> 2010 MS3 - Big Turbo Builds
  • 1 Post By Monotonous ONE
 Old 07-12-2012, 05:31 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default COBB Adjustable Internal Wastegate Brackets Now Available
COBB Tuning is proud to announce the availability of an innovative new pair of Internal Wastegate (IWG) Brackets for Subaru and MAZDASPEED vehicles in short and long bracket styles. The COBB Tuning Adjustable IWG Bracket is the first of its kind, and the most versatile and reliable way to keep a turbocharger’s internal wastegate closed when using an external wastegate setup. The Adjustable IWG Bracket can be installed quickly, adjusted for perfect fitment on many different turbos, and can be removed just as easily to return a turbo to its original configuration.
The COBB Adjustable IWG Bracket replaces the internal wastegate actuator and locks the wastegate in a fully closed position. This is a superior solution to welding the wastegate door closed, which is a time-consuming, expensive and irreversible process. The COBB Adjustable IWG Bracket is easy to install and bolts into place and adjusts quickly using simple hand tools.
Not all turbos are made exactly the same, and there can be variations in housings, center cartridges, clocking, etc. A single position internal wastegate bracket may not accommodate these variations and fail to close the wastegate completely, which will result in poor turbo response and lower maximum boost. The COBB Adjustable IWG Bracket takes the worry of turbo-component variance out of the equation and allows proper adjustment, every time, on a variety of different turbos that a non-adjustable internal wastegate bracket simply cannot match.
The COBB Adjustable IWG Bracket’s advantage lies in its unique adjustable rod-end linkage. The turnbuckle center section features right-hand and left-hand threads to make adjustment as easy as rotating it one direction or the other to shorten or lengthen it. The rod-end linkage and through-bolt allow high misalignment for maximum adjustability. The bracket itself is made from a single piece of 11-Gauge steel and incorporates slotted bolt holes for additional adjustability and turbo compatibility. The custom spade-bolt that connects to the wastegate arm, the bracket, and the turnbuckle are black zinc coated for an attractive finish that is corrosion resistant. All hardware for install is included in this kit.
The COBB Tuning Adjustable IWG Bracket offers maximum turbo compatibility, simple installation and is easily adjustable to ensure complete wastegate closure to get the maximum performance from your specific setup. In the familiar words of our dads, “Make sure you shut the ****ed door!”
Part #: 512273
MSRP: $39.00
Applications: Click Here
Part #: 512274
MSRP: $39.00
MAZDASPEED EXPERT GROUP
- ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE
The Following 8 Users Say Thank You to Cobb Tuning For This Useful Post:
atvfreek (07-12-2012), Easter Bunny (07-13-2012), EdgeAutosport.com (07-13-2012), fishin53 (07-13-2012), MS3-a(sore)ASS-rex (07-13-2012), MS3G35 (07-13-2012), speedms6 (07-13-2012), Vader (07-13-2012)
 Old 07-12-2012, 05:34 PM   #2
atvfreek's Avatar
Posts: 7,787   (View Stats)
Great idea and for a very reasonable price!
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 07-12-2012, 05:34 PM   #3
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
sweet... ewg K04's?
860whp/677wtq
2.7 V6 Ecoboost
 Old 07-13-2012, 08:11 AM   #4
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
sweet... ewg K04's?
Sure! The Subie guys do it all the time. I'd like to see a Mazda owner go for it on a K04.
This is a viable option for a Mazda guy who has an IWG GT series turbo that they'd like to switch over to EWG with. Strap the flap down and slap on an EWG manifold and you're good to go!
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following 4 Users Say Thank You to Evan@COBB For This Useful Post:
MS3-a(sore)ASS-rex (07-13-2012), MS3G35 (07-13-2012), PapaSmurf (07-13-2012), Vader (07-13-2012)
 Old 07-13-2012, 08:28 AM   #5
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
if only there were options for ewg manifold
haha
 Old 07-13-2012, 08:29 AM   #6
Looks like an awesome option.
 Old 07-13-2012, 10:32 AM   #7
PapaSmurf's Avatar
haha
Fail CP-E manifold u can get with external and Mazda flange I believe.
860whp/677wtq
2.7 V6 Ecoboost
 Old 07-13-2012, 10:36 AM   #8
Groans: 819
sorry...i meant options that fit
PapaSmurf likes this.
 Old 07-13-2012, 10:38 AM   #9
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
fuck me
Is my internal wastegate broke? jiveturkey MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 07-22-2012 02:28 PM
Adjustable Wastegate SRHTX Gen2 MS3 General Discussion 6 04-09-2012 12:18 PM
can you utilize and internal AND external wastegate? TWOptSL0W MazdaSpeed 3/6 - Big Turbo Builds 2 07-14-2011 09:29 PM
the ultimate internal wastegate cbspeed3 MazdaSpeed 3/6 - Turbo Induction 2 09-12-2008 02:40 PM
Cobb RSB and adjustable end link installation Fiesta42 MazdaSpeed 3/6 - Suspension & Brakes 3 07-29-2008 05:25 PM
Page generated in 0.31508 seconds with 26 queries
