| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
(Thread Starter) | Not Ranked : 0 score Here are a couple of caveats to the build you must be aware before making recommendations: 1.) Stock exhaust retention. At most I'd be willing to upgrade to a catted DP. 2.) Must work with the CorkSport TMIC as I want to retain the stock shroud (stock is better but not required) 3.) I do not have access to e85 locally. Max is 93 4.) Reliability is paramount. Again, Reliability is of utmost importance. 5.) stock internals and sensors and NO CEL. This car must pass emissions w/o me spending the weekend getting it ready to pass. some parts I've already purchased: 1.) cobb accessport 2.) denso itv22's 3. CS intake (purchased before deciding to go BT so not necessarily a required use, but if it could be incorporated it would be nice) anyways. Thanks for your time. Please do not ask me to donte for answers. I'll donate when I'm ready. |
| The Following 11 Users Say NO Thank You to NCspecV81 For This Un-useful Post: | ANITIX87 (04-15-2013), Easter Bunny (04-15-2013), Fatguy729 (04-15-2013), Hush (04-15-2013), Kyle Undefined (04-15-2013), MADDOG 20/20 (04-15-2013), mazdafreak (04-15-2013), p057 (04-15-2013), Pu Manchu (04-15-2013), Raider (04-15-2013), SofaKingAwesome (04-15-2013) |
![]() Join Date: Feb 2011 Location: Killeen, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 504
Groans: 34
| Not Ranked : 0 score Oh lord reekress this is gonna be bad But seriously. Edgeautosport.com. Call those guys they will take care of you.
__________________ BT Build in process, should have engine running in a couple days.....knock on wood. |
| The Following 3 Users Say Thank You to sLow6 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score not sure what your first comment eludes to, but that they were on next on my list of contacts. |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,655
| Not Ranked : 0 score Are you in north carolina?
__________________ [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score yes I am. |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score Would you be inclined to use meth? tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() Join Date: Jan 2013 Location: Stoughton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
Groaned at 86 Times in 51 Posts
| Not Ranked : 0 score I cant believe i am saying this but... DO SOME FUCKING RESEARCH!!!!!!!!!!!!!!!!!!
__________________ 2010 Speed3 w/tech Bolted E85 FREEKTUNE |
| The Following 2 Users Say Thank You to mrshoulders For This Useful Post: | Kyle Undefined (04-15-2013), sLow6 (04-15-2013) |
| The Following 3 Users Say NO Thank You to NCspecV81 For This Un-useful Post: |
You joined, and obviously skipped reading the welcome PM and the knowledgebase. So STFU. Stop posting. Start reading. If you did, you would know you need at bare minimum, a fuel pump solution. Donate. | |
| The Following 2 Users Say Thank You to Raider For This Useful Post: | Kyle Undefined (04-15-2013), mrshoulders (04-15-2013) |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Wait, let me get this straight. You have an AP and an intake and think you know what the KO4 is capable of...? Ahahahahahahahahahahaha.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| The Following 5 Users Say Thank You to CWP_MS3 For This Useful Post: | johnredding (04-15-2013), Kyle Undefined (04-15-2013), mazdafreak (04-15-2013), mrshoulders (04-15-2013), VulgarKyle (04-18-2013) |
| Not Ranked : 0 score You will need WMI to get to that power level regardless of turbo you use (for 380whp). For 350, a GT3071 will do it at lower boost on good 93. The turbos I would consider for this are the BNRS3 or GT(X)3071. For the BNRS3 you will need an upgraded MAP sensor for the GT30, you may be able to scrape 350whp at 21-21.5psi on the stock MAP sensor on a cooler day. The GT30 is more obvious than a BNR install due to the larger intake and inlet. You will need an upgraded HPFP and likely a larger intake than stock. You will also need to control boost via either the OEM EBCS and a Boost Dial, or a 3 port EBCV.
| The Following User Says Thank You to Lex For This Useful Post: | zedekias (04-16-2013) |
| Theres a reason why i send huge PM's to new users. You failed to read it. Goodluck
| The Following 2 Users Say Thank You to Haltech For This Useful Post: | Kyle Undefined (04-15-2013), Raider (04-15-2013) |
| Not Ranked : 0 score But guys, he has IVT22's. I bet SURE told him that is the mod list for success, lol |
| The Following 4 Users Say Thank You to Raider For This Useful Post: | Fatguy729 (04-15-2013), Kyle Undefined (04-15-2013), mazdafreak (04-15-2013), VulgarKyle (04-18-2013) |
Groans: 433
| Not Ranked : 0 score Don't buy any more CS parts because @TexanMS3; likes to jizz all over their parts before they're shipped......after blowing everyone over there. Cuz, you know you're better than a group after you learn everything there is to know about the ms3 from a salesman at a parts company.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. Last edited by Chimmike; 04-15-2013 at 03:30 PM. |
| The Following User Says Thank You to Chimmike For This Useful Post: | Kyle Undefined (04-15-2013) |
| MX-5 EFR Turbo Build | Andy@Killshot | Miata - Forced Induction | 40 | 12-28-2011 04:01 PM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Turbo Build | UKMPS3MK2 | 2010 MS3 - Turbo Induction | 12 | 05-10-2011 09:53 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
