one for my BOV, Boost a spark sensor, boost gauge
pic attached.
EDIT: so final word is it does not come with fittings right ?
 Old 12-10-2012, 07:08 PM   #25
helmetface's Avatar
Groans: 219
b
Where did you read that about the WG/BC not supposed to be hooked up to a block?
 Old 12-10-2012, 07:11 PM   #26
Daily Driver
Nitr0EngiE's Avatar
its all over the isntructions with the boost controllers themselves, turbosmart says it in thier instructions, and thats why turbos have the flat spot on the snail itself to add a boost fitting.
and my fabricator said so, there are many places that say it. the fitting being on turbo or IC pipe after turbo is different than after the TB. when TB closes the wg and boost controllers wont see accurate info.
I am sure you can make it work off of IM connection and fuck if it was proper it would look really cool because I could then use all the ports on the vacuum block and it would look nice. but I dont even have a boost controller, i make life easy and just run 25 psi spring =)
EDIT: I never said Not supposed to be on a block !!!! i said the boost source should not be off IM
now i know some SSQV use vacuum line from IM to control it but thats a BOV tapping WG. not the WG's source of boost !
EDIT2: just look at @superskaterxes; setup hes EXACTLY like mine he tapped IC right after turbo for the WG/Boost controller connection
Thinking of changing my PCV system setup
its right there in the pics.... I just dont want people to hook EVERYTHING to this block and have overboosting issues or some shit because the sources are coming from the wrong place in a wrong setup. i do NOT know what the negative effects are i simply hooked mine up as directions stated in the first place. if you really want it on a "block" you will need two blocks one for IM side and bov and boost gauge and shit other block strictly WG/boost control
 Old 12-10-2012, 07:16 PM   #27
helmetface's Avatar
Groans: 219
Ya I was assumed the IM was feeding the block.
I guess I'll be running ECBS and WG off their own setup. And then my BPV, IM and boost gauge off the block..
 Old 12-10-2012, 09:05 PM   #28
Daily Driver
Nitr0EngiE's Avatar
yes sir !
Edge auto sorry about thread clutter, i thought it a good idea to chime in.
 Old 12-13-2012, 08:17 AM   #29
yes sir !
Not a problem at all. It is always recommended that the boost source is the closest it can be to the turbo, if not, actually on the compressor housing but you can still tap into any part of the intake post-turbo. The difference ends up being that the closer the tap is to the turbo, you get quicker response and it's more accurate to the actual boost the TURBO is creating. When it's tapped in the manifold, you're tuning based more on what the engine is seeing and the turbo is actually working harder than the boost reading would suggest. We have our car tapped into the manifold.
Why Aren't We Running these ERL MZR sleeved blocks? Alpha MazdaSpeed 6 - Engine, Transmission & Driveline 115 01-31-2014 11:22 AM
MS6 towed on two wheels for a couple blocks xfeejayx MazdaSpeed 6 - Engine, Transmission & Driveline 20 05-05-2012 04:56 AM
Page generated in 0.48716 seconds with 30 queries
