> 2010 MS3 - Big Turbo Builds
 Old 04-13-2019, 03:02 PM   #1
Mini Franki's Avatar
Posts: 37   (View Stats)
Mini Franki will become famous soon enough
Default Gtx2867 gasket leak?
Hi,
I see some oil on the most under bolt of the cold side of the turbo, i think its the seal? Confirmation?
https://ibb.co/brdyPMF
Thx
Mini Franki is offline   Reply With Quote
 Old 04-19-2019, 01:41 PM   #2
I can confirm this is not a leak from the inside of the turbo. My turbo inlet is super clean, no fresh oil
Its hard to know if that come from oil feed line but i dont see any oil on the center of the turbo, only on cold side and on the rubber tube of the coolant line
https://ibb.co/10bfhg7
 Old 04-21-2019, 02:58 PM   #3
I find some fresh oil in the TMIC
How to know if its the turbo seal or if its the PCV?
Oil leak coming from the head gasket(built motor) stockms3 MazdaSpeed 3 - Engine, Transmission & Driveline 8 02-18-2017 10:54 AM
Catless DP install, a week later boost leak / blown gasket? tmaiorca MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 03-15-2016 02:32 PM
Gasket leak? jerihaly MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 10-23-2014 12:10 PM
PG manifold V2, replacement gasket with small raised area... leak path? MS3 Ventura Mazdaspeed3/6 General Discussion 2 09-29-2008 09:12 PM
Page generated in 0.22621 seconds with 20 queries
